misc satoshi questions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by EricT, Sep 4, 2009.
  1. Sep 4, 2009 at 2:13 PM
    EricT
    EricT [OP] Well-Known Member
    Arizona
    '09 4x4 shortbed TRD Sport
    Hey guys-
    Gonna do my satoshi tonight/tomorrow. So I went to the super fancy auto paint store, annnnd.... they were out of satin black in a rattle can. I did get some SEM brand flexible primer surfacer, they said that would be good for doing some light filling work. But the black I got was gloss. Not sure how that will look since the bumper black is very flat. I wanted satin, all out. Any recommendations on where else to go (car parts stores) or lowes, etc, and what kind to get. I want to get something that will look good and last, so I don't mind paying for good stuff.
    What kind of paint should I use for the radiator? I read a writeup that said bbq paint, but it wasn't very dark black. I want dark, as my metal is perf'd aluminum that's powdercoated black.
    And what's best for sanding. I was going to run 100 grit, 240, then 400, then I have some ultra fine scotch brite pads. While I do want it satin, I want it dead smooth. I'm going to do this non bondo style, abs filler only.
    Beyond the color on the grille, should I put a satin clear over it? Might it be better to get a flat black and clear coat it? I have no idea.
    How long should I wait in between coats (primer, main) and how many coats. I was figuring 3 coats of main, primer, no idea. Scotch brite rub down between?
    Alot of the write ups assume basic painting knowhow, and I don't have it. But I am meticulous, I want to do the best job I can.
    I think that's it for now. Doing this tonight, starting it I hope, if I can run out and get the rest of my work done, speaking of.... hi ho silver! I mean mag grey.
  2. Sep 4, 2009 at 2:44 PM
    paintdiddy
    paintdiddy Machine gun shits
    shithead
    nj and not from "the jersey shore"
    silver bullet
    take your time between coats.depending on temp.the coats should be tacky to dry before the next coat
  3. Sep 4, 2009 at 2:53 PM
    1BlkT
    1BlkT Mod'n on a Budget
    Ty
    90603
    2006 Black Sport Double Cab
    Allied 4'' Spindles, Sway A Way 2.5 Coilovers, Donahoe Remote Reservoir Shocks w/ Deaver 11Pack Leafs, Goodyear Duratrac 285's, Pro Comp Series 8128, Recessed Grill w/Hella 500's behind, Tint, Black TRD Skid Plate, Debadged, Tailgate Hose Clamp, Weathertech Mats, Aero Turbine 2525XL Exhaust, Volant Intake, RETRO'D Headlights by Yosh2000
    I did a lot of wet sanding towards the end and then even did a little between coats of primer using 1000 grit. Might not have been necessary but it did come out super smooth. Then again I don't have any painting know how either so I was just making it up as I went lol
  4. Sep 5, 2009 at 9:10 AM
    T0LLPHR33
    T0LLPHR33 Well-Known Member
    S1N C1TY...(from Hilo, HI)...
    BSP TRD Off-Road
    APR X-1 | TRD CAI w/Clear Cover | TRD Short Shifter w/ TRD "RED" Shift Knob | SGII w/Blendmount| Snugtop SL w/KeyLess Entry | 5% Tint | Pop-n-Lock | Bosch Icon WB | S2K Antenna | HRM | LS 8K Projectors w/BSP HLM & 8K Fogs w/FLM | Debadged |Tinted Tails | Black Weathertechs | MX RGM & RBM | Optima Red Top 35 | Gatorback Belt |
    this is 1 of my favorite mods that I have done for the truck...
    all I can say bro is take your time...its very tedious and time consuming but once your done the look and stance of the front end is straight up TITS...
  5. Sep 5, 2009 at 9:13 AM
    EricT
    Arizona
    Thanks. Starting this today, hoping I can add in a couple of conveniences and improve upon the abs method a little. I'll post more about that later.
    Nice job on the lower bumper well there tophr!
  6. Sep 5, 2009 at 9:16 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Use a good amount of bondo to build up the sides, and shape it with some 60 grit paper. That way, you eliminate any trace of where the original grill was cut out. I use 60 grit, 150, 220 and 400. :)
  7. Sep 5, 2009 at 10:56 AM
    EricT
    Arizona
    Thanks chris, I got a ton of sandpaper from lowes last night.
    So I moved my horns first in prep for shooting the radiator black - how exactly are you guys moving that thermal sensor back up front? Splicing into the wire and adding more wire, then insulating the run back?
  8. Sep 5, 2009 at 11:42 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Flipping it upside down and separating it from the horns will give plenty of slack to mount it in the factory spot.
  9. Sep 5, 2009 at 11:47 AM
    T0LLPHR33
    BSP TRD Off-Road
    I didn't flip mine upside down but I did separate it from the factory wiring that is shared with the horns...
    my sensor is in the OEM location while my horns are here...
    where did the horns go?
    there they are...lol (BTW...this picture was shot prior to separating the horn and temp sensor module...if you look closely you can see the temp sensor zip tied just to the right of the horns...)
