driveshaft spacer question
Old 09-08-2009, 11:29 PM   #1
08pretaco [OP] 08pretaco is offline
Almost there
08pretaco is one of the sharper tools in the shed08pretaco is one of the sharper tools in the shed08pretaco is one of the sharper tools in the shed08pretaco is one of the sharper tools in the shed08pretaco is one of the sharper tools in the shed08pretaco is one of the sharper tools in the shed08pretaco is one of the sharper tools in the shed08pretaco is one of the sharper tools in the shed08pretaco is one of the sharper tools in the shed08pretaco is one of the sharper tools in the shed08pretaco is one of the sharper tools in the shed
08pretaco's Avatar
08pretaco's Tacoma Gallery
so i made my own, pic below. the bolt barely goes above the nut up top and i was curious if you guys think i should get a longer bolt or would that be ok to drive with? i dont want those 2 bolts coming loose then having my driveshaft fall from the middle
Old 09-08-2009, 11:39 PM   #2
Taco love in East Van
Canadianboy has a spectacular aura aboutCanadianboy has a spectacular aura aboutCanadianboy has a spectacular aura about
Canadianboy's Avatar
Canadianboy's Tacoma Gallery
The big question is, did it work??? I'm assuming you had some vibrations? About the bolt, I would get a longer one. If it was me, everytime I was driving my truck, all I would think about is that bolt and how I half-assed it and imagine the driveshaft falling out.
Old 09-08-2009, 11:43 PM   #3
Almost there
08pretaco's Avatar
helllz ya it worked like a charm. piece of aluminum about .34" and just put it in there and took it for a drive, no vibrations whatsoever! so happy haha and it cost me nothing. so should i just go to home depot and get a bolt from them or what? and do i just take in the one i got on there now?
Old 09-09-2009, 12:05 AM   #4
RelentlessTaco's Avatar
I'd want to get a harder bolt than the standard hardware you buy, I'd make sure to get grade 8. As for how, just bring the ratchet/socket with ya and crawl under and remove it once you're in the parking lot if you dont know what thread and length to get. Just dont forget to reinstall after you buy the new bolts
Im getting a decent drivetrain shudder lately so i think im gonna go and do this when I get a chance
Old 09-09-2009, 09:04 AM   #5
Almost there
08pretaco's Avatar
its really easy to do. i just got some aluminum make it into a square. the hole is bigger than a 3/8" but if you use a 3/8" drill then you can self tap the screw into that which will thread your spacer and make it a really strong connection between the whole setup.
relentlesstaco you wouldnt know off the top of your head the thread would you lol
Old 09-09-2009, 09:09 AM   #6
nad nad is offline
mmmm tacos!
nad is one of the sharper tools in the shednad is one of the sharper tools in the shednad is one of the sharper tools in the shednad is one of the sharper tools in the shednad is one of the sharper tools in the shednad is one of the sharper tools in the shednad is one of the sharper tools in the shednad is one of the sharper tools in the shednad is one of the sharper tools in the shednad is one of the sharper tools in the shednad is one of the sharper tools in the shed
nad's Avatar
nad's Tacoma Gallery
I really like what you have done and am probably going to do this myself
Old 09-09-2009, 09:22 AM   #7
:POOPCORN:
98tacoma27's Avatar
Marines:
98tacoma27's Tacoma Gallery
If your hole is 3/8, you can use a 3/8-16 grade 8 bolt. I would suggest either a locking nut or a locking washer also. These can all be found at your local hardware store.
The metric equivalent would be a M10 x 1.5.
Threading the spacer doen't not make a stronger connection.
Old 09-09-2009, 10:53 AM   #8
Almost there
08pretaco's Avatar
so i went to home depot got the 3/8 grade 8. tried to put it on and for some reason it doesnt want to work. im hoping the bracket tread is stronger than the bolt thread cause i might have tried to screw it in there
i measured the bolt sizes the original one of the tacoma is .386" the new one i got is .369"
what do i need to do?
Old 09-09-2009, 11:02 AM   #9
:POOPCORN:
98tacoma27's Avatar
Marines:
The bracket is threaded? You made it sound like it was a thru-hole (no threads). It's a 10mm bolt then. Measure the length and then get one a little longer. It will be in mm. Probably a pitch of 1.5
Old 09-09-2009, 11:07 AM   #10
Almost there
08pretaco's Avatar
oh im sorry. ill explain better. when you remove the bolt there is a nut that is welded to the top of the "housing". so when i remove the bolt the nuts still there. should i just chop off the nut and do my own thing or what?
and the .386" and .369" measures are over the threaded part of the bolt
Old 09-09-2009, 11:12 AM   #11
:POOPCORN:
98tacoma27's Avatar
Marines:
Ok, I got you now. Two options:
1. Toyotas are metric. The bolt with either be a M10 x 1.25 or M10 x 1.5. You can get the right bolt only longer.
2. Drill the hole out and use washers and a nut and a longer bolt (standard or metric) I would recommend staying metric.
Old 09-09-2009, 11:18 AM   #12
Almost there
08pretaco's Avatar
thank you very very much. unfortunately i dont have time right now so ill go back tonight..
you think for the time being id be ok to drive. i carry the wrench and size with me everywhere. iv driven about 50 miles so far and it hasnt come loose yet at all and its on there pretty good
Old 09-09-2009, 11:20 AM   #13
:POOPCORN:
98tacoma27's Avatar
Marines:
It would make me nervous personally. It might be better to take the spacers out for now until you get new hardware, for safety's sake.
Old 09-09-2009, 11:41 AM   #14
Almost there
08pretaco's Avatar
ok so i found some tacoma bolts i had lying around. they look the same but longer, so i tried them. PERFECT! about a quarter inch longer, showing on the top. so happy got this done and fixed woo hoo me and all your help guys! lol
vib free which means i gotta now pay to sit in a vibrating chair
Old 09-09-2009, 11:49 AM   #15
:POOPCORN:
98tacoma27's Avatar
Marines:
LOL, congrats and nice work!
Old 09-09-2009, 11:56 AM   #16
jnolan88 is a name known to alljnolan88 is a name known to alljnolan88 is a name known to alljnolan88 is a name known to alljnolan88 is a name known to alljnolan88 is a name known to all
jnolan88's Avatar
jnolan88's Tacoma Gallery
red loctite also maybe?
Old 09-09-2009, 12:06 PM   #17
SC4333 is one of the sharper tools in the shedSC4333 is one of the sharper tools in the shedSC4333 is one of the sharper tools in the shedSC4333 is one of the sharper tools in the shedSC4333 is one of the sharper tools in the shedSC4333 is one of the sharper tools in the shedSC4333 is one of the sharper tools in the shedSC4333 is one of the sharper tools in the shedSC4333 is one of the sharper tools in the shedSC4333 is one of the sharper tools in the shedSC4333 is one of the sharper tools in the shed
SC4333's Tacoma Gallery
I would go with blue. Red is a bit overkill of this type of application. None the less, I would at the very least use a lock washer. A lock washer and some blue loctite would be ideal.
When you install the spacers, install one at a time. This will prevent misaligning the driveshafts.
Old 09-09-2009, 12:55 PM   #18
Almost there
08pretaco's Avatar
im buying some blue also cause iv got to replace some tranny bolts also that i lost so ya def use some blue.
what do you mean one at a time. i loosed one side put it on tightened it. then loosened the other side and put that on and tightened it.. is that what you mean?
Old 09-09-2009, 03:44 PM   #19
Yep, exactly what I meant.
Driveshaft Spacer 650H1 2nd Gen. Tacomas 12 09-28-2013 03:53 AM
Rear Driveshaft Question bellassaiw10 1st Gen. Tacomas 9 01-03-2012 09:12 PM
OME Driveshaft spacer kit/ rear axle shims/ weathertech lens protectors NewMexiTaco Buy / Sell / Trade 8 11-23-2011 11:02 PM
5 lug driveshaft question? bills yota 2wpeel 5 Lug 7 07-16-2011 12:34 AM
Question about about driveshaft tacoman68 Long Travel Suspension 3 01-23-2011 09:05 PM
