Most cost effective way to get 3" lift and 33s
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Doug88, Oct 4, 2009.
  1. Oct 4, 2009 at 5:42 PM
    #21
    Doug88
    Doug88 [OP] Well-Known Member
    Ok if I go with this kit What coil should I go with? 884? 885?
  2. Oct 4, 2009 at 5:42 PM
    #22
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    884's AND OME n140s shocks
  3. Oct 4, 2009 at 5:43 PM
    #23
    yosh2000
    yosh2000 Well-Known Member
    CO
    '17 Tundra CM 5.7
    do you want the most cost effective, or you want a decent lift?
    cost effective: daystar spacer lift
    decent (while still cost effective): bils 5100 from sonny at downsouthmotorsports.com
  4. Oct 4, 2009 at 5:47 PM
    #24
    Doug88
    so with the $182 front bils I can fit 33's
  5. Oct 4, 2009 at 5:48 PM
    #25
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    With minor rubbing, but yes. ;)
  6. Oct 4, 2009 at 5:49 PM
    #26
    Doug88
  7. Oct 4, 2009 at 5:51 PM
    #27
    Anathollo
    Anathollo www.saveadane.org
    Houston
    07 Tacoma TRD Sport
    Icon coilovers, Rear Fox Resi-shocks, 285/70/17 Toyo A/T's, Touchscreen JVC Headunit, Custom Rhino-lined sub box, Rocksford Fosgate components and Dual Rockford Fosgate 10" shallow subs, Pioneer and Rocksford Fosgate amps, 1250 watts total, Autometer Volt and Trans gauges with Lotek A-pillar, K&N Drop-in filter, WO Seat covers, Tint, NST WP pulley, Hi-lift jack, Diff breather mod, horn relocation mod, extra "D" rings, de-pinstriped, carrier bearing drop, Rear backup 886 bulbs, Camburg UCA's, AMW Catch can, BHLM, OME Dakars with AAL, Procomp 7089's, Front single hoop Demello bumper, Superwinch Tiger Shark 9500, Amsteel 3/8th synthetic line
    The Billy's will not give you the full 3" of lift. Where as the OME kit with the top plate spacers will.
    But also, if you buy this OME kit on the link above, you also have to purchase the OME shocks that go with it.
  8. Oct 4, 2009 at 5:54 PM
    #28
    Incognito
    VA
    I'd go with the lift from Toyteclifts. But nonetheless, Billys are still a nice lift, and a whole lot better than spacers.
    If you purchase the 884 coils, you won't need the OME shocks. ;) The 885's and 886's will require the shocks, but not the 884's. Also, since the OP is a regular cab, 884's will be fine for him. :)
  9. Oct 4, 2009 at 6:01 PM
    #29
    Doug88
    so with the bils I can fit 31"s?
  10. Oct 4, 2009 at 6:02 PM
    #30
    Incognito
    VA
    You can fit up to 33's with Billys, with some minor trimming.
  11. Oct 4, 2009 at 6:06 PM
    #31
    Doug88
    do I need AAL
  12. Oct 4, 2009 at 6:09 PM
    #32
    Incognito
    VA
    You don't NEED it, but it will look more level than without it. ;)
    Without it, it will look like you are constantly hauling sand bags back there. That being said, I'd definitely get the AAL.
  13. Oct 4, 2009 at 6:11 PM
    #33
    jfr02
    jfr02 Well-Known Member
    2012 dcsb 6spd sport
  14. Oct 4, 2009 at 6:11 PM
    #34
    Doug88
    but I dont need the AAL with this lift ???
  15. Oct 4, 2009 at 6:14 PM
    #35
    Incognito
    VA
    That comes with the AAL. The long flat piece is the AAL (Add a leaf). So you're all set if you order that kit. ;)
  16. Oct 4, 2009 at 6:25 PM
    #36
    InfidelTaco
    InfidelTaco No better friend,No worse enemy...
    G
    PNW
    Prerunner
    AFE, Fox, Built Rights, Moog, SpiderTrax, Icon progressive, Grabbers
    Haha! dont do it. im running these and cant wait to get out of them. Billy's from Sonny at DownSouth is a better way to go if ur thinkin spacers.
  17. Oct 4, 2009 at 7:25 PM
    #37
    yosh2000
    CO
    '17 Tundra CM 5.7
    here is my truck w/ bils at 2.5" and TSB leafs (NO AAL), nearly level. so you really dont need the rear AAL if your worried about money right now.
    i suggested the bils because many people have had the OME coils settle on them, giving them 2.5" or less anyways. yes, at first you will have 3" (maybe a tad more), but it will eventually settle down a few months later. also, you really dont want more than 2.5" any ways for alignment, tire wear, and handling reasons.
    also, if your going to get the bils upfront, i suggest you might as well get all four shocks from sonny, will make a big difference in the way your truck handles.
  18. Oct 4, 2009 at 8:01 PM
    #38
    tacoma89
    tacoma89 Money Pit
    Chase
    Richmond, Va
    08 sport dc lb
    Check build in sig.
    ya that one comes with aal's
  19. Oct 4, 2009 at 9:25 PM
    #39
    cko
    cko Well-Known Member
    NoVa
    '09 Timberland Mica DC/LB
    I've heard a couple different things, so I might as well ask. Is the front diff. drop in the OME kit from Toytec really necessary? I've heard numerous people say they run without it, yet some insist it's necessary. Opinions?
  20. Oct 5, 2009 at 7:54 AM
    #40
    Doug88
    ok im ordering this kit should I get the 884 coils? I heard the front sometimes sags with the 884's
