16 inch rims with a 6 inch lift kit
Old 10-06-2009, 10:24 PM   #1
kinkrider101 is one of the sharper tools in the shedkinkrider101 is one of the sharper tools in the shedkinkrider101 is one of the sharper tools in the shedkinkrider101 is one of the sharper tools in the shedkinkrider101 is one of the sharper tools in the shedkinkrider101 is one of the sharper tools in the shedkinkrider101 is one of the sharper tools in the shedkinkrider101 is one of the sharper tools in the shedkinkrider101 is one of the sharper tools in the shedkinkrider101 is one of the sharper tools in the shedkinkrider101 is one of the sharper tools in the shed
kinkrider101's Tacoma Gallery
Unhappy 16 inch rims with a 6 inch lift kit
why cant you run 16 inch rims with a 6 inch lift kit??
Old 10-06-2009, 10:39 PM   #3
i heard that you cannot
Old 10-06-2009, 10:40 PM   #4
wareagle5693 is one of the sharper tools in the shedwareagle5693 is one of the sharper tools in the shedwareagle5693 is one of the sharper tools in the shedwareagle5693 is one of the sharper tools in the shedwareagle5693 is one of the sharper tools in the shedwareagle5693 is one of the sharper tools in the shedwareagle5693 is one of the sharper tools in the shedwareagle5693 is one of the sharper tools in the shedwareagle5693 is one of the sharper tools in the shedwareagle5693 is one of the sharper tools in the shedwareagle5693 is one of the sharper tools in the shed
wareagle5693's Avatar
wareagle5693's Tacoma Gallery
Send a message via AIM to wareagle5693
the amount of lift, shouldn't effect the wheels... i mean you COULD run stock 265/75/16s with the 6 inch lift.
Old 10-06-2009, 10:42 PM   #5
ok thanks
Old 10-06-2009, 10:42 PM   #6
Firefighter160 is one of the sharper tools in the shedFirefighter160 is one of the sharper tools in the shedFirefighter160 is one of the sharper tools in the shedFirefighter160 is one of the sharper tools in the shedFirefighter160 is one of the sharper tools in the shedFirefighter160 is one of the sharper tools in the shedFirefighter160 is one of the sharper tools in the shedFirefighter160 is one of the sharper tools in the shedFirefighter160 is one of the sharper tools in the shedFirefighter160 is one of the sharper tools in the shedFirefighter160 is one of the sharper tools in the shed
Firefighter160's Avatar
Law Enforcement:
Firefighter160's Tacoma Gallery
Yea the wheel diameter should not effect the lift size.
Old 10-06-2009, 10:52 PM   #7
Can the pro comp 6 inch go on the 2010 taco?
Old 10-06-2009, 11:08 PM   #9
RelentlessTaco's Avatar
I think the new lift knuckles provided with the 6" lifts make it necessary to run a 17"+ wheel.
Old 10-06-2009, 11:10 PM   #10
Hmm. I'll have to look into that Eric. But I thought that you could still run the 16" wheels with the 6" Lift.
Old 10-06-2009, 11:11 PM   #11
chris4x4's Avatar
chris4x4's Tacoma Gallery
Correct. The spindles will interfere with wheels smaller than 17"
Old 10-06-2009, 11:17 PM   #12
Thanks for the backup Chris
Old 10-06-2009, 11:18 PM   #13
chris4x4's Avatar
Old 10-06-2009, 11:36 PM   #14
HOSS454 is on a distinguished road
HOSS454's Tacoma Gallery
my friend runs 16" rims with his 6" pro comp stage 1 lift... he runs 16x10 rock crawlers with a 4.5" bs and a 2" wheel spacer... i know it probably isnʻt really safe but he has done it...
Old 10-06-2009, 11:45 PM   #15
toku58 is one of the sharper tools in the shedtoku58 is one of the sharper tools in the shedtoku58 is one of the sharper tools in the shedtoku58 is one of the sharper tools in the shedtoku58 is one of the sharper tools in the shedtoku58 is one of the sharper tools in the shedtoku58 is one of the sharper tools in the shedtoku58 is one of the sharper tools in the shedtoku58 is one of the sharper tools in the shedtoku58 is one of the sharper tools in the shedtoku58 is one of the sharper tools in the shed
toku58's Avatar
toku58's Tacoma Gallery
The 6" lift will require that you install your steering heim joint on top, rather than below the mounting point of the spindle.
This is why you need the additional clearance of the 17" wheels. (Also like Chris stated the spindles are designed a bit differently.)
But yes! If you choose to run spacers then you can use the 16" wheels.
Old 10-07-2009, 01:08 AM   #16
BlueXenon is on a distinguished road
BlueXenon's Avatar
BlueXenon's Tacoma Gallery
The money you spend on spacers for your 16's you might as well get some new wheels and make the truck look mean as hell.
Old 10-07-2009, 06:43 PM   #17
16" Wheels, with 35s WOULD make your truck look mean as hell.
Old 10-07-2009, 06:54 PM   #18
thanks for all your feedback
Old 07-28-2013, 12:19 PM   #19
Cwarner272 is on a distinguished road
Cwarner272's Avatar
Cwarner272's Tacoma Gallery
Is that true for all 6" suspension lift kits? Or just the pro comp?
Old 03-31-2014, 07:51 AM   #20
Cwarner272's Avatar
I have 6" rough country suspension lift with 16" rims 4.5 backspace they fit without spacers. I got 33's now. Getting 35's this week
3 Inch TOYTEC Ultimate Lift OR RCD 4.5 Inch Lift Kit? FXHO 2nd Gen. Tacomas 17 08-08-2013 01:37 PM
16 inch rims SPOTSONTROUT 1st Gen. Tacomas 2 07-20-2011 07:43 PM
16 inch rims Jm1hawk Buy / Sell / Trade 0 09-17-2010 10:05 PM
I need 16 inch RIMS! caleb337 Wheels & Tires 18 06-10-2010 07:26 PM
18x9 inch rims with a -12 offset. What size tires without lift kit? DeeKay21 2nd Gen. Tacomas 2 11-12-2008 07:32 AM
