Tacoma World Forums mjp2's 2006 Tacoma
Register Site Information Glossary Calendar Search Today's Posts Mark Forums Read
05 Transmission drip
Old 02-02-2008, 10:41 AM   #1
lucktoday is on a distinguished road
lucktoday's Tacoma Gallery
Now that my warranty has run out I find a spot on the driveway. It appears that my transmission has a slight drip somewhere at the rear by the U joint. Any ideas on what it could be. I'd rather fix it myself. I really pissed that I got a 2 1/2 year old truck with this kind of issue. I have about 38K on it so I'm figuring Toyota isn't going to fix it for me. Plus I can't believe they set it up so you can't even check the fluid level. I was really enjoying the truck up until now.
Old 02-02-2008, 12:11 PM   #2
concrete jedi is a jewel in the roughconcrete jedi is a jewel in the roughconcrete jedi is a jewel in the rough
concrete jedi's Avatar
Army: Shit deflector
concrete jedi's Tacoma Gallery
Sounds like a rear seal, how handy are you ? Depending on your tools and garage/place to do the work, you might be money ahead to have it repaired. This is the first I've heard of a transmission leak, do go off road ? maybe some damage and not a factory issue ? do you have a vibration when at highway speeds ? maybe a driveshaft needs balancing and has put some excessive wear on the bearing ? Often it is wise to look at what caused the issue, and not just repair the issue at hand.
Old 02-02-2008, 01:55 PM   #3
It must be a rear seal. However I never go off road and it drives real smooth, I don't think it's much of a drip but with out a dip stick I can't really keep an eye on it.
Old 02-02-2008, 02:28 PM   #4
stick_my_beef_in_ur_taco is on a distinguished road
stick_my_beef_in_ur_taco's Avatar
stick_my_beef_in_ur_taco's Tacoma Gallery
well man deffinitly sounds like a rear seal to me i worked for mr. transmission for 2 yrs and if it is leaking around the yoke then it is a real easy cheap fix.
Old 02-02-2008, 04:44 PM   #5
45longcolt will become famous soon enough
45longcolt's Avatar
45longcolt's Tacoma Gallery
Look for spots on your tailgate that look like oil spots in the dust. That's a clear sign of a seal leaking. As others have stated, yes it is annoying on such a low mileage truck but it is not real expensive to fix right on the vehicle. Look at it this way, you get your oil changed out which is a good thing. I'd make sure the shop you use knows the proper fluid replacing procedures and uses the correct fluid. These tranny's are special and the correct Toyota fluid is essential to proper operation. Might want to check with the Dealership on this one.
Old 02-02-2008, 06:01 PM   #6
well i deffinitly agree with the last guy on that 1 what i would do is take it in and have it done right regardless you are going to have to take it in for the fluid change/ fill up and it isnt a expensive job no more then a hrs labour
Old 02-03-2008, 02:21 PM   #7
dirthawker1313 is on a distinguished road
dirthawker1313's Avatar
dirthawker1313's Tacoma Gallery
its prolly your rear output shaft seal. i have an 07 that started leaking at 6300 miles..it took 3 times at the dealer to get it to stop. if you have any mechanical ability you should be able to do it yourself.
__________________
07 tacoma Dcab
1999chevy tahoe lt
1951 ford shoebox lowered 8"in rear 6"in front with the original flathead v8
Display Modes
6 speed transmission BrianPK 1st Gen. Tacomas 2 11-21-2007 08:35 PM
Auto Transmission Usage Spacedude Technical Chat 1 09-18-2007 02:26 PM
AT Transmission Filter Kit agapedisciple Technical Chat 3 09-18-2007 02:10 PM
05 and up Transmission servicing viprbomber Technical Chat 4 07-07-2007 07:48 PM
05 transmission question scott c 2nd Gen. Tacomas 6 12-12-2006 05:30 AM
Copyright © 2008 Tacoma Forum
