Washing engine compartment?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Reaper22, Oct 18, 2009.
  1. Oct 18, 2009 at 4:59 AM
    Reaper22
    Reaper22 [OP] Well-Known Member
    Palmyra Missouri
    SR5 Tacoma
    Radient Red, Red Grille, Debadge'd, Blacken'd Headlights, DTRL's, Cruise Control, Fog Lights, 2 1\2" suspension lift, 285\75\16 Nitto Dune Grapplers, Pioneer Premier DEH-P510UB stereo, Pioneer 3 way fronts with factory tweeters & Kenwood tweeters, Kenwood truck boxes behide seats with 8" subs in each, Wet suit like tacoma seat covers
    Is there do's and dont's to washing the engine compartment??
  2. Oct 18, 2009 at 5:12 AM
    steviestyles
    steviestyles The "Search" tab is your friend!!
    Steve
    Colorado Springs
    07 DC 4x4 TRD Off Road
    Bone Stock
    I've done so many times without issue. Check to make sure the oil dipstick, brake fluid and power steering fluid caps are on tight and use the low pressure nozzle or stand further back from the engine bay if using a higher pressure setting. If you do this, you should be fine.
  3. Oct 18, 2009 at 5:30 AM
    coppert
    coppert Mall Krawler
    Travis
    916
  4. Oct 18, 2009 at 6:30 AM
    saf023
    saf023 Well-Known Member
    East Coast
    2nd Gen TRD Sport DCSB 4X4
    I've been using the old plain Dawn dishwashing soap (without any bleach) on the engine of all my cars for years. That, some warm water and a tire brush, to get into tight spaces, keeps things clean. Cold water would probably do just as well.
    I don't have any pictures of the Tacoma but I'm thinking it does a fairly nice job on my 19 year old Corvette.
  5. Oct 18, 2009 at 6:46 AM
    95SLE
    95SLE Starting to get cold outside
    Tom
    Maryland
    09 RWD Access Cab
    Custom XM Install, Window Tint, Intermittant Wiper Install, AVS Bug Deflector, Bed Mat, TRS FX-R retrofits, CIBIE fog and spot lamps, PIAA 510 lamps, Acess LE cover, Weathertech Digital floorr mats, LED interior lighting, Pioneer AVH-2300BT HU, Boston Acoustics speakers, JL Audio Amp, shorty antenna, leather wrap steering wheel cover, Viper security system.
    You might want to pick up a pair of microfiber gloves. Makes cleaning cables and hard to reach areas very easy. Put on thin latex gloves first to protect your skin from chemicles.
  6. Oct 18, 2009 at 6:49 AM
    neslerrah
    neslerrah Taco lovin'
    Harrelsen
    Tucson
    5 lug BEAST!
    Secondary air filter removed, elbow mod, BFG T/A KO (31x10.5R15), 15" American Racing Mojaves, BHLM, Dome Light MOD (Blue), Pioneer headunit, Sockmonkey 'TACOMA' Decals, Readylift 5-lug SST, Rear Shocks - Bilstein TRD, Dynomax Super Turbo #17748, DDM Slim Ballast HID Kit H4 Hi/Lo -35W 6000K in headlights, Apexcone Raptor HID Kit H3 - 35W 6000K in Hella 500s, aFe CAI #51-10762, WeatherTech Floorliner, 200W Smart AC Inverter
    I use the engine cleaner at car wash, and then just rinse it out.
  7. Oct 18, 2009 at 7:29 AM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    I just sprayed some all purpose cleaner around and hosed it off. Came out like new. I was a little worried about it starting wet but no problem. I guess those days are over. I keep reading about Dawn in a lot of posts for detailing. I'll have to remember to try it.
  8. Oct 18, 2009 at 12:38 PM
    Reaper22
    Palmyra Missouri
    SR5 Tacoma
    Ok, Did as you suggested, I live on a short gravel road so my engine will get dusty, So I took my wifes 05 Jeep liberty up to the car wash in a near by town and left it running and washed it not getting too close, I also just bought a 200mph blower (sears) and took it with me and blew it off real good, drove home and it looks new again.. But I'm thinking if I stay on top of the dust with that blower I may not have to spray it or as often..
    Again thanks to all for your ideas and support...
  9. Oct 18, 2009 at 12:51 PM
    krimson
    krimson Nothin
    TRD Off Road
    OME 3" lift with 885 coils. OME Shocks with TSB 1.5 AAL. 285/75/16 KM2s. XD Hoss 16" wheels. DDM Tuning 6000K HIDs, H10 6000K Fogs. BHLM. Debaged. 20% tint on front windows.
    you should cover your fuse box with tin foil to be on the safe side.
  10. Oct 18, 2009 at 4:17 PM
    george3
    New Jersey
    As far as I know my fuse box is left of the steering wheel on the inside of the cab behind a little change/glove compartment. I have a 2.7.
  11. Oct 18, 2009 at 4:59 PM
    Plain Jane Taco
    Plain Jane Taco ALL human beings deserve equal treatment
    USA
    Looks to be a Mercury Marine/Lotus tuned 5.7....a.k.a. the ZR1. Yes? No?
  12. Oct 18, 2009 at 5:16 PM
    86ceeten
    86ceeten Well-Known Member
    Brian
    NW Florida
    08 TRD Off Road PreRunner
    Limo tint, 18x10 Diamo Karat, Toyo 285-60's, Rear TSB, 5100's all around, front at 2.5", Debadged, Sound System (evolving)
    I usually spray it down with diluted simple green let it sit for a few minutes then rinse it off. Really soap the radiator/AC condensor real good to remove the bugs. Then I use car wash soap and an old wash mitt and get what I can reach. I do it every couple of washes. Still looks new!
  13. Oct 18, 2009 at 7:08 PM
    saf023
    East Coast
    Yes. Lotus designed, Mercury Marine purpose built racing engine. Standard on the 1990 to 1995 Corvette ZR-1.:thumbsup:
  14. Oct 18, 2009 at 7:16 PM
    mgrande
    mgrande iKill
    Raleigh
    2011 TRD off road
    Kings, AP 3" leaf pack, timbrens front and rear, TC UCA's, pro comp 7189's, baja ATZ's, CBI sliders and rear, relentless front, dynomax catback
    You can just get some engine degreaser. Maybe alittle expensive, my brother owns a detailing company so when I'm home I just get to use all his chemicals for free :p
