Tekonsha Prodigy Brake Control
Old 10-19-2009, 05:37 PM   #1
K5423 [OP] K5423 is offline
Banned
K5423 will become famous soon enoughK5423 will become famous soon enough
K5423's Tacoma Gallery
Just ordered one and for the life of me can't decide on a good spot to mount it.Drilling holes in the dash of my 2010,just the thought makes me cringe.Any innovative ideas on a good mounting(maybe with no drilling)spot for this controller?
Old 10-19-2009, 05:46 PM   #2
senile member
Tacoyota is one of the sharper tools in the shedTacoyota is one of the sharper tools in the shedTacoyota is one of the sharper tools in the shedTacoyota is one of the sharper tools in the shedTacoyota is one of the sharper tools in the shedTacoyota is one of the sharper tools in the shedTacoyota is one of the sharper tools in the shedTacoyota is one of the sharper tools in the shedTacoyota is one of the sharper tools in the shedTacoyota is one of the sharper tools in the shedTacoyota is one of the sharper tools in the shed
Tacoyota's Avatar
Navy: Ex Navy. subs
Tacoyota's Tacoma Gallery
could it be placed in the little bin below and to the right of the steering wheel? On my truck (manual) the parking brake goes there, looks wide enough, dunno 'bout the depth.
Old 10-19-2009, 08:37 PM   #3
bdo bdo is offline
bdo is on a distinguished road
bdo's Tacoma Gallery
I put mine in the little tray to the right. I have an auto. I put the bracket on the bottom of the tray, so the ears face up. Then I mounted it with the tray pulled out, drilled enough holes to cut access for the harness in back, and that was it. The screws that came with it stick out a little though, so you can grind them down, get a washer or whatever. It works great in this position..
My reasoning is I can at least get a new tray for relatively cheap if I ever need to put it back to stock!
-brad
Old 10-21-2009, 10:19 AM   #4
yhiki is on a distinguished road
Army: sp5
yhiki's Tacoma Gallery
This is where I mounted mine. Unit was mounted ofset in the bracket so controler is level.
[/url][/IMG]
Old 10-21-2009, 12:53 PM   #5
Custom User Title
Zac808 is one of the sharper tools in the shedZac808 is one of the sharper tools in the shedZac808 is one of the sharper tools in the shedZac808 is one of the sharper tools in the shedZac808 is one of the sharper tools in the shedZac808 is one of the sharper tools in the shedZac808 is one of the sharper tools in the shedZac808 is one of the sharper tools in the shedZac808 is one of the sharper tools in the shedZac808 is one of the sharper tools in the shedZac808 is one of the sharper tools in the shed
Zac808's Avatar
Air Force: CSAR
Zac808's Tacoma Gallery
I used heavy duty velcro above the cup holders. I take it on and off depending on which trailer I'm towing.
Old 10-21-2009, 05:22 PM   #6
Banned
[/IMG]
Please post pic again.
Old 10-21-2009, 05:28 PM   #7
Those are not my pants
dw77x is on a distinguished road
dw77x's Avatar
dw77x's Tacoma Gallery
I screwed mine onto the little cubby where the park brake is on a manual. I hate to drill holes but at least it is a easily replaceable part.
Old 10-21-2009, 06:32 PM   #8
Army: sp5
repost of pic
Old 10-21-2009, 06:33 PM   #9
dw77x's Avatar
[QUOTE=yhiki;1047992]repost of pic
yup x2 on that same setup!
Old 10-21-2009, 07:16 PM   #10
Banned
repost of pic
I have a 6 speed with the pull out parking brake.I'm thinking i'll mount it under the steering wheel........maybe.Shows up at my doorstep tomorrow.
Old 10-24-2009, 03:44 PM   #11
Banned
Well........here it is installed with the only logical place I could think of:
Old 10-26-2009, 05:19 AM   #12
rachunter will become famous soon enough
rachunter's Tacoma Gallery
I mounted mine on the little door that swings open on the left. It is very easy to unhook and take out when not in use.
Old 10-26-2009, 05:55 PM   #13
Banned
Anyone notice after installing the prodigy that your brake characteristics changed? My brakes were very touch sensitive,after I plugged in the prodigy and with no trailer hooked up now I have to press down real hard on the pedal to stop.I unplugged the controller and still the same.It's like the computer changed how sensitive my brake pedal is now.Does this make sense or am I going insane?
Old 10-27-2009, 04:20 AM   #14
I have not noticed any change and I have been using mine for about 3 years now.
Old 10-27-2009, 06:17 AM   #15
msaniac is a glorious beacon of lightmsaniac is a glorious beacon of lightmsaniac is a glorious beacon of lightmsaniac is a glorious beacon of lightmsaniac is a glorious beacon of light
msaniac's Tacoma Gallery
I mounted mine in the little recess underneath the cigarette lighters. I haven't had any trouble with it. It is a P3 though. I decided to put it here so I can see it easily as well as reach it. If I were to put it where the others were I would hit it with my knees due to my driving style.
Old 04-14-2010, 06:08 PM   #16
roy826 will become famous soon enoughroy826 will become famous soon enough
roy826's Avatar
roy826's Tacoma Gallery
Finally got around to installing my brake controller. I took a slightly different approach. I still used the bin to the right since it can be easily replaced. Only I felt it was a bad angle according to the instructions. So I used a rubber shim on the left side facing forward to bring the device horizontal with the front of the truck. Not 100% horizontal but better than simply mounting the thing flush with the panel. I also used the pocket. I like the idea of removing it when not in use and plus a thief won't be eying it. The trucks plug was easy to locate. The wiring was super easy. I don't have a trailer yet that uses trailer brakes but hopefully that will change come this weekend when I go look at a 18' Coachmen blast 150 toy hauler I plan on buying.
No interference with my leg as far as I can tell. now if I were 5' tall and had the seat all the way up yes it might become an issue. BTW that is a GSXR rubber fairing grommet I used for a spacer. Perfect fit.
Old 04-14-2010, 06:26 PM   #17
diggerbuzz will become famous soon enoughdiggerbuzz will become famous soon enough
diggerbuzz's Tacoma Gallery
I have a P3 and I mounted it in the cubby right of the wheel also. i had to trim the removable they though. I priced the tray in case i wanted to replace it later it is around $30 at the dealership so not a big deal and drilled up into the dash where you will never see the holes unless you are laying on your back looking up.
Old 06-19-2012, 09:29 PM   #18
SkiprJohn is on a distinguished road
Navy: Retired Command Master Chief
SkiprJohn's Tacoma Gallery
I have a 2000 4x4 and the only place I could seem to fit it without running into it with my long legs was where the ashtray was. I removed the ashtray and the steel bracket for the P2 bolted right up to where the ashtray was without drilling holes. I saved all the pieces from the ashtray just in case I want to return it to original.
Now I'm having a heck of a time figuring out which wire on the brake switch to tap into with the red wire from the P2. Not any room to do a test and barely enough room to pull the plug on the switch.
kind regards,
John
Old 09-28-2012, 10:05 AM   #19
DenisSeattle is on a distinguished road
DenisSeattle's Tacoma Gallery
Tekonsha Prodigy install wiring, brake sensitivity
I mounted where others did, in the tray above my right knee. My post about it has photos. Mounting it low has the advantage of not shining the bright LEDs in your eyes at night.
http://www.tacomaworld.com/forum/tow...r-install.html
And rachunter, if anything I imagined my brakes were more sensitive after the install, not less. Dirt? Water?
Old 09-28-2012, 12:51 PM   #20
badger is one of the sharper tools in the shedbadger is one of the sharper tools in the shedbadger is one of the sharper tools in the shedbadger is one of the sharper tools in the shedbadger is one of the sharper tools in the shedbadger is one of the sharper tools in the shedbadger is one of the sharper tools in the shedbadger is one of the sharper tools in the shedbadger is one of the sharper tools in the shedbadger is one of the sharper tools in the shedbadger is one of the sharper tools in the shed
badger's Tacoma Gallery
I have mounted and moved mine. It now lives between the cig lighter and power port, just far enough down to clear the shifter (6 spd). You need to be able to read the controller and also to reach the manual over ride. None of the low mounting options allowed that.
Tekonsha P3 brake controller. Can I borrow your brains? ChuckLee Towing 11 03-07-2015 07:48 PM
Tekonsha Prodigy Brake Controller roxspin72 Towing 16 12-19-2012 07:19 PM
Tekonsha P3 Electronic brake controller...Is it Good..?? Mr.Tacoma 2nd Gen. Tacomas 5 11-21-2010 03:31 PM
Prodigy brake controller jputnam Buy / Sell / Trade 0 04-19-2010 10:46 PM
Tekonsha Prodigy brake controller WVU #1 Fan Towing 11 02-04-2010 02:05 PM
