Poplock (PL5300) 2009 Tacoma with Cam -Install Tutorial
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tacoma-09, Oct 23, 2009.
  1. Jan 27, 2010 at 7:00 PM
    #41
    Tacoma-09
    Tacoma-09 [OP] Well-Known Member
    Ft Lauderdale, Florida
    09 Taco TRD Sport DC
    BTW: I'm done with my POP-LOCK - the PL5300 - Worst lock I have ever had on my Taco. I have removed it and gone back to the factory fitted handle. The pop-lock would not open all the time, it would work for a while then stop working for no reason. I re installed it, it then worked for a week then stopped working. I'm done with it.
    If anyone wants to buy mine feel free to make me a decent offer. I have all the pieces screws and everything packaged nicely back in the factory packaging sitting in my garage.
  2. Jan 28, 2010 at 12:43 PM
    #42
    doughboy
    doughboy Well-Known Member
    norcal
    2010 Tacoma TRD 4x4
    hid head lights, hid fog lights, always on fog lights, bed lights
    sorry to hear it did not work out for you after such a great post. I just ordered mine from truckalterations.
    anyway, what is the purpose of rerouting of the cable if, based on the picture, it seems to end up in the same spot ?
    thanks.
  3. Jan 28, 2010 at 12:47 PM
    #43
    Tacoma-09
    Actually it does not end up at the same spot. The factory position for the cam is on the right hand side of the handle, whereas the pop-lock location is on the left hand side of the truck, hence one needs to re-route in order to get the extra length needed by the pop-lock
  4. Jan 28, 2010 at 1:35 PM
    #44
    Veccster
    Veccster bass turds
    Eric
    Pittsburgh - The City of Champions
    2020 Pro
    My lock has been locking itself while driving. Is this what you are referring to?
  5. Jan 28, 2010 at 2:57 PM
    #45
    Tacoma-09
    Thats half of it. Yes it used to lock while I'm driving.
    1st: When I unlock it, the key would stick. (Really... These locks cant even get it right so that a key does not stick when you unlock it. I thought the lock was what Pop-Lock was all about.) Anyway the sticking key I knew about so I over looked that.
    Then the unlocking when I'm driving got a little annoying, then the "If I rattle the handle enough" it would lock or half way lock, was even more annoying. But the fact that I would go to open it and it simply did not pull the two metal rods back enough to unlock the tailgate... that is what drove me to uninstall and go back to the factory installed handle. There I would stand yanking away at the pop-lock trying to get the damn thing to open up my tailgate in the rain! this was not a pretty site.
    There was only one thing I was expecting from this lock to do. That was to lock my tailgate. It failed :(
    Now I intend to spend thew $1000.00 and get a solid cover for my truck.
  6. Feb 6, 2010 at 6:45 PM
    #46
    doughboy
    norcal
    2010 Tacoma TRD 4x4
    I am trying to install the pop n lock, and can't figure out how to remove the camera wire harness.
    I noticed in this instructions, there is no step to transfer the gasket from the old handle to the pop n lock handle.
  7. Feb 6, 2010 at 8:22 PM
    #47
    doughboy
    norcal
    2010 Tacoma TRD 4x4
    ok, I was able to get the camera harness off.
    The picture in the instructions was pointing to the left side instead of the underside. finished installing and working fine so far.
  8. Feb 26, 2010 at 3:49 PM
    #48
    Waking the Dead
    Waking the Dead Well-Known Member
    Raleigh, NC
    2010 TRD Sport DC LB Gray
    Does anyone else think that Toyota should offer some kind of lock for the tailgate anyway, since they probably know the tailgates get stolen?
  9. Mar 6, 2010 at 11:44 AM
    #49
    biketom555
    biketom555 Member
    Tom
    NW Indiana
    09 Barcelona Red SR5 4x4
    Nerf bars (TRAIL FX 56400 stainless), "Quality S" class III trailer hitch, WeatherTech Side Window Deflectors, Hellwig rear Sway Bar, WeatherTech Digital Mats (front), P&L 5300.
    Tacoma - 09
    Thank you for the great write-up/tutorial.
    I agree, after having just installed this handle 2 hours ago, I am not crazy about the way it feels...not a smooth feel like the factory handle. I'll give it some time since I do like the color match.
  10. Mar 6, 2010 at 12:05 PM
    #50
    doughboy
    norcal
    2010 Tacoma TRD 4x4
    I too experienced the problems described. Comparing to the original handle, the original has lots of grease/lubricant while the pnl looks dry. What would be a good lubricant to use? Has to be thick, like Vaseline. I think the malfunction is partly due to temperature change. The only reason I am still using it is I need the tailgate locked and there is no other replacement handle with lock.
  11. Mar 7, 2010 at 6:22 AM
    #51
    kevin46
    kevin46 Member
    Kevin
    Jayton. Texas
    2010 DC prerunner TRD
    toyota racing sport package
    great write up, Mine is ordered, due here next week. I will use this to help me. Thanks
  12. Apr 23, 2010 at 7:14 PM
    #52
    BMichel
    BMichel New Member
    Bill
    2010 Access Cab SR5
    Just what I was looking for. I just bought a 2010 and was looking for a way to secure the tailgate (w/camera). I saw the Pop & Lock but was also told of hose clamp and washers on the cable posts. Now I just need to decide if I get the standard or power lock model. Your walk through is very helpful.
  13. May 16, 2010 at 1:35 PM
    #53
    NAYo2002
    NAYo2002 Well-Known Member
    Great Falls, MT
    '09 Tacoma 4x4 TRD Off Road
    Michelin LTX A/T2, TRD Skid Plate, WeatherTech DigiFit Liners, OEM Bed Extender, OEM Bed mat, Advantage TorzaTop Trifold Tonneau, Pop & Lock PL5300
    Just got mine and installed it. Here's my review for anyone who cares. I put extra pictures up that could help some people.
    Also: There must have been an update on the PL5300 since the material I got is not flimsy at all and there doesn't appear to be any way in which it could unlock itself by the look of the design. However, I can see it auto-locking if the little spring next to the washer gets weak in the future.
  14. Aug 15, 2010 at 6:39 PM
    #54
    Derpy Derek
    Derpy Derek Well-Known Member
    Derek
    Brookings, OR
    2012 TRD Sport 4x4 DCSB
    ARB Bumper, Smittybilt X20, King suspension
    Wish it would work with the 2008 Tacoma, it looks so nice with the little backup camera built in. Exactly what I want..
  15. Aug 15, 2010 at 8:03 PM
    #55
    doughboy
    norcal
    2010 Tacoma TRD 4x4
    I found out that in case you are unable to open it no matter how hard you pull, the trick is to give the tailgate a slight push in, and while pushing it in, that handle will pull out quite easily to open the tailgate.
  16. Aug 15, 2010 at 8:25 PM
    #56
    hawkeye12
    hawkeye12 Go Pack Go!
    Bryce
    Raleigh, NC
    10 Black DC SB Tacoma TRD Sport
    Smittybilt nerf bars
    WOO HOO!!! I didnt think any other Florida Panthers fans existed on this planet!! :D
  17. Aug 15, 2010 at 9:41 PM
    #57
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    I gave you a at-ah-boy on that. I've never had a problem but a lot of people have. Hope they all read your post.:D
  18. Aug 15, 2010 at 9:50 PM
    #58
    kbx10
    kbx10 Well-Known Member
    Kyle
    Chicago
    The beginning of something big...
    Tint, Autopage Security
    Great write up! I might have a little more confidence in doing this now!
  19. Aug 15, 2010 at 10:04 PM
    #59
    El Tano
    El Tano i am the one who knocks
    Pasadena. CA
    10 Tacoma TRD sport
    Corvette homelink FRONT: 5100 Blinstein set at 0 Procomp 3" leveling kit Allpro UCA’s. REAR: Icon Multi Rate RXT Leaf Pack 5100 Blinstein. 17x9 kMC wheels 0 BS 285/70 17 Wildpeak A/T4W C range Amp research steps. and a bunch of TSB's
  20. Feb 3, 2011 at 10:20 PM
    #60
    bonsai3s
    bonsai3s Active Member
    Fresno, CA
    09 TRD, Off Road, Prerunner
    Great write-up! I'm a newbie and seriously thinking of buying the Pop and Lock for our 09 Tacoma TRD Off Road...problem is my wife purchased a chrome cover for the tailgate handle. The chrome cover was designed with the hole for the camera on the right side of the handle. Installing the Pop and Lock would move the camera to the left...making the chrome cover useless. Is there a chrome cover for the tailgate handle, with the camera on the left and Pop and Lock installed. Thanks guys.
