Functional Hood Scoops?????
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Wasatch Quad, Nov 11, 2009.
  1. Nov 11, 2009 at 7:07 PM
    Wasatch Quad
    Wasatch Quad [OP] Well-Known Member
    Has anybody turned their scoop into more than just a "hood ornament"???
    :rolleyes:
    If so lets hear about it.
  2. Nov 11, 2009 at 7:09 PM
    DanGer
    DanGer Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    No
  3. Nov 11, 2009 at 7:10 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    x2
  4. Nov 11, 2009 at 7:10 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Short Story is: Scoop sits in a low pressure, non ram portion of the air flow. It woulds pull air out of the engine bay- No increase in performance and it would allow contaminants and water into the engine bay from the top too.
    For more: search hood scoop.
  5. Nov 11, 2009 at 7:10 PM
    1337Taco
    1337Taco Well-Known Member
    Kevin
    NorCal
    2015 4X4 Manual
    It can't be functional.
  6. Nov 11, 2009 at 7:11 PM
    Wasatch Quad
    The intake was my thoughts, just not sure about possible gains.
  7. Nov 11, 2009 at 7:16 PM
    Wasatch Quad
  8. Nov 11, 2009 at 7:29 PM
    StaticFilter
    StaticFilter Well-Known Member
    Jason
    Cedar Hills, UT
    2008 Blue FJ Cruiser
    Lifted, N-Fab steps, Roof rack light bar, Grill guard, Volant Snorkel (not installed ye)
    Mines "functional" ish :)
  9. Nov 11, 2009 at 7:33 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    ..what does that mean:)
  10. Nov 11, 2009 at 7:37 PM
    badguybuster
    badguybuster Well-Known Member
    Michael
    West (by GOD) Virginia
    2016 Tacoma TRD Sport
    New truck....so nothing yet
    Is that like a fat girl saying she is wearing "Skinny" jeans?!!!???!!!!
  11. Nov 11, 2009 at 7:43 PM
    StaticFilter
    Jason
    Cedar Hills, UT
    This...
    darkyota33 likes this.
  12. Nov 11, 2009 at 7:44 PM
    ktmrider
    Junk
    oooooooo i like that
  13. Nov 11, 2009 at 9:43 PM
    BigRedToy
    BigRedToy ¯\_(ツ)_/¯
    John
    Colorado
    07 Regular Cab SR5 4x4
    I'll take 2.
  14. Nov 11, 2009 at 9:46 PM
    sandman427
    sandman427 KR FAB
    Amir
    WAY THE HELL OUT THERE, So Cal
    BAMF TACO!!
    2 ten inch kicker cvt subs, pioneer deck and alpine 1000 watt class D amp, and flowmaster exhaust, 4 inch camburg lift spindles and my coilover is adjusted to 1" (5inch total) in front and 3" All Pro leafs, KING off road racing reservoir shocks and coil-overs, KR FAB CUSTOM BUMPER with three 9" HELLA 4000 Race LIGHTS , HID headlights with rigid amber LEDs , "KR Fabrication" custom built bumper, sliders and tiregate, Full size spare with matching rim, custom bed bar with two amber off road lights, cb radio, also BHLM (thanks Ray), and debagged
    do u really notice anything..???
  15. Nov 11, 2009 at 10:05 PM
    cobracomander
    cobracomander Well-Known Member
  16. Nov 12, 2009 at 5:03 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Wont work with the Tacoma
    To be effective, a functional scoop must be located at a high-pressure area on the hood. For that reason, some functional scoops are located at the rear of the hood, near the vehicle's cowl, where the curvature of the windshield creates such a high-pressure zone, and may be placed so that their opening faces the windshield (a reversed scoop).
    The scoop will be most effective if it is either mounted high enough to clear the boundary layer (the slow-moving air that clings to the surface of a moving object) or if it is a "NACA duct," mounted below the surface and designed to draw the faster moving air outside of the boundary layer into the duct. A shallow scoop that is not a NACA duct may not admit a useful amount of air even if it is open.
    Under the hood, an effective scoop must funnel air into the engine's intake in as short and direct a path as possible, preferably through a tub or channel that is insulated against underhood heat.
    A scoop may be part of the hood, or may be part of the engine's air cleaner assembly, protruding through a hole cut into the bonnet. Such a scoop is called a shaker hood, because the scoop vibrates noticeably when the engine is running, especially under power.
