2009 Access Cab and weather techs?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BSP4x4, Nov 17, 2009.
  1. Nov 17, 2009 at 8:32 AM
    BSP4x4
    BSP4x4 [OP] Guest
    For all of you who have a 2009 AC (Manual) do the front and back weather tech's fit the 2009. I know you have to trim the drivers side to fit the clutch. What about the back set up mats getting in the way of the rear console? I thought the website says they don't fit models with a rear console.
  2. Nov 17, 2009 at 8:40 AM
    BSP4x4
    BSP4x4 [OP] Guest
    Will not fit trucks with vinyl floors.
    WeatherTech® Rear FloorLiner™
    Rear liner will not fit with optional center storage box/console.
    ^From the website
  3. Nov 17, 2009 at 9:36 AM
    BSP4x4
    BSP4x4 [OP] Guest
    anyone?
  4. Nov 17, 2009 at 9:56 AM
    jassco
    jassco Well-Known Member
    NH
    2023 TRD Offroad
    It fits only if you unbolt the rear console, place mat there and then put console back over the mat. You can also trim if needed. I removed rear console so this wasn't an issue.
    I will check again when i get home but if there are mounts there(can't recall) you can easily drill holes for the bolts into the mat.
    It looks like you can partially bolt the console in without drilling the liner.
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/27398-09-access-cab-weathertech-solution.html
