'08 rear suspension
Old 02-22-2008, 08:12 PM   #1
BLOCKADE [OP] BLOCKADE is offline
BLOCKADE will become famous soon enoughBLOCKADE will become famous soon enough
BLOCKADE's Tacoma Gallery
'08 rear suspension
I have been wondering for the last few weeks whether or not my '08 TRD Prerunner needed the rear leaf TSB. Today was the first time I really had enough weight in the bed to really test out the suspension and from what I could tell, even though it is only a three leaf set up, I had no bottoming out. I have tried to find out if they beefed up the metal by making it with a more rigid alloy but haven't been able to find any information. The part numbers are slightly different (the '08 ends with a F) so this could be the case. It really doesn't make much sense to me to just leave that 'flaw' in the newer model year.
Any body have any thoughts on this?
Old 02-22-2008, 08:27 PM   #2
My hair is all natural
lsocoee is one of the sharper tools in the shedlsocoee is one of the sharper tools in the shedlsocoee is one of the sharper tools in the shedlsocoee is one of the sharper tools in the shedlsocoee is one of the sharper tools in the shedlsocoee is one of the sharper tools in the shedlsocoee is one of the sharper tools in the shedlsocoee is one of the sharper tools in the shedlsocoee is one of the sharper tools in the shedlsocoee is one of the sharper tools in the shedlsocoee is one of the sharper tools in the shed
lsocoee's Avatar
lsocoee's Tacoma Gallery
Did you check out your clearance between the bumpstops and the frame?
How much weight did you have back there?
I think that once your suspension breaks in, you'll suffer from it more. The bottoming out isn't too harsh, so you might not notice it.
Toyota might only need to replace 40% of the springs. If they have a bunch left over, they'll probably finish using them and then change the design. The stock springs are more comfortable than the newer ones. Many people prefer a softer ride than a larger capacity.
Old 02-22-2008, 08:39 PM   #3
I don't know exact weight, it was a front end loader full of topsoil. I've had 200lbs in there before and this was definitely over 400. I will take pictures tomorrow, I have to go back and get a second load. I'll also check the clearance.
You could be right though about the newness and time making a difference. I'll keep you posted.
Old 02-22-2008, 08:59 PM   #4
lsocoee's Avatar
It really depends on the front end loader and the soil dryness. Before my tacoma, I rented a Silverado to get some sand to my house. I had him put one bucket in and then I decided that it was a rental and he should add another bucket to it. I calculated it out; the sand, which has a density greater than top soil, ended up weighing 1000 lbs per bucket.
Old 02-22-2008, 10:39 PM   #5
kjnkidd is on a distinguished road
kjnkidd's Tacoma Gallery
I'm glad you posted that. I've been reading all of these post sitting here thinking I would have to have work done on my 4 day old truck.
The most I ever carry is maybe a transmission, light lumber or a couple of gas cylinders. No towing.
I think I'll stick with the softer ride.
Old 02-23-2008, 09:56 AM   #6
Tacoma World Ring Leader
klown is one of the sharper tools in the shedklown is one of the sharper tools in the shedklown is one of the sharper tools in the shedklown is one of the sharper tools in the shedklown is one of the sharper tools in the shedklown is one of the sharper tools in the shedklown is one of the sharper tools in the shedklown is one of the sharper tools in the shedklown is one of the sharper tools in the shedklown is one of the sharper tools in the shedklown is one of the sharper tools in the shed
klown's Avatar
klown's Tacoma Gallery
Yeah, toyota corporate tells me the rear leaf springs have been redesigned to address the TSB. I tried to get the TSB but was told by toyota corporate that the TSB wasn't applicable to 2008 models. The issue was apparently addressed with a newly redesigned rear leaf spring. I hope this is the truth, cause I like the stance of my truck as it is, I don't really want the rear end to be raised up due to the fourth leaf spring. I'm glad you've given your account with about 400lbs of stuff in the back. When I load my bed up I will check the ride also, but at this point it doesn't look like it's an issue for 2008 model years.
Old 02-23-2008, 10:44 AM   #7
Zebra is on a distinguished road
Zebra's Avatar
Zebra's Tacoma Gallery
i loaded my 08 up with 20 cases of bottled water from sam's club the other day and no bottoming out.
Old 02-23-2008, 11:21 AM   #8
Mellow has much to be proud ofMellow has much to be proud ofMellow has much to be proud ofMellow has much to be proud ofMellow has much to be proud ofMellow has much to be proud ofMellow has much to be proud ofMellow has much to be proud ofMellow has much to be proud of
Mellow's Avatar
Mellow's Tacoma Gallery
Just picked up mine 2 days ago, loaded it with 8 bags of quickcrete (400lbs) and about 10 landscape timbers and a few other boards. I couldn't tell any difference in ride and no noticeable difference in the bed height however, I'm sure there was at least a little.
I don't know what part numbers to look at so let me know and I'll go check, maybe it doesn't matter if they redesigned the part?
Old 02-23-2008, 01:14 PM   #9
JTDTacoma is on a distinguished road
JTDTacoma's Tacoma Gallery
I loaded my 08 up with firewood (a heaping pile) expecting it to be draggin ass after all the complaints. It wasn't close to bottoming out with the 3 leafs. I hope they addressed the issue!
Old 02-23-2008, 03:57 PM   #10
klown's Avatar
Looks like you guys don't have an issue, from what I can tell, before 2008 these types of loads would have caused you to bottom out.
Old 02-23-2008, 04:30 PM   #11
concrete jedi is one of the sharper tools in the shedconcrete jedi is one of the sharper tools in the shedconcrete jedi is one of the sharper tools in the shedconcrete jedi is one of the sharper tools in the shedconcrete jedi is one of the sharper tools in the shedconcrete jedi is one of the sharper tools in the shedconcrete jedi is one of the sharper tools in the shedconcrete jedi is one of the sharper tools in the shedconcrete jedi is one of the sharper tools in the shedconcrete jedi is one of the sharper tools in the shedconcrete jedi is one of the sharper tools in the shed
concrete jedi's Avatar
Army: Shit deflector
concrete jedi's Tacoma Gallery
My 06 doesn't have an issue with only three leafs, lucky I guess.
Old 02-23-2008, 04:52 PM   #12
I went back today and got quite a lot more dirt so I was not able to get an accurate measurement (this time it was definitely bottoming out, I had 800+ lbs) . I'll be building a fence in the next couple of weeks and check the measurements then. But it does sound like they may be a bit more sturdy.
All that would have been necessiary for the three leaf setup to work is to just use a more rigid pieces of steel (just change the alloy chemistry a bit by adding more carbon). I bet they are stronger, just not as strong as the four leaf set up.
Old 02-23-2008, 07:37 PM   #13
Zebra's Avatar
from what i've seen they redo the shocks as well. that may play a role as well as the leaf springs
Old 02-23-2008, 10:26 PM   #14
Defying Alliances since 2007
TacoTurd will become famous soon enoughTacoTurd will become famous soon enough
TacoTurd's Avatar
TacoTurd's Tacoma Gallery
That's wrong. The modulus of iron or steel doesn't change with carbon content (or hardness or anything else I can think of).
Old 02-23-2008, 11:35 PM   #15
lsocoee's Avatar
I thought, what the hell happened to TurdTaco? Then I realized that you are actually TacoTurd, dropping some knowledge.
Adding carbon to steel increases the hardness and strength.
Old 02-24-2008, 09:44 AM   #16
TacoTurd's Avatar
Up to a point adding carbon increases hardenability of steel (by heating and quenching). Hardness IS strength, just measured in a different way.
But NOTHING changes the stiffness (young's modulus). It will be 30 x 10^6 psi no matter what. If the 08 springs are dimensionally the same as 05-07 (I think they are), then the spring rate HAS to be identical.
Gotta go spin the propeller on my beanie now....
Old 02-24-2008, 10:10 AM   #17
lsocoee's Avatar
It can be anywhere between 28 and 31, so there are some options there.
Old 02-24-2008, 10:46 AM   #18
TacoTurd's Avatar
Not as a function of carbon content.
My point is nobody is alloying steel to change the section modulus of a Toyota leaf spring. It's a silly notion. I'm all about silliness, but not when it comes to metallurgy.
The section modulus of a leaf spring will be directly proportional to the material modulus and the width, but the cube of the THICKNESS. Guess which knob it makes sense to twist.
OK OK I'm going back to the MPG threads now...
Old 02-24-2008, 01:31 PM   #19
I'm not sure if tacoturd is correct or not, but, it sounds like he knows what he is talking about... so I'll agree with him. Maybe they are thicker pieces of metal?
(any time you start throwing numbers and fancy formula at me... you automatically win.)
Old 02-24-2008, 02:41 PM   #20
lsocoee's Avatar
08 Tacoma Sport suspension flesh2 2nd Gen Tacoma Marketplace 3 11-22-2011 07:56 AM
08' Like new Suspension Bilstein Coilvers and Rear Shocks 05xr Buy / Sell / Trade 23 12-13-2010 12:38 AM
TSB rear suspension vs Stock Suspension glennleno1966 4 Cylinder 6 03-10-2010 06:02 PM
Suspension TSB 0305-08 TacoinMD 2nd Gen. Tacomas 0 06-06-2009 04:26 PM
Suspension TSB not listed for the 08 - done today on my 08 DC JJK 2nd Gen. Tacomas 57 12-13-2007 03:44 PM
