305's with 3" lift complete!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Klipp11, Nov 20, 2009.
  1. Nov 20, 2009 at 10:09 AM
    Klipp11
    Klipp11 [OP] s3
    Kevin
    '06 DC 4x4 LB
    OME 885 coils, Bilstein 5100 shocks, 1.5" AAL, TC uca's, cab mount chop, 5000k HID heads and fogs, LED tails, satoshi GC w/ Hella 500's mounted behind it with 5000k HID upgrade, Extang solid tri-fold tonneau cover, Yakima roof rack, fog light anytime mod, disable a/c defrost mod
    hey guys,
    just finished stuffing 305's on my '06 DC LB, and it looks awesome!!!
    just wanted to thank chris 4x4 and forgotten1 for you advice and help!
    thought i'd post some pics of how i did it in case you want to try a bigger tire than a 285 with 3" lift.
    my truck 2 months ago bone stock:
    went with 3" lift by adding 5100's all around with AAL in the rear and OME 885X springs and TC UCA's in the front:
    now the challenging part... making room for these 305/55 20's!!
    rear was no problem, but it's up on the hoist to trim the front:
    shot of the rear 5100 with the AAL installed:
    front end apart with TC UCA installed and fender flare removed:
    originally had tried the 0.85" setting on the 5100, but chris 4x4 and forgotten1 convinced me that running the 0 setting with the toytec top plate spacer is a much better way to go (lets the 5100 do its job with a better ride). this is a shot of the setup i have now:
    ordered both the 1/2" and the 1/4" spacers from toytec, but only ended up using the 1/2" ones:
    with the fender flare removed, it was clear my tires weren't going to allow me full articulation without doing something to the front cab mounts. i decided to trim the front of the cab mounts, then box them in again to restore their strength back to stock, then finally undercoat the welds to keep the rust away. so here we go! (stock):
    trimmed with a plasma cutter:
    traced and cut the steel plate to reinforce the cab mount back to original strength (tack welded):
    front view:
    good as new:
    sprayed with undercoat to seal 'er up and keep out the rust:
    with the hard part done, now it was time to trim up the front plastic a bit (stock):
    after trimming was complete:
    front wheel and fender flare back on, able to go to full lock in both directions. perfect!! (duct tape on fender flare until the epoxy cures):
    finally to brace the plastic inside the wheel well so it's nice and stable and doesn't flop around in there (shot from underneath the front bumper):
    what she looks like today with her new shoes:
    8054x4 likes this.
  2. Nov 20, 2009 at 10:11 AM
    Untamed_SS
    Untamed_SS Stayed Up Too Late
    Adam
    Haughton, Louisiana
    08 Speedway Blue Access Cab
    Alpine iDA-X200 Deck, Rockford P3, Infinity 1600 A Amp, Black Badges, "KnightRider Mod", Back-up lights. Painted Engine Cover. TRD QuickShifter & Shift Knob. MAF Calibrator. Doug Thorley LT Headers. Custom Y-Pipe. Flowmaster 50 series. Satoshi Grill
    Lookin good man. :thumbsup:
  3. Nov 20, 2009 at 10:13 AM
    outlawtacoma
    outlawtacoma Well-Known Member
    W. TN
    2018 T4RTRDOR
    very nice, good job man! :thumbsup:
  4. Nov 20, 2009 at 10:16 AM
    XC4ME
    XC4ME Well-Known Member
    Litchfield Park, Arizona
    05 Tacoma DC TRD Sport
    You did a great job Kevin! :thumbsup:
  5. Nov 20, 2009 at 10:16 AM
    jr114
    jr114 Well-Known Member
    Jon
    SoCal
    Truck
    Icon Ext travel CO, Icon tubular uniball UCAs, Maxtrac Spindles, Icon RR rear w 2"aal.
    looks clean. i really like how they fill up the fender well
  6. Nov 20, 2009 at 10:18 AM
    Doc.SS
    Doc.SS ︻╦╤─
    Frank
    O'side
    T4R SR5
    looks great, those wheels look mammoth
  7. Nov 20, 2009 at 10:21 AM
    Magnetic
    Magnetic Active Member
    Baton Rouge, La
    09 TRD-Off Road, locker mod
    Please elaborate on the fender flare and epoxy....
  8. Nov 20, 2009 at 10:21 AM
    Klipp11
    Klipp11 [OP] s3
    Kevin
    '06 DC 4x4 LB
    thanks guys,
    i really like how it turned out. off to work now, talk to you later!
    kevin
  9. Nov 20, 2009 at 10:22 AM
    TXRoper
    TXRoper Texas Edition
    Dean
    Plano, TX
    Texas Edition PreRunner SR5 - Super White
    So the OME 885X springs with a 1/2" spacer gave you total lift of 3 inches? The 5100s added No lift since they were set a 0" ?
  10. Nov 20, 2009 at 10:24 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Dam good job!! Looks great! :)
  11. Nov 20, 2009 at 10:30 AM
    forgotten1
    forgotten1 Well-Known Member
    Adam
    Chandler, AZ
    06 DCSB TRD Sport 4x4
    Bilstein 5100 set at 0, OME 885 coils, 1/2" Top Plate Spacer, Light Racing Upper Control Arms, Alcan AAL, 17" Moto Metal 951 ALL BLACK, 285/70/17 BFG A/T, Depo Black Housing Headlamps, Onex 4300K HID/3000K Fogs, FLM, Toyota Optional Skid Plate, Avid Offroad Sliders, K&N Drop In Filter, Centric Posi-Quiet Front Brake Pads, USA-Spec DF-Toy, Sirius Sportster 4
    Sweet, looks good man!
  12. Nov 20, 2009 at 10:33 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Seriously nice job! :thumbsup:
  13. Nov 20, 2009 at 10:34 AM
    Good351
    Good351 Well-Known Member
    Ames, IA
    03 4Runner V8
    Very nice, good job!
  14. Nov 20, 2009 at 10:46 AM
    MikeyD
    MikeyD Well-Known Member
    Sayreville NJ
    2007 Toyota tacoma 4x4
    BHLM, HID kit, yellow fogs, Grill craft, Hellas behind grillcraft, LED cup holder mod, after market horn, extra reverse lights, under body glow for off roading at night, pro comp 7089's wrapped in 255/75/17 bfg mud terrains, Toytec coiovers sat at 3.25, 2" add a leaf with 5100's, Satoshi grill mod
    Sickkkk!
  15. Nov 20, 2009 at 11:36 AM
    Canadianboy
    Canadianboy Taco love in East Van
    James
    Vancouver, BC
    09 TRD Sport S/B 4x4 Auto in Mag Grey
    Icon Stage 3, Goodyear Duratracs and KMC Addicts!
    Very nice! Absolutely no rubbing in the front?
  16. Nov 20, 2009 at 12:20 PM
    AZCOMA
    AZCOMA where can't I go?
    Kacey
    Laveen
    05 Preunner sr5
    2.5 saw co's, n-fab bed cage rear tire mount,new head unit and 10"sub,285/75/16 nittos on M/T wheels,H.I.D.'s...The next mod is T.C. long travle kit,Deavers and glass all the way around.
    I bet they still rub a little I have close to the same set up and I can get mine to rub with 285/75/16's
  17. Nov 20, 2009 at 12:22 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    Looks great man...thats some big rubber ya got there :thumbsup:
  18. Nov 20, 2009 at 12:22 PM
    AZCOMA
    Kacey
    Laveen
    05 Preunner sr5
    :headbang::headbang:sorry I ment to say it looks bad ass!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! too
  19. Nov 20, 2009 at 12:31 PM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    wow! first truck with 20s I've seen that looks absolutely awesome!! :thumbsup:
  20. Nov 20, 2009 at 12:36 PM
    Rudbwoy7s
    Rudbwoy7s Well-Known Member
    TEXAS
    08 Double cab 4x4 sr5
    3" Revtek suspension lift, 17" Black and silver American Eagle Alloy wheels, 285/70 Nitto Terra Grapplers, Flowmaster 40 series muffler, sockmonkey brake light cover, Maglight mod, Viper alarm, Smith & Wesson hitch receiver cover
    those huge wheels make it look like it has no lift.
