SecretSquirrel's 2005 Tacoma w/ All-Pro Bumper, Satoshi Grille, Cooper 305 STTs & more...
ooops i drained the tranny oil !
Products Referenced Thread Tools Search this Thread Display Modes
Old 03-08-2008, 06:30 PM   #1
you win mr anonymous
phantom has a reputation beyond reputephantom has a reputation beyond reputephantom has a reputation beyond reputephantom has a reputation beyond reputephantom has a reputation beyond reputephantom has a reputation beyond reputephantom has a reputation beyond reputephantom has a reputation beyond reputephantom has a reputation beyond reputephantom has a reputation beyond reputephantom has a reputation beyond repute
phantom's Tacoma Gallery
ok i see it happened again on another site
so do you think this should be made a sticky somewhere for all the new folks? if so where? ( no it won't fit there)
note that the transmission oil plug is beyond the bell housing ( ok 1 1/2 feet back of the oil drain
the oil drain is almost in the middle of the front axle
UPDATE: 10/05/08
IF YOU DID MAKE A BOBO , DO NOT DRIVE THE TRUCK !
GET MORE OF THE atf ( FROM TOYOTA AS I DO NOT CARE WHAT THE PARTS STORE SAYS IT IS DIFFERENT)
AND FOLLOW THESE INSTRUCTIONS
http://phantomphixer.iquebec.com/fill.pdf
__________________
Old 03-08-2008, 06:39 PM   #2
06tacoma is on a distinguished road
06tacoma's Avatar
06tacoma's Tacoma Gallery
I think its pretty obvious where its at but i guess for a person that not use to looking underneath cars i could understand the mistake but you have to think about it you will never see a oil drain plug so far to the rear of the truck
__________________
Old 03-08-2008, 06:57 PM   #4
06tacoma's Avatar
I clearly said i could understand the mistake of a new owner and never sayed i was a perfect mechanic but after being under a few cars you come to understand stuff and take your time but i do agree it should be stickied
__________________
Old 03-08-2008, 08:59 PM   #5
Old Fart Anonymous
Janster has a reputation beyond reputeJanster has a reputation beyond reputeJanster has a reputation beyond reputeJanster has a reputation beyond reputeJanster has a reputation beyond reputeJanster has a reputation beyond reputeJanster has a reputation beyond reputeJanster has a reputation beyond reputeJanster has a reputation beyond reputeJanster has a reputation beyond reputeJanster has a reputation beyond repute
Janster's Avatar
Gender: Female
Janster's Tacoma Gallery
Originally Posted by rhoppas View Post
Excellent...and useful picture. This should be useful to many people.
It's a double edged sword I guess. I'll be one of the first people to point out how EASY it is to do your own maintenance - however, I forget to realize that people obviously don't spend enough time researching and looking for pictures first before diving under there and unscrewing the first bolt they see.
I guess maintenance really ISN'T as easy as we think it could be. It involves some research.....
But then again - Why the hell did Toyota put a drain plug on the transmission in the first place? The transmission doesn't have a dipstick and it's not supposed to need service for 100,000 miles anyway... How hard would it be to drop the entire pan?
__________________
Our Homepage
http://www.lieblweb.com/
My truck photo gallery
http://www.lieblweb.com/cpg/thumbnails.php?album=16
I know I'm in my own little world, but it's ok, They know me here.
Old 03-08-2008, 09:08 PM   #6
Land of Oz
rhoppas has much to be proud ofrhoppas has much to be proud ofrhoppas has much to be proud ofrhoppas has much to be proud ofrhoppas has much to be proud ofrhoppas has much to be proud ofrhoppas has much to be proud ofrhoppas has much to be proud ofrhoppas has much to be proud of
rhoppas's Avatar
rhoppas's Tacoma Gallery
Janster - I couldn't agree with you more, on all points. For those people who aren't quite sure what they are doing, and they are smart enough to do a bit of research before diving in, Phantom's picture makes it pretty clear. The 'ol adage "a picture is worth a thousand words" applies here.
Old 03-08-2008, 09:24 PM   #7
08TurboTaco is on a distinguished road
08TurboTaco's Tacoma Gallery
"But then again - Why the hell did Toyota put a drain plug on the transmission in the first place? The transmission doesn't have a dipstick and it's not supposed to need service for 100,000 miles anyway... How hard would it be to drop the entire pan?"
Its actually not the drain plug, its the overflow plug used for refilling the transmission.
Old 03-08-2008, 10:07 PM   #8
Old Fart Anonymous
Janster's Avatar
Gender: Female
You'll have to explain what you mean by the 'overflow plug'.
Not doubting you - but how do they refill the transmission with a bolt at the bottom of the pan? It's baffling my thinking....
__________________
Our Homepage
Old 03-08-2008, 11:05 PM   #9
because there is no dip stick, the transmission cannot be filled the traditional way. The way to fill the new transmissions with the new WS fluid is to connect the toyoto scan tool to set the vehicle in maintenance mode and to monitor the temperature of the ATF. there is a fill plug on the side of the transmission that a toyota special tool will all allow you to pump fluid into the trans. when the temp is at the proper level you take out the overflow plug on the bottom and continue pumping in fluid until you get a slight trickle out of the overflow. The trans pan has a tube on the inside where the overflow plug is, this tube is a predetermined length so that when the ATF is at the proper temperature and level it will expand to the exact height of this tube and barely trickle out. i.e. no flow then there is not enough fluid....heavy flow then it is overfilled..... Believe me, we dealership technicians hate this new design also....its a huge pain in the ass
Old 03-08-2008, 11:07 PM   #10
I am an idiot and I mis-spelled Toyota (and I work for them ha!)
Old 03-09-2008, 08:56 AM   #11
gsm gsm is offline
gsm is on a distinguished road
gsm's Avatar
gsm's Tacoma Gallery
First, I agree this should be, and is now, a sticky. I've been changing my own oil (and started with my fathers truck) for over 30 years now. And although changing oil is straight forward for me as well as most other, Some may be young and this could be their first vehicle and oil change experience. My father taught me at a young age (probably so he didn't have to do it ). But that type of hand me down knowledge is being lost, just like hunting, farming, etc., to make way for quick change stations.
08TurboTaco, without looking at the tanny overflow plug, what you say makes sense but if an oil change is performed - how do they get all the old oil out of the tranny without a "drain plug"? Syphon it out?
Old 03-09-2008, 02:36 PM   #12
Biggest asshole on this board
WilsonTheDog has a reputation beyond reputeWilsonTheDog has a reputation beyond reputeWilsonTheDog has a reputation beyond reputeWilsonTheDog has a reputation beyond reputeWilsonTheDog has a reputation beyond reputeWilsonTheDog has a reputation beyond reputeWilsonTheDog has a reputation beyond reputeWilsonTheDog has a reputation beyond reputeWilsonTheDog has a reputation beyond reputeWilsonTheDog has a reputation beyond reputeWilsonTheDog has a reputation beyond repute
WilsonTheDog's Avatar
WilsonTheDog's Tacoma Gallery
"Special tools", gotta love it. It's more like "let's make a design that the average DIYer won't be able to handle so he has to come spend money with us".
__________________
Old 03-09-2008, 04:02 PM   #13
"08TurboTaco, without looking at the tanny overflow plug, what you say makes sense but if an oil change is performed - how do they get all the old oil out of the tranny without a "drain plug"? Syphon it out?"
The WS ATF is not sceduled to be changed until 100K miles. If and when it does need to be changed, a full flush can be performed with a flush machine, or the trans pan will need to be dropped to drain all of the oil out of the pan, this however will only get about 4 of the 12 quarts since the remainder will still be in the coverter, so a flush is the best solution.
Old 03-10-2008, 04:35 PM   #15
Tool Geek
river rat is on a distinguished road
river rat's Avatar
river rat's Tacoma Gallery
Indeed. A full flush is good. I wish I had a drain plug on my '94 Lincoln.
I just did the 120K tranny fluid and filter service but would have to change it multiple times to get it clean. That would pretty much suck...Wish I could rent one of those machines for a few hours.
Rob
__________________
Tail gate closed for better gas mileage.
Old 03-11-2008, 04:11 AM   #16
Mudbug is on a distinguished road
Mudbug's Avatar
Mudbug's Tacoma Gallery
When I was 16 I did an oil change on my vw passat.....and as I poured the new oil in....bwahahaha I had forgotten to put the drain plug back in the pan LOL
__________________
2007 Tacoma Regular Cab 4x4 2.7
2006 Yamaha FZ1
1966 Ford F100
Old 03-11-2008, 06:23 AM   #17
CCRT is on a distinguished road
CCRT's Tacoma Gallery
Transmission Over Flow Tube
Phanton....
You making the underside of my truck famous
Thought this would help explain the transmission overflow tube.
Old 09-09-2008, 01:25 PM   #18
red06toy is a splendid one to beholdred06toy is a splendid one to beholdred06toy is a splendid one to beholdred06toy is a splendid one to beholdred06toy is a splendid one to beholdred06toy is a splendid one to beholdred06toy is a splendid one to beholdred06toy is a splendid one to behold
red06toy's Avatar
red06toy's Tacoma Gallery
Your right, I went to a high school that had an auto shop even tho it wasnt a voke school. We take this stuff for granted. I work witha kid who didnt know what a spark plug was, my girlfriends brother didnt know how to put air in his tires. No bulls**t.
Old 09-19-2008, 08:00 AM   #19
braker19 is on a distinguished road
braker19's Tacoma Gallery
made the same mistake
I am a first time DIYer and accidentally drained the transmission fluid as well. Is it possible to refill the fluid with a manual pump, and if so, could I get some advice on where to find the refill plug and how much fluid this will take. Thanks, and please excuse my extreme idiocy as I didn't have anyone to teach me these types of things in my youth.
Old 09-19-2008, 08:08 AM   #20
My hair is all natural
lsocoee has a reputation beyond reputelsocoee has a reputation beyond reputelsocoee has a reputation beyond reputelsocoee has a reputation beyond reputelsocoee has a reputation beyond reputelsocoee has a reputation beyond reputelsocoee has a reputation beyond reputelsocoee has a reputation beyond reputelsocoee has a reputation beyond reputelsocoee has a reputation beyond reputelsocoee has a reputation beyond repute
lsocoee's Avatar
Gender: The Dude
lsocoee's Tacoma Gallery
your forgiven. we all have those DOH moments. The fact that you tried to do it means you should be commended. Welcome to the site.
Home > Tacoma Discussion > 2nd Gen. Tacomas
Display Modes
Related / Mentioned Products
K&N Air Filter - $29.87
HELP! tranny screw-up? orangebutte 2nd Gen. Tacomas 13 02-04-2008 12:08 PM
ooops ZonKs 2nd Gen. Tacomas 7 09-12-2007 08:25 AM
Auto Tranny Fluid BlackSportD 1st Gen. Tacomas 9 08-10-2007 06:43 AM
new member with tranny problem bryan44 Technical Chat 10 04-01-2007 03:48 PM
tranny problems Bud Technical Chat 2 10-30-2006 11:16 AM
Copyright © 2009 Tacoma Forum
