Glovebox piston/hydraulic
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kupono64, Mar 16, 2008.
  1. Mar 16, 2008 at 7:49 PM
    kupono64
    kupono64 [OP] Member
    Honolulu, HI
    06 Access Cab, SR5, 2.7L I4, Auto
    Rolling Tonneau, Locking Gate, Factory Tacoma Seat Covers, Factory Tacoma Floor Mats, Bug Deflector, 16" Motegi Rims, Secondary filter removed, Tint,
    Has anyone every broken that hydraulic on the glove box? My friend pulled down on the glove box (not knowing it drops down slowly on its own with the hydraulic piston). The clip isn't broken but the catching edges on the two pronged upper clip are rounded off. So you can snap it back on the clip, but it'll just slide off the next time you try to open it.
    I'm thinking of snapping the hydraulic back on and putting a little dab of silicone or epoxy to build up an edge that prevents it from slipping off.
    Before I do this though, does anyone have any better ideas or done something different?
  2. Mar 16, 2008 at 10:31 PM
    RedruM29
    RedruM29 Blinking Car Mod...
    Kyle
    Nor☆Cal
    08 trd sport 4x4
    Just enough, and never enough
    i've done this too installing my ipod adapter, so i played with it for so long that i eventually got it to work. I was freaking out when i did it too so i wasn't taking my time like i should have.
  3. Mar 17, 2008 at 1:06 AM
    kupono64
    Honolulu, HI
    So what method was it that you used?
  4. Mar 17, 2008 at 7:41 AM
    Dutch
    Dutch Well-Known Member
    Wilmington, NC
    07 4x4 Taco
    Did the same to mine. I just left it off. It is kind of cheap and really not needed.
  5. Mar 17, 2008 at 9:05 AM
    RedruM29
    Kyle
    Nor☆Cal
    08 trd sport 4x4
    I don't know that there was really a method to the madness i just kept trying new things until it worked. i used a flat head screwdriver to hold the piston on to close the glove compartment.
  6. Mar 17, 2008 at 2:12 PM
    pdxyota
    pdxyota Well-Known Member
    Greg
    Newberg, OR
    2005 4x4 5M 2TR-FE SR5 Access Cab Indigo Ink Pearl
    TSB x 2 because first TSB leaf springs broke
    Mine broken off over and over and then finally the piston broke and zero hydraulic. It was still under warranty, MINE is rounded off as well and so I can't put anything heavy in there or it'll just unclip itself and slam open.
  7. Mar 17, 2008 at 5:03 PM
    willard417
    willard417 Yeah
    Luke
    beaver county, PA
    06' access cab. 2.7L
    alpine head unit, removed secondary air filter, 18" XD Rockstars. 285/60/R18, 3" OME 884/AAL OME shocks all around.
    mine came off too and kept coming off so i told the dealer when i was there and they put a new one on and he said if it came off again he would probably have to change out the entire dash. it came off again as soon as i opened it but it wasn't worth all that hassle
  8. Nov 21, 2020 at 8:58 AM
    rlg0613
    rlg0613 Patron Prince
    Bob
    NC
    08 Super White Prerunner SR5 I4 Manual
    Fog Lights
    My 2008 Tacoma has not had this problem... until today! While installing the cabin air filter for the nth time the piston fell off the dash nub and wouldn't stay on. I read all the solutions but wanted something a little more permanent. I did use a screw to spread the barbs on the dash nub. I also drilled through the slot of the nub with a 5/64" bit. I used a small screw and a lug from a duplex receptacle as a washer. It went together nicely and is holding great.
    Comet'spop, Rocketball and DR_CA68 like this.
