Blocks vs. Add A Leaf.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by skierpunk, Mar 18, 2008.
  1. Mar 18, 2008 at 11:32 AM
    skierpunk
    skierpunk [OP] Well-Known Member
    Oregon
    08 DC Off Road.
    TRD mats and seat covers, smoked tail lights, smoked turn signal corners, Revtek lift, Access LE tonnaeu, HIDs, grillcraft mesh grill, TRD CAI, custom bike racks, Alpine system.
    I'm new to the fourm and even newer to suspension. I am looking at installing the revtek lift. However, I have a few questions first:
    1. If I’m going to be towing a boat from time to time, as well as using the truck how it was intended to be used (hauling and using the bed for various different jobs) would it be better to get a lift with add a leaf instead of blocks?
    2. What are a few Pros and Cons for each style of lift.
  2. Mar 18, 2008 at 12:10 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    The only thing a block will do is raise your truck. The handling and suspension characteristics are gonna be the same.
    Putting an AAL will raise your truck and change the suspension characteristics. It'll support more weight, more control (axle wrap), and better handling (so to speak).
    I'm not a fan of blocks. I've seen too many people bust them apart while offroading on the trails. I'm not necessarily a fan of AAL's either. I've had them in the past and they're OK...but can and will eventually wear out your original leaf paks.
    Ultimately - if your gonna be towing, hauling and putting your suspension through a workout, I would highly recommend replacing the entire leaf paks. It'll be more expensive - but I'm pretty sure it'll last longer and be even more durable for the workout you'll give 'em. Shop around - as I think there are lots of options.
    doyouevenprerun likes this.
  3. Mar 18, 2008 at 1:10 PM
    mjp2
    Milton Juevo Portimous II
    NJ
    I also posted this in a suspension thread a week or so ago. It's a pretty killer deal. AllPro has 05+ leaf packs on sale for $369 a pair, with your choice of 1.5" or 3" of lift. 25% off for the month of March.
    Note that they're for offroading so they'll be better for flex and ride than for load capacity. Add a set of Timbrens with the springs to increase the capacity and you'll be all set!
  4. Mar 18, 2008 at 1:25 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    15 Lariat Sport 5.0L
    or if u have an 05-07...and some 08's, u can get a suspension tsb that'll lift the rear up 1 1/4" w/ replacing the whole leaf pack, and also the shocks if u dont have a trd. fill us in on what year/model u have
    fatrip likes this.
  5. Mar 18, 2008 at 2:16 PM
    nd
    nd Radical Town. It's a hell of a place!
    Nate
    Greenville, SC
    07 TRD Off-Road 4x4 debadged
    De badged, 5100's, Black Toyota Baja wheels
    go with leafs, not blocks
  6. Mar 18, 2008 at 10:36 PM
    skierpunk
    Oregon
    08 DC Off Road.
    My truck actually hasn’t come in yet but it’s supposed to be here within a week. It’s a black double cab TRD Off Road. I hope I can get the TSB done. Save lots of money.
  7. Mar 18, 2008 at 11:11 PM
    The_Hodge
    SC
    some people have been hit or miss w/ the 08's. just look under there and see if u have 3 leafs or 4. if u have 4, then the tsb has already been done/corrected. if thats the case, then the only ways to lift the rear are to either get a whole new leaf pack or blocks.
  8. Mar 19, 2008 at 2:24 AM
    ERdept
    ERdept Well-Known Member
    So if I want to lift by replacing the leaf pack, AND increase payload, what brand is the one to buy for the 2008 Prerunner?
    In other words, who makes it that I can buy from that fits the 2008 Prerunner?
    Then All I need for the front is the Toytec aluminum spacer and coils and 5100's all around.
  9. Mar 19, 2008 at 6:42 AM
    nd
    Nate
    Greenville, SC
    you cant use the 5100's with spacers unless you keep them at stock height. Just an FYI
  10. Mar 19, 2008 at 9:51 AM
    Big Guns
    Big Guns Well-Known Member
    Temecula, CA
    07 PreRunner SR5 4.0L Indigo Blue
    Aero Turbine 2525 exhaust, Black Headlight Mod, DO Rock Sliders
    I have heard from reading around forums that the deavers are "haulers" and the alcans are "wheelers", but i find that a little iffy. You really cant go wrong with any of the companies as far as wheeling/hauling goes, but anyone will tell you they prefer the ones they have. I hear good things about the All-Pro springs, and for the price you really can't go wrong.
  11. Mar 19, 2008 at 9:56 AM
    jonny_jard
    jonny_jard Well-Known Member
    Alberta
    06 Taco
    3" suspension lift, bull bar, IPF 100w flood light system, side bars, custom fit leather seat covers, URD CAI, URD MAF calibrator,
    Has anyone ever heard about the blocks wearing out, eventually sliding out of position causing the axle to kick out while in motion
  12. Mar 19, 2008 at 11:27 AM
    mjp2
    NJ
    The 3" AllPro springs installed, for those on the fence about the:
    remgu2000 likes this.
  13. Mar 19, 2008 at 11:34 AM
    ERdept
    That's like 20 leaf springs!
  14. Mar 19, 2008 at 11:44 AM
    Janster
    Jandy
    Lancaster, PA
    YES! I've only ever seen this while on the trails with rigs while offroading - and I've helped do trail repairs on many rigs because their blocks came out.
    I knew a guy who almost got castrated by a block that literally *flew* out while the guy was on the gas and the axle was under extreme torque. Another guy - lost one side and he didn't realize it. He got on the gas some more and it knocked the other side out, the axle was free floating (not attached to anything). That resulted in the rear driveshaft to tweak the u-joint & yoke while punctering a hole in the bottom of his bed.
    lo2hi likes this.
  15. Mar 19, 2008 at 12:15 PM
    nd
    Nate
    Greenville, SC
    thats awesome! Now whats the reasoning for moving the shock mount forward on the frame?
  16. Mar 19, 2008 at 12:39 PM
    mjp2
    NJ
    I'm actually changing quite a bit. The Jounce Shocks will soon be moved to inside the frame rails to make room for 2.5" bypass shocks that will mount to the top of the axle housing and will come through the bed outside the frame and will tie into the bed cage.
    It has to keep pace with the front suspension:
    :eek:
  17. Mar 19, 2008 at 1:14 PM
    nd
    Nate
    Greenville, SC
    What do you mean it has to keep pace with the front? Sorry but i'm ignorant about setting a truck up for a baja race, you will have to explain things to me cause i really wont know what you're talking about.
    I need to read the full story on your truck. do you have it documented on TN or TW or TTORA or anything like that? I am just amazed that you're doing this to a brand new truck. Dont get me wrong, its badass but, damn thats alot of money to sink into a truck....
    Looks like a fun hobby though :)
  18. Mar 19, 2008 at 1:38 PM
    mjp2
    NJ
    Full story: Basically I beefed up the front end enough that it would survive long after the rear shocks were foamy, the leaf springs cracked, the bumpstops broke off, and the ass end bounced me sideways off the road. Everything I've been doing has been to increase durability and safety.
    I got the idea while sitting in traffic on my way to work one morning and kinda ran with it. At this point I've turned the truck into a business and will start seeking sponsors once I'm back on the road. I've hemorrhaged money, but I also have 10 times the truck I had originally planned.
    The fun should start soon. The cage is nearing completion and the fuel cell should be started shortly. After that the truck will be drivable again! Currently it's just me walking into an episode of Overhaulin' every Saturday morning when I visit the shop. :D
  19. Mar 19, 2008 at 2:15 PM
    The_Hodge
    SC
    damn...i just put 2" blocks on mine...now was he doing some harder/bigger trails or just minor/intermediate trails? i really dont want my shit to pop out while on trail. if u have the u-bolts tightened good enough, shouldnt it be ok?
  20. Mar 19, 2008 at 6:10 PM
    jonny_jard
    Alberta
    06 Taco
    SH#T... So basically if you only drive to and from the grocery store with minimal foot to floor ratio you should be safe. Anyone else know of experiences like this? Thanks for the reply Janster. Sounds like this is something everyone should know about.
