Brighter Reverse lights
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NastyN8, Jan 12, 2010.
  1. Jan 12, 2010 at 5:43 PM
    NastyN8
    NastyN8 [OP] Member
    N. Arizona
    08 TRD Sport 4X4
    none as of yet need $$ --- TRD Cold Air & exaust, chip, ProComp 3", extra lighting, etc.
    I have been looking on all the Tacoma forums I could find since I bought my truck in late December. I saw a way to modify some lights (possibly some sort of headlight) to fit where the reverse lights go. I cannot find the website were I saw it. I live in a neighborhood w/o streetlights and my windows are tinted. Need more light to prevent hitting another car/person/animal/hard object. Help please!
  2. Jan 12, 2010 at 5:49 PM
    Viet2100
    Viet2100 Well-Known Member
    Viet
    South Florida
    2016 Prius 4T
    Back up lights, 7-pin back up light, foglight bulb in the reverse light socket, roll your windows down, or get lighter tint.
  3. Jan 12, 2010 at 5:57 PM
    vtragweed
    vtragweed Beef Slut
    Willie
    VA
    08 2.7 SR5 Debadged
    afe pro-dry s filter, LCE headers, painted black steelies,color matched grill surround, URD short shifter, UWS black tool box
    go to tractor supply get 2 tractor off-road lights and wire them into your reverse wire
  4. Jan 12, 2010 at 6:11 PM
    badguybuster
    badguybuster Well-Known Member
    Michael
    West (by GOD) Virginia
    2016 Tacoma TRD Sport
    New truck....so nothing yet
    subscribed
  5. Jan 12, 2010 at 6:11 PM
    Anathollo
    Anathollo www.saveadane.org
    Houston
    07 Tacoma TRD Sport
    Icon coilovers, Rear Fox Resi-shocks, 285/70/17 Toyo A/T's, Touchscreen JVC Headunit, Custom Rhino-lined sub box, Rocksford Fosgate components and Dual Rockford Fosgate 10" shallow subs, Pioneer and Rocksford Fosgate amps, 1250 watts total, Autometer Volt and Trans gauges with Lotek A-pillar, K&N Drop-in filter, WO Seat covers, Tint, NST WP pulley, Hi-lift jack, Diff breather mod, horn relocation mod, extra "D" rings, de-pinstriped, carrier bearing drop, Rear backup 886 bulbs, Camburg UCA's, AMW Catch can, BHLM, OME Dakars with AAL, Procomp 7089's, Front single hoop Demello bumper, Superwinch Tiger Shark 9500, Amsteel 3/8th synthetic line
    If you get 886 fog light bulbs from autozone or wherever and use a dremel to cut off the end to where you just have the two wires showing, that will give out more light. It takes about 20 mins to do them both.
  6. Jan 12, 2010 at 6:15 PM
    bigyetti
    bigyetti Well-Known Member
    mike
    asheville, nc
    08 taco dc 4x4 short bed
    sirius satilite radio, more on the way when i get more money. oh ya removed the secondary filter
  7. Jan 12, 2010 at 6:15 PM
    SamSter0077
    SamSter0077 Happy Camper
    Katy, TX
    09 Tacoma 4x4 TRD OR
    OME 886 Coils, and Struts, Rear Toytec TSB AAL/ OME shock absorbers, Fog Lamp anytime mod, Voyager Brake Controller.
  8. Jan 12, 2010 at 6:16 PM
    SamSter0077
    Katy, TX
    Anathollo, you have before and after pics posted somewhere, don't you?
  9. Jan 12, 2010 at 6:20 PM
    Anathollo
    Houston
    07 Tacoma TRD Sport
    yeah they're in my pics.
    My truck on the right has the new backup bulbs and the truck on the left doesn't.
  10. Jan 12, 2010 at 6:41 PM
    borderbrat
    borderbrat Watching Chris4x4 o.O
    Jeremy
    Victoria BC, Canada
    2012 DCLB, STOCK..But not for long
    (old truck 2008 AC ....PIAA fogs, led "puddle" lights, bed lights, in cab 115V, Toyota Devil emblem, Randy Ellis light bar with LED light bar, OME 885 and Dakar leaf springs OME shock all round, 2.5 Gal OBA system with air horns, iPod adapter, scangauge on blend mount, magnaflow catback, bike fork mounts, tinted 2009 tails.)
  11. Jan 12, 2010 at 8:29 PM
    NastyN8
    NastyN8 [OP] Member
    N. Arizona
    08 TRD Sport 4X4
  12. Jan 12, 2010 at 9:53 PM
    mr2crazed
    mr2crazed Well-Known Member
    Morro Bay, CA.
    06 DC PreRunner SR5
    Any risk melting the housing due to the increased wattage? I guess since they're backup lights, they're not on for very long.
  13. Jan 13, 2010 at 9:27 AM
    toughtaco
    toughtaco Well-Known Member
    05 tacoma dbl cab short bed
    TRD CAI, MBRP dual exhaust, PIAA headlights and driving lights, 5% limo tint, 3 inch Skyjacker lift , AFE throttle body spacer, 285/70/17 BF Goodright AT TA KO, Grillcraft MX with PIAA's behind the grill, anytime fog light mod, reverse camera anytime mod, and PIAA fog lights on the rear bumper anytime mod light bar behind back window with truck lights for reverse assistance, Optima Red Top Battery, Onza 3x5" LEd reverse lights attached to light bar behind cab
    I have really dark tint and i did PIAA fog lights mounted under the rear bumper witha reverse camera. They are really bright and every once in a while i roll the windows down but the camera works well.
  14. Jan 13, 2010 at 12:08 PM
    DDD
    DDD Shine bright like a hymen
    Derek
    Santa Clarita, CA
    I did this mod about 8 months ago and have had no serious problems.
    When cutting the wire leads on the bulb I used wire cutters and the bulb broke. So next I used a dremel with cut-off wheel and it worked perfectly. The other problem I had was that one bulb popped out of the plug after driving for a few days. So, I squeezed the contacts closer and put the bulb back in and it has been fine ever since.
  15. Jan 13, 2010 at 12:16 PM
    Mark C.
    Mark C. If you want it bad, you usually get it bad!
    Mark
    Connecticut
    2010 MGM SR5 4WD AC
    LED Dome, Reed Switched LEDs in Glove Box and Center Console, Bumper Fogs, Tailgate anti-theft, LEDs over Cig lighter, Back-up camera anytime, Outside Temp add-on, Hidden GPS power, Sockmonkey 3rd Brakelight decal, 4X4 switch illumination, reed switch controlled engine compartment Flood LEDs, Elite Hitch Cover, Plasti-dipped cupholders and door switch control panels, Elite Hitch Cover.
    I did this about a week ago. No problems yet. Will let you know if something ugly happens.
  16. Jan 13, 2010 at 3:26 PM
    HankB
    HankB Well-Known Member
    Hank
    near Chicago
    06 Preruner TRD Off Road
    bone stock
    I did this too, but with a minor twist. I selected a Sylvania 889 lamp. That's 27 watts, vs. 18 for the factory bulb and 50 for the 886. I felt the 889 would provide a compromise between additional light and possibility of problems due to excess current and heat.
    I used a metal cutting blade on a reciprocating saw to slice along the back side of the mounting flange (e.g. opposite the surface with the gasket) and it released the bulb in about 3 seconds. Using a hacksaw would probably take under a minute.
    I tried to capture the results against my light colored garage door. I noticed that the shadow thrown by the lights made the difference more evident than the light itself. You can see the results below. Only the left bulb was replaced, the right one - left in the picture facing the rear of the truck - is still the factory bulb.
    The shadow thrown by the factory bulb is barely visible while the factory bulb barely lights the shadow thrown by the 889 bulb.
  17. Jan 13, 2010 at 3:36 PM
    trdtacoman31
    trdtacoman31 Well-Known Member
    Raleigh, NC
    2011 Titan Pro4x CC
    Bought some nice rectangle 55w lights from Northern Tool for 12 bucks/pair. Bought an 8 dollar relay, tapped into the power source and reverse lights from the tow package. Mounted the lights on each side of the hitch with the hardware included so that they are up underneath the rear bumper and at an angle. I love them because they are really bright and not even visible (when not in use) when looking at the back of the truck. Just did this mod last week.
  18. Jan 14, 2010 at 8:40 AM
    Chachie
    Chachie Well-Known Member
    Justin
    Nor Cal
    '06 TRD OR, 4x4, Auto, 6" Fabtech, 35's
    Locker mod, Anytime fog mod, always 400w mod.
    I was thinking of doing the same thing but putting them like on either side of the license plate, provided it does not block it at all. I do a lot of off roading and the chances that i would break one off under my bumper are pretty high.
  19. Jan 14, 2010 at 8:46 AM
    Anathollo
    Houston
    07 Tacoma TRD Sport
    No not really. How long do you stay in reverse? I'm never in reverse for that long so I don't really worry about it
  20. Jan 14, 2010 at 8:52 AM
    Chachie
    Justin
    Nor Cal
    Well they could be on for a while at times. I know that when we go hunting if it is dark by the time we are ready to head out or we have to drag a deer out, we will just turn on the ignition throw it in reverse and set the ebrake, then turn the ignition off just so we have the extra light.
