09 Dbl Cab 4x4 rear lift w airbag? Heavy load, leveling.
Old 01-18-2010, 05:22 PM   #1
TacoMO [OP] TacoMO is offline
TacoMO has a spectacular aura aboutTacoMO has a spectacular aura about
TacoMO's Avatar
TacoMO's Tacoma Gallery
I know I have the terms wrong, but I am looking for a rear adjustable airbag for leveling the load.
Maybe I have this all wrong, but I am going to haul a fairly heavy (400 lb) motorcycle on a hitch mounted carrier. I have used it several times in the past for short trips with no problem.
I have a 1,000 mile trip planned for next month. (each way.)
Is there some type of lift or air controlled ride height adjusting device that is available?
I don't think it's good for the truck to ride with the back end sagging for 2,000 miles..
If anyone has a suggestion, I'd appreciate it.
Thanks,
Jeff
Old 01-18-2010, 07:01 PM   #2
My pee parts itch
dexterdog is one of the sharper tools in the sheddexterdog is one of the sharper tools in the sheddexterdog is one of the sharper tools in the sheddexterdog is one of the sharper tools in the sheddexterdog is one of the sharper tools in the sheddexterdog is one of the sharper tools in the sheddexterdog is one of the sharper tools in the sheddexterdog is one of the sharper tools in the sheddexterdog is one of the sharper tools in the sheddexterdog is one of the sharper tools in the sheddexterdog is one of the sharper tools in the shed
dexterdog's Avatar
dexterdog's Tacoma Gallery
Have you had the rear leaf TSB performed? I would look into this before investing in an airbag system when the TSB would be performed under warranty and would only cost you your time.
I wouldn't be too concerned with hauling the Harley especially after having the TSB done.
Old 01-18-2010, 07:07 PM   #3
ktmrider is one of the sharper tools in the shedktmrider is one of the sharper tools in the shedktmrider is one of the sharper tools in the shedktmrider is one of the sharper tools in the shedktmrider is one of the sharper tools in the shedktmrider is one of the sharper tools in the shedktmrider is one of the sharper tools in the shedktmrider is one of the sharper tools in the shedktmrider is one of the sharper tools in the shedktmrider is one of the sharper tools in the shedktmrider is one of the sharper tools in the shed
ktmrider's Avatar
ktmrider's Tacoma Gallery
i haul 2 dirtbikes roughly 525 pounds with 100 pounds of gear all over the place and i really dont sag. One time i did bottem out, but i was going close to 100 in a 45 zone. other then that i go about 300 miles on riding trips and i really dont see a problem, other then i cant burn out with them in there(even brake starting)
Old 01-18-2010, 07:30 PM   #4
TL697 is a splendid one to beholdTL697 is a splendid one to beholdTL697 is a splendid one to beholdTL697 is a splendid one to beholdTL697 is a splendid one to beholdTL697 is a splendid one to beholdTL697 is a splendid one to beholdTL697 is a splendid one to behold
TL697's Tacoma Gallery
x's 2 on the TSB...
I had the TSB done on my '09, and I haul my ATV with no issues, even offroad...
Old 01-18-2010, 08:48 PM   #5
slooowr6 is on a distinguished road
slooowr6's Tacoma Gallery
Thanks,
Jeff
Take a look at Firestone Ride-Rite air bags, http://www.fsip.com/riderite/ . Easy to install and reasonable priced. I tried Air-Lift, the placement of the bag is not idea for really heavy load (1000lbs) in truck bed.
Load leveling air bags for '12 AC 4X4 V-6 helibear 2nd Gen. Tacomas 40 08-19-2012 09:23 PM
small lift for 2011 Tacoma Dbl Cab 4x4 nmhs ToyTec Lifts 30 07-10-2011 09:36 PM
Rancho easylift leveling kit 06' dbl cab sr5 Tacotime19 Wheels & Tires 3 03-31-2011 06:45 PM
dbl cab 4x4 vs dbl cab prerunner got_titan Suspension 0 02-27-2010 07:03 PM
New 09 Super White Tacoma 4x4 DBL Cab LB CLK New Members 11 11-15-2009 07:18 PM
