shock bolt spinning???
Old 02-04-2010, 04:49 PM   #1
kinkrider101 is one of the sharper tools in the shedkinkrider101 is one of the sharper tools in the shedkinkrider101 is one of the sharper tools in the shedkinkrider101 is one of the sharper tools in the shedkinkrider101 is one of the sharper tools in the shedkinkrider101 is one of the sharper tools in the shedkinkrider101 is one of the sharper tools in the shedkinkrider101 is one of the sharper tools in the shedkinkrider101 is one of the sharper tools in the shedkinkrider101 is one of the sharper tools in the shedkinkrider101 is one of the sharper tools in the shed
kinkrider101's Tacoma Gallery
Question shock bolt spinning???
its been about a month since i had my lift out on.I went out and check the top bolts on the rear shock, and when i put a wrench on it to tighten the whole axle spun with the bolt, is this normal?
Old 02-04-2010, 05:01 PM   #2
chris4x4's Avatar
chris4x4's Tacoma Gallery
What shocks? 5100's?
Old 02-04-2010, 05:44 PM   #3
yes 5100
Old 02-04-2010, 05:44 PM   #4
chris4x4's Avatar
The top of the shock shaft is made to fit a 5mm hex wrench to hold it still.....I have a pic on here somewhere....
Old 02-04-2010, 06:04 PM   #5
oh ok i couldnt see the top thank you,is it supposed to be loose?
Old 02-04-2010, 06:06 PM   #6
chris4x4's Avatar
No. It should be tight.
Old 02-04-2010, 06:07 PM   #7
ok thats not good then
Old 02-04-2010, 06:12 PM   #8
If at first you don't succeed, don't try skydiving
colinb17 is one of the sharper tools in the shedcolinb17 is one of the sharper tools in the shedcolinb17 is one of the sharper tools in the shedcolinb17 is one of the sharper tools in the shedcolinb17 is one of the sharper tools in the shedcolinb17 is one of the sharper tools in the shedcolinb17 is one of the sharper tools in the shedcolinb17 is one of the sharper tools in the shedcolinb17 is one of the sharper tools in the shedcolinb17 is one of the sharper tools in the shedcolinb17 is one of the sharper tools in the shed
colinb17's Avatar
colinb17's Tacoma Gallery
sorry to thread jack, but it's a similar question. the trd shocks are the same way, i found that out, but then i was trying to actually get the nut off, i ran out of place to grab on top to keep the shaft from spinning. i ended up wrapping up part of an old rubber bycicle tube around the highest point i could reach on the shaft and grabbing that with a set of pliers...that way it didn't scrape or gouge the shock shaft....is there a better way to get the nut off?
Old 02-04-2010, 06:16 PM   #9
DTacoms is one of the sharper tools in the shedDTacoms is one of the sharper tools in the shedDTacoms is one of the sharper tools in the shedDTacoms is one of the sharper tools in the shedDTacoms is one of the sharper tools in the shedDTacoms is one of the sharper tools in the shedDTacoms is one of the sharper tools in the shedDTacoms is one of the sharper tools in the shedDTacoms is one of the sharper tools in the shedDTacoms is one of the sharper tools in the shedDTacoms is one of the sharper tools in the shed
DTacoms's Avatar
DTacoms's Tacoma Gallery
Hold the shaft with the hex key then tighten the nut. I believe the torque is 20 Nm.
Old 02-04-2010, 06:19 PM   #10
on the 5100 is the shat of the axle the same,like on the 5100 do you put a allen wrench on the top.
( I just ordered the procomp light bar with 7'' lights!!!)
Old 02-05-2010, 07:18 AM   #11
Fortech is one of the sharper tools in the shedFortech is one of the sharper tools in the shedFortech is one of the sharper tools in the shedFortech is one of the sharper tools in the shedFortech is one of the sharper tools in the shedFortech is one of the sharper tools in the shedFortech is one of the sharper tools in the shedFortech is one of the sharper tools in the shedFortech is one of the sharper tools in the shedFortech is one of the sharper tools in the shedFortech is one of the sharper tools in the shed
Fortech's Avatar
Fortech's Tacoma Gallery
The shaft is supposed to spin freely, if that is what the question above was really asking by referring to "tight".
That chrome shaft is attached to the piston/valves inside of the shock barrel that moves up and down inside the barrel containing oil and gas under pressure. It is what dampens the vehicles movement over rough terrain.
Old 02-05-2010, 07:20 AM   #12
chris4x4's Avatar
I thought he was talking about the nut.
Old 02-05-2010, 09:44 AM   #13
Fortech's Avatar
It's hard to tell exactly what he is referring to as loose. The shaft will still turn with the nut as he describes even if the nut is torqued to spec, this is what I thought he was asking about - but could be wrong.
Old 02-05-2010, 12:05 PM   #14
i put a wrench to the nut and when i went to tighten the nut and the shaft just spun.
Old 02-05-2010, 12:06 PM   #15
chris4x4's Avatar
Yeah...Thats normal. Thats why you have to hold the shaft with a 5mm Hex
Old 02-05-2010, 12:08 PM   #16
ok thank you, when it stops raining i will go take a look.
Old 02-05-2010, 12:10 PM   #17
chris4x4's Avatar
You will see a hole in the top of the shaft. A 5mm hex fits inside it. Then use an open wrench to tighten the nut.
Old 02-05-2010, 12:12 PM   #18
ok cool thank you.
Old 12-15-2012, 06:35 PM   #19
Johnnyh is on a distinguished road
Johnnyh's Tacoma Gallery
I thought it would better to post in this then start up another, but what would one do with a 5100 and no hex bolt spot up top with the bolt maxed out and spinning. Pic included to limit confusion. Tried channel locks around the boot and around a rubber grip but no luck.
Old 12-15-2012, 06:44 PM   #20
DDD DDD is offline
Shine bright like a hymen
DDD is one of the sharper tools in the shedDDD is one of the sharper tools in the shedDDD is one of the sharper tools in the shedDDD is one of the sharper tools in the shedDDD is one of the sharper tools in the shedDDD is one of the sharper tools in the shedDDD is one of the sharper tools in the shedDDD is one of the sharper tools in the shedDDD is one of the sharper tools in the shedDDD is one of the sharper tools in the shedDDD is one of the sharper tools in the shed
DDD's Avatar
DDD's Tacoma Gallery
On 5100 shocks the top of the shaft has a flat spot to hold with a wrench.
Watch this video at the 5:08 mark.
http://youtu.be/vkVLBOnAifc?t=5m6s
shock absorber BOLT???!!! shepnuts 1st Gen. Tacomas 22 03-25-2011 06:57 PM
front shock bolt crazyjeys 1st Gen. Tacomas 4 09-28-2010 04:12 PM
Bolt in shock hoops. Dellosa89 Suspension 22 12-02-2009 05:43 PM
Lower Shock Bolt Kenny650 Suspension 22 08-06-2009 07:44 PM
u-bolt reversal kit with shock mount thenrie Suspension 0 05-05-2009 06:35 PM
