Lots of milky condensation in oil cap and filler neck
Discussion in '2nd Gen. Tacomas (2005-2015)' started by spaz10, Feb 20, 2010.
  1. Dec 27, 2011 at 6:58 AM
    #121
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    Blackstone requests that you drive 10-15 minutes (or was it miles) prior to taking the sample. Its not required and if you dont, they just ask that you note that to account for the moisture that they will come across from taking a cold sample.
  2. Dec 27, 2011 at 7:01 AM
    #122
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    Well there ya go, they account for moisture if its cold. And I assume that means for any engine.
  3. Dec 27, 2011 at 7:12 AM
    #123
    BBY2KS2K
    BBY2KS2K Jon Stewart / Stephen Colbert 2016
    Jason
    Lake Stevens, WA
    2005 PreRunner DC
    16x7.5 TRD Bronze "beadlock" wheels without the beadlocks w/ 265 70 16 Bridgestone Revo II tires (non-winter) 16x8 KMC Enduro w/ 265 70 16 Bridgestone Blizzak DMV-1 tires (winter) McGard Spline Drive lugs and locks, Satoshi Grill, BLHM, blacked out badges, Aries side steps, Smittybilt light bar with PIAA 540 plasma ion fogs, Aero-Turbine muffler
  4. Dec 27, 2011 at 7:27 AM
    #124
    Chris(NJ)
    08 Indigo 4x4 DC OR
    But my point is, if there are other levels found in the oil that are reading high, it may not be directly related to moisture, as everyone is assuming it is. Moisture may be a contributing factor, but not necessarily the entire cause.
  5. Dec 27, 2011 at 8:28 AM
    #125
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    LOL, :confused:. I think we are arguing the same point now? Anyway, like I said before, I think its no big deal.
  6. Dec 27, 2011 at 9:58 AM
    #126
    Chris(NJ)
    08 Indigo 4x4 DC OR
    probably lol
  7. Jan 25, 2012 at 12:16 PM
    #127
    Gwarrior4u
    Gwarrior4u Member
    Paducah, KY
    '10 AC TRD OR
    I have a 2010 Access Cab (V6) and I noticed this last oil change for the first time. My truck has 54K miles (I drive a lot!) I live in Virginia (temp lately in the low 20's), do a fair amount of short (few miles) trips and while it gets warm, it doesn't get *hot*. I use Castrol Edge and change the oil religously every 5K. It's good to know it's not uncommon, it kind freaked me out to see that gunk in there. I'd be up for doing the pipe insulation to the filler neck if anybody notices that helps!
  8. Feb 8, 2013 at 7:21 AM
    #128
    nlic1995
    nlic1995 New Member
    Mark
    Somerset, MA
    05 TRD Sport
    I have the white gunk under the filler cap and in the filler neck as well. I was advised by a mechanic at my work this morning that it's condensation from temp. change inside the engine. I've owned the truck since March and never saw that before when I've done oil changes. But then again it wasn't as cold out. I live in MA and we've had a cold snap with mornings in the single digits. I'm aware that when metal goes through extreme temp. changes is forms condensation, but it's nice to hear others have the same issue and it's not a major problem. Thanks guys.
  9. Feb 20, 2013 at 3:39 PM
    #129
    K3tsurui
    K3tsurui Well-Known Member
    Ricky
    Upstate NY
    Seeing this issue reminds me of a problem I've seen when someone added motor oil into their brake reservoir. You'll get a similar milky mayo substance. I believe the term for this is contamination.
    There is nothing "NORMAL" about water mixing in your motor oil! Just counting the people from this one thread that have seen this would make me believe that there is a defect out there. I am only one example but I drive less than 5 mins to and 5 min from work every day, live in Upstate NY where it gets relatively colder than most of the states, have done 2 oil changes since bought new and I do NOT have mayo in my oil.
    EDIT--- I LIED!!! I just went outside to check under the cap and can see very little but visible "mayo". WTF MAN!!
  10. Feb 20, 2013 at 5:05 PM
    #130
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    It is normal for that type of driving... like has been repeated many times.
  11. Feb 18, 2014 at 5:00 PM
    #131
    skycap
    skycap New Member
    Michael
    Waldorf Md.
    09 prerunner
    volant cold air, tono pro cover
    Hi All, New member here, I found this tread very helpful, I just did the second oil change on my 65,000 mile new to me Taco. I saw the filler neck and cap thought head gasket! The truck is under warranty till 100,000 but I still thought the worst. Seems like this is normal (thank goodness) but I will go talk and show the service writer the cap to hear what spin he tells me. As for the design problems that were discussed in this forum, could it be it was designed to have the moisture go in the fill neck verses somewhere else? Just a thought, Thanks Taco people.:p
  12. Feb 18, 2014 at 5:04 PM
    #132
    Navar
    Navar Well-Known Member
    Steve
    Corona CA
    07 Tacoma TRD Sport 4x4
    Washed it, Icon suspension, Icon UCA
    Milky oil is not normal! I would ask for a better explanation for this "normal" I am kind of leaning towards coolant in the oil? If its condensation then where is it coming from?
  13. Feb 18, 2014 at 5:05 PM
    #133
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Read the WHOLE thread...
  14. Feb 18, 2014 at 5:16 PM
    #134
    Agent Smith
    Agent Smith Always outnumbered, never outgunned
    05 TRD Offroad Ivan Stewart Edition
    Toytec lift,FJ Anthracite wheels wrapped in BFG A/T 265/75/16's,WAAG Brush Guard, IPF 868's,sleeved fog lights
    The oil on my dipstick is fine. The FILL CAP has the milky residue. Like has been stated, I drive a lot of short trips, this is common.
  15. Feb 18, 2014 at 7:04 PM
    #135
    Navar
    Steve
    Corona CA
    OK lol
  16. Feb 18, 2014 at 7:09 PM
    #136
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    5100's and 883 OME Coils TRD Exhaust Deaver 1.5" AAL Rear Differential Breather Extension, 4WD Light, Tailgate Pipe clamp, Fog lights on while High Beams on, Carrier Bearing flip
    Holy crap burn it before it spreads....
  17. Feb 18, 2014 at 9:39 PM
    #137
    Foihdzas
    Foihdzas VA7PTZ
    Danny
    B.C Canada
    2010 Dbl Cab 5' Box 6 Speed
    2010 Tacoma, sold...
    :rofl:
  18. Feb 18, 2014 at 10:05 PM
    #138
    cheeseit
    cheeseit Well-Known Member
    Vancouver B.C.
    2005 SR5/TRD OR Tacoma
    3 inch toytec lift
    lol I noticed this on my last oil change and it went literally nearly word for word exactly like this thread.
    On a slight tangent would a Blackstone Labs test be worth the money? I'm thinking about doing it but idk.
  19. Feb 19, 2014 at 5:53 AM
    #139
    BBY2KS2K
    Jason
    Lake Stevens, WA
    2005 PreRunner DC
    That's up to you. If it won't put you out or you want some piece of mind, I say go for it. I'm the guy that posted the picture of the nasty oil cap and the Blackstone report above. I did it out of curiosity and to prove to the skeptics my truck was fine. That was four years ago and my truck still runs like a top (and still has the crap build up under the cap during the winter.)
  20. Feb 20, 2014 at 5:05 AM
    #140
    nlic1995
    nlic1995 New Member
    Mark
    Somerset, MA
    05 TRD Sport
    I have an 05 4.0 Tacoma. I've had it for almost two years. My first winter oil change, I almost lost my mind when I saw the cream under the cap. I checked here and spoke with some mechanics at work. Everyone assured me it was harmless condensation not burning off due to short trips to work every day. Sure enough, when summer came the condensation went away. Now that we're back in the dead of winter, it's back. If the oil itself is milky, you have a problem. If the oil is clean and it's only the gunk under the cap and in the filler neck, no worries.
