Increasing rear end travel
Old 04-01-2010, 01:37 PM   #1
Mxpatriot [OP] Mxpatriot is offline
distinguished bongo truck art critic
Mxpatriot is one of the sharper tools in the shedMxpatriot is one of the sharper tools in the shedMxpatriot is one of the sharper tools in the shedMxpatriot is one of the sharper tools in the shedMxpatriot is one of the sharper tools in the shedMxpatriot is one of the sharper tools in the shedMxpatriot is one of the sharper tools in the shedMxpatriot is one of the sharper tools in the shedMxpatriot is one of the sharper tools in the shedMxpatriot is one of the sharper tools in the shedMxpatriot is one of the sharper tools in the shed
Mxpatriot's Avatar
Army:
Mxpatriot's Tacoma Gallery
So right now I'm on C/O's with UCA's up front and All Pro's 1.5'' leaf pack, Bilstein 5100's, Timbren bump stops, and a u-bolt flip kit in the rear.
I'm not going to go LT because the truck has 80K miles on it and it's not worth it to me to put that much money into it at this point. Next truck...
I'd like to get some more travel out of the rear end, but I want to keep the truck level. If I get the 3'' leaf pack from All Pro my rear end would ride a little high. My C/O's are cranked to about 2.5'' or so and the truck sits level right now.
What options do I have, if any? The Timbren bumpstops seem to take up some of my travel, but they also seemed to help a lot with absorbing harder hits.
I even thought about putting a spacer between the coil over and the shock mount and then running taller leaf springs (or just adding a leaf to my leaf pack). Would that work well? I know it wouldn't increase travel at all in the front, but it would keep the truck level and shouldn't change the feel of the front end, right?
Old 04-01-2010, 02:15 PM   #2
nvdeserted is one of the sharper tools in the shednvdeserted is one of the sharper tools in the shednvdeserted is one of the sharper tools in the shednvdeserted is one of the sharper tools in the shednvdeserted is one of the sharper tools in the shednvdeserted is one of the sharper tools in the shednvdeserted is one of the sharper tools in the shednvdeserted is one of the sharper tools in the shednvdeserted is one of the sharper tools in the shednvdeserted is one of the sharper tools in the shednvdeserted is one of the sharper tools in the shed
nvdeserted's Avatar
nvdeserted's Tacoma Gallery
Ubolt flip kit? Not familair with that.
Maybe you mean shackle flip? if yes then you could probably find some shackles that will allow for more flex (droop anyway, your bumpstops always limit the tuck). Some shackles have flexy bushings that allow more flex, and the Revolver shackles extend and twist (mad droop!) but I'm not sure about a Tacoma application.
If you do not have a shackle flip kit on there, that's your next best move. But a shackle flip kit will add 1/2" lift... somthing to think about.
Also, I don't know much about the 5100's but they night be a limiting factor on your droop too, depending on how much travel they allow for.
Old 04-01-2010, 02:28 PM   #3
Zombie Runner's Avatar
Air Force: AMMO (2W0)
x2 on the shackle flip kit and ditch the timbrens, add some air bump cans.
http://www.polyperformance.com/shop/...tops-p-63.html
Old 04-01-2010, 02:36 PM   #4
Dan
YotaDan is one of the sharper tools in the shedYotaDan is one of the sharper tools in the shedYotaDan is one of the sharper tools in the shedYotaDan is one of the sharper tools in the shedYotaDan is one of the sharper tools in the shedYotaDan is one of the sharper tools in the shedYotaDan is one of the sharper tools in the shedYotaDan is one of the sharper tools in the shedYotaDan is one of the sharper tools in the shedYotaDan is one of the sharper tools in the shedYotaDan is one of the sharper tools in the shed
YotaDan's Avatar
YotaDan's Tacoma Gallery
[quote=Mxpatriot;1608696]I'd like to get some more travel out of the rear end, but I want to keep the truck level.quote]
To increase down travel with out changing ride height, you will need longer rear shocks. To fit longer rear shocks you will probably need to change the upper mounting location.
Old 04-01-2010, 02:43 PM   #5
Chachie is one of the sharper tools in the shedChachie is one of the sharper tools in the shedChachie is one of the sharper tools in the shedChachie is one of the sharper tools in the shedChachie is one of the sharper tools in the shedChachie is one of the sharper tools in the shedChachie is one of the sharper tools in the shedChachie is one of the sharper tools in the shedChachie is one of the sharper tools in the shedChachie is one of the sharper tools in the shedChachie is one of the sharper tools in the shed
Chachie's Avatar
Chachie's Tacoma Gallery
I was in the same boat as you are but i have the 6" fabtech. I ended up converting the top mount in the rear into a eye mount, putting in fully arched springs and a set of 12" travel 5125's. Helped a ton!
Old 04-01-2010, 02:46 PM   #6
I like ze best!
Rhino8541 is one of the sharper tools in the shedRhino8541 is one of the sharper tools in the shedRhino8541 is one of the sharper tools in the shedRhino8541 is one of the sharper tools in the shedRhino8541 is one of the sharper tools in the shedRhino8541 is one of the sharper tools in the shedRhino8541 is one of the sharper tools in the shedRhino8541 is one of the sharper tools in the shedRhino8541 is one of the sharper tools in the shedRhino8541 is one of the sharper tools in the shedRhino8541 is one of the sharper tools in the shed
Rhino8541's Avatar
Rhino8541's Tacoma Gallery
Got any pictures of your setup?
Old 04-01-2010, 03:30 PM   #7
Chachie's Avatar
Ok i just took these at work, let me know what you would like to see and ill take some with my digi at home (i took these with my phone.)
Old 04-01-2010, 04:19 PM   #8
Mxpatriot's Avatar
Army:
It's a U bolt flip, not a shackle. Go look at a your truck and see how the bolts point downward, under the rear axle. Mine are the opposite, with only the smooth, rough "U" of the "U" bolt protruding down.
Old 04-01-2010, 04:32 PM   #10
I like ze best!
Rhino8541's Avatar
Awesome!! Do you think you could PM me some pictures of your truck from further away, I noticed your exhaust is cut right behind that hangar, and I was thinkin about doin the same thing(only duals) and wanted to see how it would look.
Old 04-01-2010, 04:37 PM   #11
nvdeserted's Avatar
Gotcha, ground clearance thing. Where'd you get that? or did you just flip the plate on top and get some U shaped U-bolts?
Old 04-01-2010, 09:23 PM   #13
Crankey Old Yacht Jockey
Timber has a brilliant futureTimber has a brilliant futureTimber has a brilliant futureTimber has a brilliant futureTimber has a brilliant futureTimber has a brilliant futureTimber has a brilliant futureTimber has a brilliant futureTimber has a brilliant futureTimber has a brilliant futureTimber has a brilliant future
Timber's Avatar
Timber's Tacoma Gallery
FWIW. Could be it's not done yet or I just missed them but I don't see any bump stops there... Those shocks don't like to bottom out and will be toast after the first couple times. Order some tall bumpstops or raise your stock ones, something to stop up travel before the shock bottoms out.
Old 04-01-2010, 09:29 PM   #14
Chachie's Avatar
Will do in the morning on the PM. as fr as the bumps go, I ordered the specs on these shocks so the the leaf would stop travel before the shock bottomed out.
Old 04-01-2010, 11:11 PM   #16
Almost there
08pretaco is one of the sharper tools in the shed08pretaco is one of the sharper tools in the shed08pretaco is one of the sharper tools in the shed08pretaco is one of the sharper tools in the shed08pretaco is one of the sharper tools in the shed08pretaco is one of the sharper tools in the shed08pretaco is one of the sharper tools in the shed08pretaco is one of the sharper tools in the shed08pretaco is one of the sharper tools in the shed08pretaco is one of the sharper tools in the shed08pretaco is one of the sharper tools in the shed
08pretaco's Avatar
08pretaco's Tacoma Gallery
thats way hot
Old 04-01-2010, 11:30 PM   #17
Go home if you don't like guns liquor and whores.
maxamillion2345 is one of the sharper tools in the shedmaxamillion2345 is one of the sharper tools in the shedmaxamillion2345 is one of the sharper tools in the shedmaxamillion2345 is one of the sharper tools in the shedmaxamillion2345 is one of the sharper tools in the shedmaxamillion2345 is one of the sharper tools in the shedmaxamillion2345 is one of the sharper tools in the shedmaxamillion2345 is one of the sharper tools in the shedmaxamillion2345 is one of the sharper tools in the shedmaxamillion2345 is one of the sharper tools in the shedmaxamillion2345 is one of the sharper tools in the shed
maxamillion2345's Avatar
maxamillion2345's Tacoma Gallery
http://s983.photobucket.com/albums/a...hackle%20Flip/
http://www.armortechoffroad.com/index.html
Old 04-02-2010, 12:12 AM   #18
Almost there
08pretaco's Avatar
Justin do you have any pictures of them flexed?
Old 04-02-2010, 09:22 AM   #19
Chachie's Avatar
Here are some waay berrer pics. Ill get some flexed out pics when i get home tonight.
Feeler: 4.10 gears front and rear, non locker rear end 97yota4wd Buy / Sell / Trade 14 10-26-2011 01:29 PM
Increasing Rear Braking montanabay 1st Gen. Tacomas 1 06-11-2010 10:12 AM
1st gen rear end vs 2nd gen rear end Usurper 2nd Gen. Tacomas 10 03-18-2010 01:06 PM
Rear end not holding it's end of the bargain... Jacob 1st Gen. Tacomas 4 10-13-2009 04:23 PM
Need some help with rear shock travel Carson Suspension 15 07-14-2009 03:40 PM
