Alright I'm sick of this...how do I clean this???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tmat, Apr 2, 2010.
  1. Apr 2, 2010 at 3:01 PM
    tmat
    tmat [OP] Well-Known Member
    Treavor
    Cypress, CA
    07 Regular Cab, PreRunner
    BHLM, de-badged, custom Manoukian flowmaster exhaust system, Bilstein 5100 front adjustable shocks set at 1.75", "smoked" foglights, Satoshi grille mod, 265/75r16 BFG T/A KO tires, AFE Pro Dry S air filter, solid rear window, Weathertech floor liners and painted grill surround
    Okay so everybody says to buy the engine cleaner and wipe it down with a damp rag, but if you can see by the pictures I have a lot to clean in many hard to reach places.
    I know many of you do desert runs and I'm sure you get this all the time....what do you guys do? Do you take it to those self car wash places and spray your engine bay with that stuff? I don't know. Help!
    Thanks for the help guys
  2. Apr 2, 2010 at 3:02 PM
    Andrew H
    Andrew H What is this "search" you speak of?
    Dirty Tucson
    2017SSMDCSBTRDS
    i just see red Xs
  3. Apr 2, 2010 at 3:05 PM
    JackedTaco
    JackedTaco Well-Known Member
    Johnny
    USA, Earth...
    07 Access Cab TRD Off Road
    Weathertech Mats, Thule rack custom install on bed caps. Foglite anytime mod. K&N air filter. Rear leaf TSB. Tinted passenger windows. TRD CAt Back exhaust. Bilstein 5100 front shocks at 1.75".
  4. Apr 2, 2010 at 3:07 PM
    Blackshirts
    Blackshirts Well-Known Member
    TX
    09 PreRunner-Totaled. 2016 SR5 Blue DC
    Stuff
  5. Apr 2, 2010 at 3:08 PM
    tmat
    Treavor
    Cypress, CA
    alright. hold on a sec.
  6. Apr 2, 2010 at 3:08 PM
    Project.paradigm
    Project.paradigm Well-Known Member
    Oil Country,Alberta, Canada
    04 TRD 4X4 Dub cab
    Airlift rear air bags. Hood struts. sockmonkey bedside decal. TRD supercharger(not installed). Deckplate. Grey wire mod. Extended rear diff breather. 6000k HIDS. 18"Magnaflow. Truxxx 3" level kit. (Temporary) Wet Okole seat covers. BoxRocket bed rack. Bora 0.75 wheel spacers All pro sliders. BAMF BPV. B&M trans cooler.
    Did you try using a pressure washer?
  7. Apr 2, 2010 at 3:09 PM
    tmat
    Treavor
    Cypress, CA
    there we go. sorry about that.
  8. Apr 2, 2010 at 3:12 PM
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    pressure washer... on low
  9. Apr 2, 2010 at 3:14 PM
    tmat
    Treavor
    Cypress, CA
    alright. then I read somewhere to then turn on the engine after that and let it run for a little?
  10. Apr 2, 2010 at 3:17 PM
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    yeah, I guess to let it dry but I can't see how that really matter
  11. Apr 2, 2010 at 3:18 PM
    Blackshirts
    TX
    Stuff
    You bought engine degreser right. Leave truck on spray the engine stuff on then like solus694 said low pressure. Once clean I used to spray armoral all over. of course engine still on then rev engine few times. you want to leave your engine on if you get your plugs too wet it wont start.
  12. Apr 2, 2010 at 3:25 PM
    tmat
    Treavor
    Cypress, CA
    Alright got it
    • leave engine on
    • spray degreaser
    • pressure wash all the stuff off on low
    • keep engine running to dry stuff off
    Thanks for the info guys!
  13. Apr 2, 2010 at 3:29 PM
    Blackshirts
    TX
    Stuff
    Sounds good. Just make sure to leave it on during and afterwards. When I used to detail, engine was always first then we washed and waxed outside with engine still on.
  14. Apr 2, 2010 at 3:30 PM
    tmat
    Treavor
    Cypress, CA
    awesome. thanks for all the help guys.
  15. Apr 2, 2010 at 3:41 PM
    Tillers_Rule
    Tillers_Rule ......................
    Jeff
    San Diego
    4x4 Sport, debadged
    Icon coil overs up front, Total Chaos UCA, Icon remote reservoir in the back with Deaver 11 pack leafs. Sunroof, Hella 500's behind grill.
    Exactly, just leave it running and you can spray the whole thing. Let's see some after pictures:D
  16. Apr 2, 2010 at 3:43 PM
    tmat
    Treavor
    Cypress, CA
    I totally agree with you. After I came back from the trip that did that to my engine bay I drove around for about a month and decided to get the AFE pro dry-s air filter and when I put it in I noticed a seriously large improvement in throttle response. The air filter that came with the truck was super dusty and dirty.
    But then again detailers swear that if you have a clean engine bay your car will run better.
  17. Apr 2, 2010 at 3:46 PM
    tmat
    Treavor
    Cypress, CA
    fsho fsho
  18. Apr 2, 2010 at 8:05 PM
    Marc M
    Marc M Dirty White Boy
    Marc
    Washington, Pennsylvania
    '06 TRD O/R Dbl-Cab
    TRD Cat-Back, TRD CAI, 3" Lift, ATX Chambers, Color matched Grille and Door Handles, Scooped Hood, GrillCraft upper and lower, DTRL, Foglight Mod, Redline Hood Struts, 20% Tint all around, SGII, Blacked out dash, Extang Full-Tilt, etc, etc, etc.
    Don't spray cleaner on a warm engine it'll just cook on.
    I clean my engine by spraying heavy duty simple green all over the engine. I let it soak for 10 or 15 minutes then just spray it off with a regular hose.
    It works very well.
    Marc M
  19. Apr 2, 2010 at 8:12 PM
    dimitrik
    dimitrik Well-Known Member
    Dimitri
    Quebec
    09 Access Cab TRD-Offroad
    AllPro Skidplate
    Make sure you cover any electric components with plastic bags and rubber bands. Especially your alternator!
  20. Apr 3, 2010 at 5:00 AM
    pauldotcom
    pauldotcom Well-Known Member
    Paul
    MA
    2012 Toyota Tacoma 4x4 TRD Sport Quad Cab
    OEM Roof Rack, Bilstein 5100's @ 1.75", Rear 1" block, TRD 17' Wheels
    Leave enging on? LOL!! NO NO NO!. Clean it while its cool, Cover up any expensive electrical components under the hood, then clean it. After you are done, either dry with compressed air (the best way) or let it dry on it's own. Dont run it or turn it on until its dry!
    The last thing you want to do is clean it while the engine is running! If you do, you run the risk of shorting out just about everything. Water is an EXCELLENT conductor and can fry stuff quite easily.
