U-Joint Replacement
Discussion in '2nd Gen. Tacomas (2005-2015)' started by fixedforbroke, May 4, 2010.
  1. Jan 7, 2014 at 7:02 AM
    #81
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    I will take an alt. for $5
  2. Jan 7, 2014 at 7:13 AM
    #82
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Yes, I would not buy the Dorman bearing, that thing is a piece of shit. They have a lifetime warranty but it's a crap bearing. I went through 2 of them in under 1,000 miles on each one. Rock Auto honors the warranty, sent me a new one each time but I finally got fed up and bought an OEM bearing. Rock Auto was great, they gave me a store credit and bought the bearing back from me.
    Here's the thing though, the Dorman bearing got rid of my shutter, it came back with the OEM bearing. The problem with the Dorman bearing (at least the problem I had) was they don't put enough grease in them from the factory and it's a sealed bearing. Within a few hundred miles, both were squeeling like stuck pigs.
  3. Jan 7, 2014 at 7:29 AM
    #83
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Roger that. I hadn't looked at pricing on RockAuto just yet. The driveshaftparts bearing is cheaper anyways. Ordered everything today.
  4. Jan 7, 2014 at 9:01 AM
    #84
    Pugga
    Massachusetts
    Damn, wish I had known about that. I blew $150 on the OEM bearing only to have my vibes come back :mad: The Dorman bearing from Rock Auto was $40 when I bought it.
  5. Jan 7, 2014 at 9:46 AM
    #85
    Hans Moleman
    Hans Moleman Well-Known Member
    Bay Area, CA
    2023 F-150 Powerboost
    driveshaftparts.com is $25:eek:
  6. Jan 9, 2014 at 2:21 PM
    #86
    Sandman614
    Tim
    '06 SR5 Off Road
    Just got these in. Waiting on the carrier bearing.
  7. Jan 9, 2014 at 3:18 PM
    #87
    brutalguyracing
    F.U> GUYZ
    broken mods
    WOOT
    REMEMBER MARK EVERYTHING BEFORE YOU REMOVE IT
    AND PACK THE NEEDLES IN THE CUP SO U DON'T LOOSE ANY ON INSTALL
    AND BE PREPARED FOR GREASE TO SHOOT OUT THE ZERK OPENINGS AS YOU INSTALL THEM
    ASK ME HOW I KNOW......
    I USED A 17MM DEEP SOCKET AND A BFH AND MY PLUMBING VISE MADE QUICK WORK OF IT
    AND TO REMOVE THE BEARING I FOUND A PULLER USELESS AND USE A BFH AND A COLD CHISEL AND SHE CAM RIGHT OFF
  8. Jan 9, 2014 at 6:38 PM
    #88
    Sandman614
    Tim
    '06 SR5 Off Road
    Check, check, check. I think I'll see these marks.
  9. Jan 9, 2014 at 7:00 PM
    #89
    brutalguyracing
    F.U> GUYZ
    broken mods
    make sure it no wash away with say brake cleaner
    ask me how i know:rolleyes:
  10. Jan 9, 2014 at 7:17 PM
    #90
    Sandman614
    Tim
    '06 SR5 Off Road
    Lol
  11. Jan 11, 2014 at 11:52 AM
    #91
    Sandman614
    Tim
    '06 SR5 Off Road
    I'm ready to get to work.
  12. Jan 11, 2014 at 3:23 PM
    #92
    Sandman614
    Tim
    '06 SR5 Off Road
    All done, no hiccups, all smooth.
  13. Jan 11, 2014 at 5:24 PM
    #93
    brutalguyracing
    F.U> GUYZ
    broken mods
    wooot
  14. Aug 15, 2014 at 4:49 PM
    #94
    Bscheffer
    Bscheffer New Member
    Ben
    Florida
    08 4L PreRunner 2wd
    Hey I'm starting to get this metal grinding noise as everyone else described and it sounds like a ujoint so I'm going to replace all 3. 110k 08 dblcab 2wd PreRunner. I've watched a few YouTube videos but what do you mean by mark everything? Mark the shaft coming out of the back of the tranny/front of rear diff in line to the drive shaft so that when it all goes back in its the same way it came out?
  15. Aug 16, 2014 at 4:36 AM
    #95
    clifpaul
    clifpaul Well-Known Member
    North Texas
    06 access cab 5 lug
    Too many to fit here now!
  16. Aug 16, 2014 at 9:16 AM
    #96
    Johnsredline
    Johnsredline Well-Known Member
    North Las Vegas
    Barcelona Red- Method Double Standards, Flowmaster Exhaust, K&N intake, black headlights and raptor style grille, ICON stage 4 suspension, allpro sliders
    i had the most forward ujoint on the driveshaft go out. It honestly sounded like something in the diffrential was messed up. i was super worried. I then got bad vibrations within a few days. And popping that went insync with wheel movement. I actually got in the bed and had the wife drive me around the neighborhod and figured out exactly where the noise was.
    Also, after i greased the culprit u joint and drove around a little. It flung most all the grease out of it. That is when i knew FOR SURE which joint was bad. The other two held the grease.
  17. Mar 19, 2015 at 6:31 PM
    #97
    Grim
    Grim Active Member
    Will
    Lancaster, PA
    Thought I would chime in here, even though it's an older thread. I had vibration issues in mine while off the gas and coasting, and on the gas at lower rpm's. Took the truck to the dealer today and they said both joints on the rear shaft had some play (regular cab, no carrier). The estimate they gave me was insane. To replace both joints and labor it would have cost me......... $541.00! I asked the service writer if he was trying to be funny. He did tell me that the tech knocked half of the labor off of one of the joints as he felt bad about charging the full labor to replace both. Go figure... I'm not sure if those joints were gold plated, should have asked.
  18. Jun 26, 2015 at 6:36 PM
    #98
    OKJC
    OKJC Well-Known Member
    Justin
    NWArkansas
    '10 SC 4x4 TRD Sport
    I guess I need to go check mine. My symptoms are very rough vibrations upon acceleration from roughly 5-10MPH, and no real vibrations when I'm coasting, but there is a loud clunk. I'm at 122k and have been having a lot of issues lately. Seemingly on a daily basis I have new issues arising.
  19. Jul 7, 2015 at 12:10 AM
    #99
    EnderXVI
    EnderXVI New Member
    Derek
    2000/ SR5/ 3.4L/ Extended cab/ 4X4/ 31 X 10.5 R15
    Grill block
    Last time i heard a clunk in a driveshaft was when my Ranger was missing a quarter of one of my caps. Check that quick! Pump all your joints full of grease, take a drive around the block, and then look for the one that puked its grease.
  20. Jul 22, 2015 at 8:08 PM
    #100
    TaylorU
    TaylorU KC HiLiTES Vendor
    Taylor
    Flagstaff, Arizona
    2010 4x4 TRD Off-Road
    ADS 2.5" coilovers, Light Racing UCAs, 2.125" rear ADS shocks, Raptor-Style Grille using Homertaco mesh and BAMF letters, MB 352 wheels, 285/75r16 Cooper ATPs, Mini D2S 3.0 HID Projectors retrofitted, KC Flex 20", KC Pro6 light bar, KC G4 LED fog lights, Pelfreybilt front bumper
    So maybe you guys in this thread can help me out. I have read through this thread and I originally thought I may have a bad u joint but I'm not sure. The symptom is that I am getting a vibration through the pedal and floorboard whenever I depress the gas pedal, even slightly, at about 65mph+. I am not getting vibrations below this speed whether or not I am on the gas pedal. I will crawl under and check for play by twisting and also pulling and pushing front to rear (I think I read the truck must be in neutral for that part). Anyone with ideas or suggestions?
