Floor Jack - Steel vs. Aluminum
Discussion in '2nd Gen. Tacomas (2005-2015)' started by raycie, Jun 8, 2010.
Floor Jack
Poll closed Jul 8, 2010.
  1. Steel
    45 vote(s)
    50.6%
  2. Aluminum
    44 vote(s)
    49.4%
  1. Jun 8, 2010 at 8:38 PM
    raycie
    raycie [OP] Well-Known Member
    Oahu, HI
    2013 DCLB / 2016 4R Trail
    In need of $$$
    Which one? Is there a preference as to durability?
  2. Jun 8, 2010 at 8:45 PM
    MxRacer190
    MxRacer190 Well-Known Member
    Georgia
    06 SR5 4x4 Indigo
    I would think steel.
  3. Jun 8, 2010 at 8:47 PM
    thekid1550
    thekid1550 Well-Known Member
    bronx ny
    trd sport
    weathertech digital fits,oem hood deflector,clarion nx409,metra dash kit,20% tint on front windows,ddm tuning 6000k hi/lo hids,ddmtuning 6000k fogs,trd 2nd gen intake,alpine pdx-5,subthump access cab box,tacotunes amp wiring kit,image dynamics idq10 2 ohm subwoofer
    i dont like having to lug shit around especially after im done working on it so I like aluminum
  4. Jun 8, 2010 at 8:53 PM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig...
    is it going to be primarily a garrage jack, or are you going to take it with you a lot. if the first case, steel, if the second, aluminum. the most important thing with either one is to get one that fits your weight capacity needs
  5. Jun 8, 2010 at 9:21 PM
    sachou
    sachou Well-Known Member
    Sam
    Richland, Washington
    2006 TRD Sport Acc Cab 4x4 V6 6spd
    When it comes to jacking, you shouldn't skimp on strength, and since most of the time floor jacks aren't needed to be portable, I would definitely say steel.
  6. Jun 8, 2010 at 9:22 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    As long as it meets your load capacity I'd go with the aluminum. The rating is really all that matters. Lighter means more energy for further mods.
    Plus, the engineering, piston used in it, and tested rating on a good aluminum jack will beat out an el cheapo steelie. Just cause it's steal doesn't mean it has good welds, good tested design, ect...
  7. Jun 8, 2010 at 9:22 PM
    jdkeller
    jdkeller How many words can be fit in this s
    Jonathan
    Inland Empire, Ca
    2008 Tacoma Prerunner TRD Offroad
    Dome light LED, 6000k HID Headlights and fogs, Grillcraft black mesh, rear 5100's, Total Chaos UCA's, 285/75/16 BFG KM2's, Spidertrax spacers, Blacked out emblems, cb,kenwood tm270 ham radio, All Pro 3" leaf pack, Fox 2.0 coilovers, Revenge Fab Sliders, u bolt flip kit, Pioneer avh4200, bed bar with light and antenna, Wet Okoles, Weathertech Mats, Wet Okole Armrests, Rear KR Fab bumper, bed mat, N-Fab spare tire carrier with full size spare on 16" TRD rim, Bedlinered flares and grille. Camburg Spindles, All Pro front fenders.
    What Colin said
  8. Jun 8, 2010 at 9:28 PM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    Steel.
    It's a jack, not an aircraft. It's for lifting a 3400lb machine. Not swinging attempting to hit home runs.
  9. Jun 8, 2010 at 9:29 PM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    X2
  10. Jun 8, 2010 at 9:30 PM
    jdkeller
    Jonathan
    Inland Empire, Ca
    If the aluminum couldn't hang they wouldn't have engineered it.
  11. Jun 8, 2010 at 9:32 PM
    HBMurphy
    HBMurphy Ban Pending
    Paul
    So California Coast
    09 Off Road Delete Model
    None
    What JD said
  12. Jun 8, 2010 at 9:33 PM
    Incognito
    VA
    I am guessing that an aluminum jack rated at 8000 pounds and a steel jack rated at 8000 pounds, the steel would be sturdier?
  13. Jun 8, 2010 at 9:35 PM
    mach1man001
    mach1man001 eh whatever
    Rob
    Blackstone, MA
    '09 Sport DCLB Met Grey
    Toyota bed mat (1st mod), Toyota all season floor mats, Rear spring TSB, Map light mod, Fog light mod, Putco yellow fog bulbs, Weather Tech window vents, Extra d-rings, Mounted mag light, TRD CAI with AFE pro dry filter, '05 front mud flaps (winter only), 2 set's of wheels/tires, 285/75/16 Hankook MT's, Black Painted 1st Gen TRD wheels (wheeling set) Black powder coated FJ Cruiser with 265/70/17 BFGoodrich KO2's (everyday), painted center of grill & bumper black, Devil horns, OME with 885's + spacers front, OME shocks w/OMD designed rear springs, Front diff drop, Rear trailer plug relocate, ATO IFS skid, Relentless Trans & Transfer skids, BAMF bolt on rock sliders, Relentless tailgate reinforcement, Uniden 75 CB radio, BAMF antenna bracket, TRD exhaust, high lift jack w/ATO mounts. And of course ProEFX Towing Mirrors!
    My only input to this discussion is that plenty of things have been engineered but have still failed.
  14. Jun 8, 2010 at 9:39 PM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    All I can say is are you that much of a wuss that an extra 20lbs of jack is going to break you?
    Seriously, it's probably less weight than that. ;)
    I kinda like that it's heavier. It's less likely to get knocked and moved about with the extra mass it has.
  15. Jun 8, 2010 at 9:43 PM
    HBMurphy
    Paul
    So California Coast
    None
    What JD said
  16. Jun 8, 2010 at 9:45 PM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    we use aluminum floor jacks on the race truck and all our chase trucks...
    havent had any issues, and its nice being light enough to bolt into the bed...
    makes it convenient too when changing a tire or helping out a friend change their tire on the side of the road...
  17. Jun 8, 2010 at 9:46 PM
    jdkeller
    Jonathan
    Inland Empire, Ca
    I agree with you krazie,
    I have a big heavy steel one. I love it. Going to mod days I have lugged it around no problem. But I will be buying an aluminum one soon for offroading.
    That's why I said what Colin said. At home I would use steel. Offroad aluminum.
    But I wouldn't hesitate to use aluminum over steel if that's all I had.
    But on a side note material science has taken off.
    And to machman, thts why I'm becoming an engineer. To remedy that : )
  18. Jun 8, 2010 at 9:56 PM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Sorry, I just hear about weight all the time from work. Oh why do we have this in the trauma bag, we already have this in there.
    Fucking redundancy. What if that doesn't work. We have a back up, otherwise we look like tools going...hmm...that didn't work, plan B? We have no plan B.
    Our fucking patient weights 300+lbs and you're concerned with a 250 gram manual suction?
  19. Jun 8, 2010 at 9:58 PM
    Marc M
    Marc M Dirty White Boy
    Marc
    Washington, Pennsylvania
    '06 TRD O/R Dbl-Cab
    TRD Cat-Back, TRD CAI, 3" Lift, ATX Chambers, Color matched Grille and Door Handles, Scooped Hood, GrillCraft upper and lower, DTRL, Foglight Mod, Redline Hood Struts, 20% Tint all around, SGII, Blacked out dash, Extang Full-Tilt, etc, etc, etc.
    I have 2 steel ones and an aluminum one. I have assigned the aluminum one to light duty work like lifting the lawn tractor after the lifting cup edges snapped off.
    I know many people use them, even the good ole Nascar boys, but I feel a little less confident in them since that happened.
    Marc M
  20. Jun 8, 2010 at 10:01 PM
    HBMurphy
    Paul
    So California Coast
    None
    What Mike said! I have had the pleasure to use Mike's jack and if I'm going to 'jack off' in the desert, his is the one I want! - Thanks again Mike! :cool: :)
