4.0 TRD Supercharger + URD pulley??????
Old 06-13-2010, 11:00 AM   #1
High-Gear [OP] High-Gear is offline
Zombie Killer
High-Gear has a brilliant futureHigh-Gear has a brilliant futureHigh-Gear has a brilliant futureHigh-Gear has a brilliant futureHigh-Gear has a brilliant futureHigh-Gear has a brilliant futureHigh-Gear has a brilliant futureHigh-Gear has a brilliant futureHigh-Gear has a brilliant futureHigh-Gear has a brilliant futureHigh-Gear has a brilliant future
High-Gear's Avatar
Law Enforcement:
High-Gear's Tacoma Gallery
I had a TRD supercharger installed on my 09 4.0 V6 when I purchased it, and they reflashed the CPU. I plan on adding a URD pulley once the warranty is up. Has anyone done this? To change the tune, do they just reflash the CPU or do I need to purchase an after market computer? What sort of HP / torque numbers did you get after the swap?
Thanks!
Old 06-13-2010, 11:11 AM   #2
Sua Sponte! RLTW
75thrangertaco is one of the sharper tools in the shed75thrangertaco is one of the sharper tools in the shed75thrangertaco is one of the sharper tools in the shed75thrangertaco is one of the sharper tools in the shed75thrangertaco is one of the sharper tools in the shed75thrangertaco is one of the sharper tools in the shed75thrangertaco is one of the sharper tools in the shed75thrangertaco is one of the sharper tools in the shed75thrangertaco is one of the sharper tools in the shed75thrangertaco is one of the sharper tools in the shed75thrangertaco is one of the sharper tools in the shed
75thrangertaco's Avatar
Army: 101st airborne
75thrangertaco's Tacoma Gallery
Thanks!
re flash or you can do an apr x1 ecu.supposedly 304 hp net with the reflash but wel see when mine gets here and i stick it on the dyno.
Old 06-13-2010, 11:28 AM   #3
Do Work Son!
rossk35 is one of the sharper tools in the shedrossk35 is one of the sharper tools in the shedrossk35 is one of the sharper tools in the shedrossk35 is one of the sharper tools in the shedrossk35 is one of the sharper tools in the shedrossk35 is one of the sharper tools in the shedrossk35 is one of the sharper tools in the shedrossk35 is one of the sharper tools in the shedrossk35 is one of the sharper tools in the shedrossk35 is one of the sharper tools in the shedrossk35 is one of the sharper tools in the shed
rossk35's Tacoma Gallery
You don't need to change anything if you add the 2.85 pulley. I've got the apr one that looks a stock pulley on my truck.
Old 06-13-2010, 01:51 PM   #6
Zombie Killer
High-Gear's Avatar
Law Enforcement:
I thought 304 was just with the TRD supercharger. The URD pulley is suppose to get you another 60+ horsepower from what I have read.
What is the APR One? Can you guys give me a link?
Old 06-13-2010, 03:47 PM   #7
Coupe is one of the sharper tools in the shedCoupe is one of the sharper tools in the shedCoupe is one of the sharper tools in the shedCoupe is one of the sharper tools in the shedCoupe is one of the sharper tools in the shedCoupe is one of the sharper tools in the shedCoupe is one of the sharper tools in the shedCoupe is one of the sharper tools in the shedCoupe is one of the sharper tools in the shedCoupe is one of the sharper tools in the shedCoupe is one of the sharper tools in the shed
Coupe's Avatar
Coupe's Tacoma Gallery
If you have a 2009 or later, there is no APR X-1 available. Which is a shame. It kicks ass.
The connectors at the ECU are different 2009 & up.
Old 06-13-2010, 05:15 PM   #8
Do Work Son!
You don't get 60hp from just a pulley change. You get about 20rwhp. Urd sells the apr 2.85 pulley.
Old 06-13-2010, 05:20 PM   #9
originalthoughts is on a distinguished road
originalthoughts's Tacoma Gallery
CPU...ECU...C3P0...Whatever it takes!
Old 06-13-2010, 05:33 PM   #10
My68ur8trd is one of the sharper tools in the shedMy68ur8trd is one of the sharper tools in the shedMy68ur8trd is one of the sharper tools in the shedMy68ur8trd is one of the sharper tools in the shedMy68ur8trd is one of the sharper tools in the shedMy68ur8trd is one of the sharper tools in the shedMy68ur8trd is one of the sharper tools in the shedMy68ur8trd is one of the sharper tools in the shedMy68ur8trd is one of the sharper tools in the shedMy68ur8trd is one of the sharper tools in the shedMy68ur8trd is one of the sharper tools in the shed
My68ur8trd's Avatar
My68ur8trd's Tacoma Gallery
some have run the pulley without any additional tuning.
it really depends on your intake setup. I have seen some trucks run super lean on the top end with certain intakes ( K&N for one)
many have not had any troubles
I would def tune for it if possible. you cannot reflash again, you will need some sort of additional tuning hardware
this reminds me, I need to put my pulley on.
Justin
Old 07-02-2013, 11:28 AM   #11
cdelgado14 is a splendid one to beholdcdelgado14 is a splendid one to beholdcdelgado14 is a splendid one to beholdcdelgado14 is a splendid one to beholdcdelgado14 is a splendid one to beholdcdelgado14 is a splendid one to behold
cdelgado14's Tacoma Gallery
Does the stock belt fit fine?no problems?
Old 07-02-2013, 12:25 PM   #12
MadToy is one of the sharper tools in the shedMadToy is one of the sharper tools in the shedMadToy is one of the sharper tools in the shedMadToy is one of the sharper tools in the shedMadToy is one of the sharper tools in the shedMadToy is one of the sharper tools in the shedMadToy is one of the sharper tools in the shedMadToy is one of the sharper tools in the shedMadToy is one of the sharper tools in the shedMadToy is one of the sharper tools in the shedMadToy is one of the sharper tools in the shed
MadToy's Tacoma Gallery
Yes. Plenty of room on the tensioner with such a small difference in diameter.....
FS/ URD 5vz Idler Dynamic Tensioner Pulley for TRD Supercharger Jake7 1st Gen Tacoma Marketplace 5 08-26-2012 12:43 AM
Trd supercharger with 2.8" pulley 05tacoma33 2nd Gen Tacoma Marketplace 22 05-04-2012 01:14 AM
Adding TRD Supercharger not sure what size pulley to go with gneitzke Performance and Tuning 4 08-21-2011 06:15 PM
NST Overdrive Pulley set compared to URD 2.8" S/C pulley bcroach78 Performance and Tuning 0 05-13-2011 06:01 AM
TRD 3.4 S/C , URD injectors, 2.2 s/c pulley Doug thorley Headers Cheap for all Bajakbob Buy / Sell / Trade 16 03-22-2011 08:07 PM
