AC Condensate drain ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JoeN 267, Jun 26, 2010.
  1. Jun 26, 2010 at 9:09 AM
    JoeN 267
    JoeN 267 [OP] Active Member
    Joe
    Central NY
    Tacoma - TRD Sport 2010
    Haven't seen any condensate dripping after running the AC - any idea where the "drain tube" is located ?
    The truck was undercoated, may have been plugged -
  2. Jun 26, 2010 at 9:13 AM
    Asgard
    Asgard Well-Known Member
    06 PreRunner DC SR5 w/LSD
    It extends a few inches out of the firewall on the passenger side and drips on the frame rail.
  3. Jun 26, 2010 at 9:41 AM
    lazaro
    lazaro Well-Known Member
    Garry
    Chesterfield, Virginia
    2010 DC BSP 4X4 TRD Off-road
    Stainless Nfab Steps painted black, Acces Tonneau cover, LED dome and map lights, Weathertech floor mats, EGR slimline visors, Wicked Flow 13 mufflers, ultragauge and 4X4 illuminated switch mod, receiver shackle from Timichi and Redline QL plus hood struts.
    I noticed that too. Is there any way or mod to let it drain away from the frame? I really think it could contribute to rusting.
    Op if you cant see any drain coming out from said location the undercoating might have plugged it. I will check it if I were you.
  4. Jun 26, 2010 at 7:05 PM
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    And be aware that some found the tube inside (up high on the inside area of the passenger floor) sometimes ran up and over a bracket causing it to either get pinched or travel uphill before going outside to drain. Might want to check that out if it's not plugged outside.
  5. Jun 28, 2010 at 6:24 PM
    JoeN 267
    Joe
    Central NY
    OK, tube was easy to see and it was draining right on top of a frame rail that had a bundle of wires running down the top of it - the OD of the drain tube was 5/8 inch, went to hdwr. store and picked up 2 ft. of 5/8 inch ID tubing - slipped new tubing over the existing tube and ran down to below frame - exhaust header is right there, tried to keep new tubing as far away as possible - tie-rapped in place - ALSO - got my Bilstein 5100's for the front today from DSMS - will be getting them installed within the next few weeks :)))
  6. Jun 29, 2010 at 12:04 PM
    JoeN 267
    Joe
    Central NY
    I have drippage from the AC condensate now on the driveway - NOT on the frame rail :)
  7. Jul 1, 2010 at 4:03 PM
    Coupe
    Coupe Well-Known Member
    Houston, Texas
    08 X-Runner
    Lots baby!
    This was one of my first mods.
    Screwdriver is on the drain extension.
    This pic shows where it goes.
  8. Jul 1, 2010 at 4:09 PM
    BakoTruck
    BakoTruck Well-Known Member
    Matthew
    Bakersfield, CA
    05 PreRunner TRD
    Boy....I sure do like how they designed the drain over the frame.
    AbunaiTaco likes this.
  9. Jul 1, 2010 at 4:34 PM
    JKD
    JKD Well-Known Member
    "Damn it, Bob, this frame isn't rusting fast enough. What can we do?"
    "Well, maybe we could design the truck so it continually dumps water into the frame."
    "Brilliant, Bob! Brilliant!"
  10. Aug 13, 2011 at 4:56 PM
    magnum922
    magnum922 Well-Known Member
    2011 DCLB 4.0 tow pkg 4x4
    Do you think this mod extension would void the warranty?
  11. Aug 13, 2011 at 5:10 PM
    spares
    spares Canadian Bacon
    New Brunswick, Canada
    06 DCSB TRD Sport
    :cool: not sure if joking....
  12. Aug 13, 2011 at 5:39 PM
    JKD
    The warranty on what?
    eaboecke likes this.
  13. Aug 13, 2011 at 6:01 PM
    magnum922
    The warranty on the ac system if anything ever goes wrong it could be a good "blame the owner for extending the hose,not covered" by the dealer.
  14. Aug 13, 2011 at 6:02 PM
    magnum922
    Anyways would the rust be that significant over the years of the ac draining onto the frame?
  15. Aug 14, 2011 at 5:11 AM
    magnum922
  16. Aug 14, 2011 at 6:26 AM
    TexasTacoma37
    Glad to see someone bumped this. I was planning on re-routing mine but hadn't measured the diameter of the tube. Now I don't have to. Thanks!
  17. Aug 14, 2011 at 6:37 AM
    Bloodhound
    Bloodhound Banned from the Pics Thread
    Greg
    East Moline, IL
    '10 TRD O/R DBL-CAB
    Floor-mats, Running Boards, Shorty Antenna, AFE Pro Dry Air Filter, AVS In-Channel VentVisors, Beer cans in the bed
    Is 5/8" the ID or the OD
  18. Aug 14, 2011 at 6:38 AM
    TexasTacoma37
    Post says OD of the original tubing.
  19. Aug 14, 2011 at 6:51 AM
    Bloodhound
    Greg
    East Moline, IL
    '10 TRD O/R DBL-CAB
    I saw that but what would the ID of the tubing be then? Most part store around here use the ID for size reference.
  20. Aug 14, 2011 at 6:55 AM
    hogeyphenogey
    hogeyphenogey Back in a Tacoma
    Dave
    Agawam, MA
    Lunar Rock 2023 TRD Sport 6spd
    Well, he stated the OD is 5/8" so that would be the ID of the tube you're buying, seeing as how you'd be putting your new tube over the drain tube on the truck. Right?
