Marlin Crawler 4.7:1 Gearset Question? & locker Question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bromagen25, Nov 10, 2010.
  1. Nov 10, 2010 at 6:35 PM
    bromagen25
    bromagen25 [OP] Well-Known Member
    Stock
    Rear Breather
    I have looked and looked but i can not find a straight answer to my question so here it goes.
    1. Is there any way to add the Marlin Crawler 4.7:1 Gearset to the 2005+ Tacoma's with out changing the transfer case.
    2. I want to Regear i have 4cyl 4x4 manual 2010 i use it as daily driver so it will be on the interstate 5 times a week. i am going to keep 31in tires would 4.56 or 4.88 be best. (I have To get Two sets Right? 1 front 1 rear)
    3. I also am looking at geting a locker as well. Wich would be best for my truck 4cyl manual 4x4. looking for front and rear.
    Will be used for mud and rock crawling. like the ARB air locker because it is selectable but is there any other out there that are selectable? (lower Price)
  2. Nov 10, 2010 at 6:42 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    I don't have an answer for #1, but would suggest calling Marlin.
    #2, since you say its your daily driver and you will be on the road most of the time 4.56 would be my vote with the 31's. Yes you will need 2 sets front and rear. for incase you didn't know your truck already comes with 4.10 gears.
    #3 I believe most selectable lockers will be $$$. With the ARB you will need an air tank. There are also some electric lockers. Food for thought.
  3. Nov 10, 2010 at 7:53 PM
    bromagen25
    Stock
    Rear Breather
    what would be a good good electric one?
  4. Nov 10, 2010 at 7:55 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    factory toyota or eaton electric if they make it for the tacoma
  5. Nov 10, 2010 at 7:59 PM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    I moded 1999 Taco so much it had turned to Land Cruiser
    1. NO you need transfer case and it has to be lefty
    2. 31" you need 4.56. you can install 4.88 but thats probably goign to be too much. yep if you have 4x4 then you need two gear sets, two master install kits. (If your current gears are not 4.10 then you will need new front differential too supposedly
    3 F/R there are plenty choices but for front only ARB is the viable choice rear you can try lockright if you dont like it then go for ARB. Lockright is easy to install
  6. Nov 10, 2010 at 8:13 PM
    bromagen25
    Stock
    Rear Breather
    what about this would it work and what all would i need. it said needs core and motor?
    HERE
  7. Nov 10, 2010 at 8:58 PM
    BlueT
    NorthEast
    If he has non e-locked axle then 8.4 which means no e-locker unless whole axle is replaced. And by all axle I mean drum to drum ... So your post is correct :)
    Oh yeah and TRD axle needs to be from 09+ truck
  8. Nov 11, 2010 at 7:39 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    Sorry I didn't reply back I was at work. Everyone that responded is likely more informed than I.
  9. Nov 11, 2010 at 10:37 PM
    kauaibuilt
    kauaibuilt U no kea but AINOFEA!
    LA/SGV
    2011 DCSB
    Check out my sig...
    No air tank needed for ARB just ARB compressor. If you run a CO2 tank theres a few companys that make a manifold to run ARB lockers off the tank.
  10. Nov 11, 2010 at 10:57 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
  11. Nov 17, 2010 at 12:35 AM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    1. Marlin makes a crawl box that goes between the current tcase and tranny. you can get that with 4.7 but because our tcase is chain drive(not gear) you cant change the ratio. So to answer your question yes and no. Yes you can add 4.7 in line with the stock tcase. but you cant replace the stock tcase with 4.7 ratio gears.
    2. If you are going to keep the 31" stock size tires, you can keep the 4.10s especially if your going to go with a crawl box. For 32"s 4.56 will be fine on the street. If you go with arb up front youll be fine with 4.56. if you plan on keeping an open front or go with a lockright you will need a 3.73 carrier for the 4.56 R&P. If you plan on waiting on the crawl box ($2000) then 4.88s would probably be better. 4.88s work with the 4.10 carrier that is stock or with arb. And the 4.88 can handle 33s. Might be a bit much with 31s though.
    3. Many people save money and opt for lockright or no-slip in the rear. Pretty street friendly. I myself am trying to decide lockright or noslip. For front, i plan on going with a selectable. ARB is currently the only one available currently.
  12. Nov 17, 2010 at 6:04 PM
    bromagen25
    Stock
    Rear Breather
    thank you very much for the in
    i think i will wait save my money and just get the new tcase Lefty is the name i think and the 4.56 gears that means i need a 4.56 up front to as well i think if i read all the post right. with the new tcase from inch worm it will replace my stock tcase right? i should have around a 84:1 crawl ratio. ( 3.95*4.56*4.71)
    or will the gears be different with the new tcase? or will they stay the same?
    sorry for all the questions i just want to do it right the first time.
  13. Nov 17, 2010 at 6:18 PM
    Yoytoda
    Roland
    completely stock
    thats if you go through the trouble of changing tcases.
    If you add a 4.7 Marlin crawler reduction and 4.56 gears itd be (3.95*4.7*2.7*4.56) no need to adapt or replace anything, just add a reduction to the mix.
    first ratio x 4.7 reduction(crawler) x 2.7 (stock T case) x 4.56 diff
    228:1 a true crawl ratio. Marlin runs dual 4.7s with 5.29s and has a 500:1 crawl ratio
    whatever gears you run in the back you have to run up front.
    a lefty inchworm is 2000$. A marlin reduction Dual case is 1850 for the kit. What it does is add the reduction of a lefty without the rest of the tcase, just the low range. you keep the stock tcase in conjunction
  14. Dec 29, 2010 at 9:40 AM
    scgunslinger
    scgunslinger Well-Known Member
    SC
    11 taco 4x4 2.7 man trans
    bone stock
    sure would like to here the after effects of the lefty install and how it works real world.
