has anyone used TPMS bands?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by builthatch, Dec 21, 2010.
  1. Dec 21, 2010 at 8:39 PM
    builthatch
    builthatch [OP] MiG-21 superfan
    Tony Mandarich
    near the ocean, NJ
    '11 SSM SR5 6 speed 4x4
    Hella DOT wattage high performance 9003 headlight bulbs, Optilux by Hella XY h10 fog light bulbs, Suntek HP50 tint, AFE Stage II Si intake
    i've found some posts of people talking about them, but i'm not sure if anyone actually uses them.
    http://www.tpmssource.com/strapkit.aspx
    goal: run '11 16" steel wheel TPMS in a particular non-toyota OE wheel.
  2. Dec 21, 2010 at 8:43 PM
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    fords use them...Not bad, but if anyone has to take your tire off the rim, tell them upfront there are bands in there, cuz they snap easy. If your changing wheels and tires, just take the sensors out and save yourself alot of headaches.
  3. Dec 21, 2010 at 9:02 PM
    builthatch
    Tony Mandarich
    near the ocean, NJ
    i did find one write-up somewhere about how to keep the light off with what looks like a simple reverseable wiring trick behind the glove box.
    i don't mind the idea of TPMS, but i also would feel much better about having them stem mounted vs. via band.
  4. Dec 21, 2010 at 9:13 PM
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    theres also a way to do it using PVC(kinda looks like a pipe bomb). Put sensors inside, close it then put a regular valve stem in the top and pressurize the pvc. Bingo light goes out.
    where in jersey are ya?
  5. Dec 21, 2010 at 9:24 PM
    builthatch
    Tony Mandarich
    near the ocean, NJ
    i live in cape may county, near OC.
    i am liking that idea the most, actually.
    i wonder if screw-on ends and cement would work as opposed to JUST cementing caps onto the pipe.
  6. Dec 26, 2010 at 1:35 PM
    TexasTacoma37
    I'm running TPMS straps with zero issues after 20,000 miles. got them from discount tire.
  7. Dec 26, 2010 at 1:40 PM
    jeremiekc
    jeremiekc Well-Known Member
    Jeremie
    Vilseck, Germany
    07 Regular Cab Base Model
    Secondary Air Filter removed, Painted Brake Calipers, AFN Drop in air cleaner, OEM Chrome Bumper, OEM Chrome grilll, OEM Cruise Control, OEM Interval Wipers, Hard Wired Garmin Nuvi 670, X-Runner Rims, Devil Horns, 6000w HID's, Bling Light Fogs with Blue Halo, OEM Bilstein Rear Shocks, 12V Plug in Truck Bed pocket. Debagged, 13" Antennax, Color Matched Satoshi Grill, URD Short Shifter, WeatherTech Floor Mats, PainLess Wiring Switched Fuse Box, Black Sand Pearl X-Runner Badges
    I have done a ton of research on this and have found the best option is to run the TPMS straps. I have been running them now for a year and daily at over 110mph and have had no problems. It is very important that you get them on tight and that you get your tires balanced as soon as you install them.
  8. Feb 10, 2011 at 5:22 PM
    gwatk
    gwatk Member
    how much do the straps cost
  9. Feb 10, 2011 at 5:28 PM
    TexasTacoma37
    $50 or so
  10. Feb 10, 2011 at 5:36 PM
    TRDKenE
    TRDKenE DAMN GOOD DEAL!!
    Kenny
    Richmond, Virginia
    '10 D-CAB OFF-ROAD 4X4
    TRD CAI, GrillCraft.
    not a fan of the straps they are a pain in the ass! I mounted some wheels and tires on a ford edge and it sucked!
