Icon add a leaf and 5100s set to 2.5
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bama_TACO, Jan 10, 2011.
  1. Jan 10, 2011 at 2:43 PM
    Bama_TACO
    Bama_TACO [OP] ROLL TIDE!!!!!!!
    Winfield, AL
    2006 PreRunner Double Cab TRD SPORT
    Got the Icon 3 leaf progressive add a leaf installed Saturday afternoon. Install went well. It was supposed to be a 1.5" lift but turned out to be about 2 1/4". Ride was really good. Had quite a bit of rake since the front 5100s were set at .85. I then decided to raise the front to the 1.75" setting. After raising I still had more rake than I wanted, so today I raised the front up to the 2.5" setting. Right where I want it now. I've got about 1" of rake. I haven't been able to drive it yet since we have 3.5" of snow and my driveway is downhill all the way with a creek at the bottom. I think the ride will be ok since my truck is a sport and has linear rate springs. I'm just hoping I can get the alignment where I want it now. If the ride is too stiff I'm going to order some Toytec springs. By the way, I'm getting pretty good at getting the front spring/shock off and on. Raising from the 1.75 setting to the 2.5 setting took me 50 minutes.
    Here is a before picture for comparison
  2. Feb 13, 2011 at 10:20 PM
    LaTechLogan
    LaTechLogan Well-Known Member
    Logan
    Louisiana
    '08 PreRunner Sport
    - K&N intake - Pioneer headunit - 2 Kicker 10" subwoofers & amp - Nokya Hyper Yellow foglights - 18" Magnaflow muffler - Bilstein 5100 shocks set to 0" - Eibach coil springs - 1.5" blocks in back
    I'm considering this same setup, I would love to know how the alignment turned out and how everything rides whenever you get a chance. Your truck looks great!
  3. Feb 13, 2011 at 10:36 PM
    skistoy
    skistoy Make mine a Double!
    Western New York
    09 4X4 SR5 BSP Double Taco
    Rear Spring TSB,Billy 5100@.85,Bull bar,Nerfbar,Painted Grill,Painted Rims,Bed D-rings,Compustar Starter,Goodyear Duratrac's,Transmission TSB,Brake Overide
    will have to see if the back end settles
  4. Feb 14, 2011 at 7:39 AM
    mach1man001
    mach1man001 eh whatever
    Rob
    Blackstone, MA
    '09 Sport DCLB Met Grey
    Toyota bed mat (1st mod), Toyota all season floor mats, Rear spring TSB, Map light mod, Fog light mod, Putco yellow fog bulbs, Weather Tech window vents, Extra d-rings, Mounted mag light, TRD CAI with AFE pro dry filter, '05 front mud flaps (winter only), 2 set's of wheels/tires, 285/75/16 Hankook MT's, Black Painted 1st Gen TRD wheels (wheeling set) Black powder coated FJ Cruiser with 265/70/17 BFGoodrich KO2's (everyday), painted center of grill & bumper black, Devil horns, OME with 885's + spacers front, OME shocks w/OMD designed rear springs, Front diff drop, Rear trailer plug relocate, ATO IFS skid, Relentless Trans & Transfer skids, BAMF bolt on rock sliders, Relentless tailgate reinforcement, Uniden 75 CB radio, BAMF antenna bracket, TRD exhaust, high lift jack w/ATO mounts. And of course ProEFX Towing Mirrors!
    Did you have the stock rear springs or the TSB's in it?
  5. Feb 14, 2011 at 11:36 AM
    Bama_TACO
    Winfield, AL
    I had the stock 3 leaf springs. With this kit I removed the overload spring and installed the 3 leaf Icon. So, now I have 5 leafs.
  6. Apr 30, 2011 at 1:40 AM
    2006TRDSPORT
    2006TRDSPORT 2006TRDSPORT
    Jason
    Felton, Delaware
    2004 4Runner SR5 4WD
    Love the truck man, I have a 2006 TRD Sport PreRunner that looks identical to yours, I have changed my mind on how to lift it several times and I'm curious how much the ICON 3 leaf springs were, as I was planning on using the Toytec 2" AAL on mine when I get it done. I'm also going with the Bilstein 5100's up front set at 2.5". Did you get UCA's for it or how does it ride without new ones if not. The main reason to get UCA's I hear is for the alignment, and possible "wondering" on the highway which I want no part of. I have the stock 3 leaf setup I'm pretty sure (cant just go look being that Im in Korea, lol). I just know before I came here, I towed a Uhaul 600+ miles and it was sagging a bit in the back with less then half the weight I should be able to tow, thus my reason for wanting at least an AAL, possibly a whole new set on each side to take care of that problem. Thanks for any help/advice!! OH, and that black on the lower bumper in the front, love it, nice touch!
  7. Apr 30, 2011 at 3:49 AM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    No wandering, no problem getting alignment within acceptable specs with 5100's @ 2.5".
  8. May 20, 2011 at 3:48 PM
    trdracing5
    trdracing5 Well-Known Member
    Elizabeth City, NC
    2003 Tacoma SR5
    Why did you decide to remove the overload spring?
  9. May 20, 2011 at 3:54 PM
    willimatic
    willimatic Well-Known Member
    Will
    Rancho Murieta/Folsom, CA
    06 Tacoma AC 4x4 Sport
    I think they rec'd you to take the over load leaf out, it says you can use it with the 3 leaf pack but most places will say you remove the OL leaf.
  10. May 20, 2011 at 6:56 PM
    trdracing5
    Elizabeth City, NC
    2003 Tacoma SR5
    The reason that I was asking is because I am getting ready to put a set of the Icon add a leafs on my first generation tacoma. The directions made no mention of the over load leaf.
  11. Jul 10, 2016 at 8:07 PM
    kjkroll83
    kjkroll83 Well-Known Member
    I just opened the icon 3 leaf pack yesterday and noticed the leafs are kind of staggered (rather than equally stacked) but they seem to be equally staggered amongst the two sets. so im thinking this is normal/ correct? anybody elses look like this? if so is there a driver/passenger side?
