About to order my lift!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by RedneckSailor, Feb 18, 2011.
  1. Feb 18, 2011 at 9:14 PM
    RedneckSailor
    RedneckSailor [OP] Well-Known Member
    Brian
    San Diego, CA
    2011 Quad-Cab 4x4 TRD Offroad
    So I'm going to order my lift next week. The plan right now is to get the Bilstein 5100's for the front end and set them at 1.75. I already have the TSB on the rear end, so I'm going to get the 1.5" AAL to match up with the TSB from Toyotec. I plan on doing the install with the help of a mechanic buddy of mine and taking it in for an alignment afterwards.
    What is everyone's thoughts on this lift set up? Good/Bad?
    Before I start the install, do I need to order anything else? I don't want to have to make several trips to the store or have to wait on any other parts to arrive once I start the install.
    Also, I found the discount code to order the Bilsteins. Does anyone know of a discount for toyotec?
    Thanks in advance for the assistance!
  2. Feb 18, 2011 at 9:22 PM
    baseballfan5566
    baseballfan5566 Well-Known Member
    You should be fine..But I haven't put a lift on a toyota. My friend with his f150 had to make a lot of trips to northern tool for ball joint removers..ect. I think you should be fine..do you have a store like that near by just in case?
  3. Feb 18, 2011 at 9:29 PM
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
    LSK LT in Progress, custom bed cage, DMZ SUA kit with 2.5 kings triple bypass, kings bump stops, baja bumper, rear custom tube bumper, glass all around, Weather Tech Liners, wet okole seat covers, Cluster LED Swap, HU LED Swap, hood LEDs, bed LEDs, etc etc etc
    PM toytec for the discount code
  4. Feb 18, 2011 at 9:31 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    I think the Toytec code is in their vendor section
  5. Feb 18, 2011 at 9:33 PM
    ds46000
    ds46000 Well-Known Member
    07 PreRunner TRD Sport
    from all the numerous threads i've seen w/ pics of 5100's on different settings...it looks like with the 1.75 setting and the tsb, your truck would be level (might even still be .5" higher in rear) . If you add a 1.5" AAL to that, you'll have quite a bit of rake because you'll be 1.5"- 2" higher in the rear. If that's the look you're going for, then have at it!
    I hope that helps...and good luck w/ the install.
  6. Feb 18, 2011 at 9:37 PM
    SDNATE
    SDNATE New Member
    San Diego
    08 PreRunner
    What is a TSB? sorry might be a dumb question
  7. Feb 18, 2011 at 9:38 PM
    OZ-T
    Peter North
    British Columbia
    Technical Service Bulletin
  8. Feb 18, 2011 at 9:40 PM
    OZ-T
    Peter North
    British Columbia
    TSB's are fixes for known problems issued by Toyota to their dealerships . If you have a problem that has a TSB issued for it , it will be repaired under warranty .
