Should I order top plate spacers with ome and 5100
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bone Buster, May 26, 2011.
  1. May 26, 2011 at 4:01 AM
    Bone Buster
    Bone Buster [OP] Active Member
    Josh
    South GA
    06 Tacoma TRD
    Tinted tail lights, 3in lift ome with bill.5100, Ranch hand brush guard, motometal wheels with 33x12x16 mudd grallers, K&N cold air intake
    Im going to order my lift after lunch( ome 885 and billy 5100)and I was wondering if I should order the spacers also to correct the lean and get a full 3in. of lift.
  2. May 26, 2011 at 4:28 AM
    badguybuster
    badguybuster Well-Known Member
    Michael
    West (by GOD) Virginia
    2016 Tacoma TRD Sport
    New truck....so nothing yet
    I did and it worked perfect. Handled great too. Go for it.
  3. May 26, 2011 at 4:48 AM
    Bone Buster
    Josh
    South GA
    06 Tacoma TRD
    How many did you use. I was told 2 on one side and one on the other is that true. Toytech has them for 59 a set or 19 a piece so they must be selling 3 in there set also
  4. Jun 3, 2011 at 9:43 AM
    sledneck
    sledneck Active Member
    Northern Maine
    2011 TRD Sport DC
    MBRP Stainless Duels, AFE CAI Stafe 2, lBilstein 5100's, 886's, smittybuilt Nerf Bars, UWS box, 6000K HID's, Grillcraft grille, Switchback LED signals and DTRL's, 20% tint,
    Same here, I just ordered 4 billies from DSM and am looking to either Eibach or 885 coils. Not sure if I need the Top Plate Spacer as well as 1/4 driver's side lean spacer or not?
  5. Jun 3, 2011 at 11:42 AM
    Bone Buster
    Josh
    South GA
    06 Tacoma TRD
    I went ahead and got the ome 885 with 1/4 spacer for the driver side along with the 5100 set at .85. I installed mine yesterday and had my tires put on this morning. 33x12x16 nitto mudd grapplers with no scrubbing.
  6. Jun 3, 2011 at 11:43 AM
    crf69
    crf69 scraping my emblems off my plasti-dip
    Ohio
    06 TRD OR BSP cab'n 1/2
    ummm yeah
    and you got it in alignment?????:eek:
  7. Jun 3, 2011 at 11:46 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I thought it was ill advised to run 885's above the 0 setting... Could be wrong but that's a tall and strong coil to be pre-loading.
  8. Jun 3, 2011 at 12:58 PM
    Bone Buster
    Josh
    South GA
    06 Tacoma TRD
    Ive heard of it done both ways and yea I knew I was taking a chance but o well and yes I had the alignment done this morning in which the only thing was out was my tow. Rides great! But I dont do much off roading either.
  9. Jun 3, 2011 at 1:01 PM
    yotamikez
    yotamikez Street glide or die
    Valrico
    04 civic & 08 Street glide
    Pictures? And are you 4wd? If so cv angles pics please.
  10. Jun 3, 2011 at 1:04 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    This is true ^^^
  11. Jun 3, 2011 at 1:08 PM
    TheHansen
    TheHansen Well-Known Member
    Mattapoisett, MA
    05 DC Sport
    dtrl mod Fog light mod Bed lights Under hood lights Rear window decals tint matched front windows Rear dif breather mod weathertech floor mats Bed mat Scan gauge 5100's and 885's lean spacer 1.5 in aal, 1" block and OME rear shocks Dynomax muffler (weld in) Truxedo lo pro qt bed cover Devil horn Emblem Plasti dip badges plasti dip radio plasti dip ac control all pro rear bumper with side pieces All pro front bumper All pro bolt on sliders illuminated 4x4 switch JBA long tube headers URD o2 Sim
    I have 5100 @ 1.75 with 1/4 lean spacer right now, but will be putting 885 on without the top plate next Tuesday or Wednesday. Ive got a 4x4 double cab and i'll post up measurements/ cv pics after the install if there's interest.
    depending on my cv angles i may try running them at .85 or order the top plates.
  12. Jun 3, 2011 at 1:10 PM
    yotamikez
    Valrico
    I'm intrigued to see these cv angles... I woulda swore over 3" and your having issues with tearing?
  13. Jun 3, 2011 at 1:18 PM
    OZ-T
    Peter North
    British Columbia
    You are better off to order the top spacers
  14. Jun 3, 2011 at 2:11 PM
    TheHansen
    Mattapoisett, MA
    05 DC Sport
    I know the top plate is better, i just don't like the idea of being able to see a spacer in there.
  15. Jun 3, 2011 at 2:13 PM
    OZ-T
    Peter North
    British Columbia
    You prefer the idea of pre loading springs that aren't meant to be pre loaded better ?
  16. Jun 3, 2011 at 2:16 PM
    TheHansen
    Mattapoisett, MA
    05 DC Sport
    well my last truck i lifted by cranking the torsion bars too their limit, and i didn't have any issue's. In all honesty i will more than likely go the spacer route if i'm left wanting more after the 885 install. along with uca's (just cant decide which)
  17. Jun 3, 2011 at 2:19 PM
    OZ-T
    Peter North
    British Columbia
    Here's a good tip I wish I had done , if you are contemplating adding the top spacers at a later date , install the longer top bolts now , then you won't need to disassemble the entire coil / shock assembly to add them later
  18. Jun 3, 2011 at 2:29 PM
    TheHansen
    Mattapoisett, MA
    05 DC Sport
    ahhh that's a good idea. My 885's are already in the mail so oh well. i would have gotten the top plate spacers when i ordered them but i was just too paranoid about my cv's (couldn't find anything definitive). I enjoy working on the truck anyways so i don't mind pulling it apart a second time.
  19. Jun 3, 2011 at 2:34 PM
    OZ-T
    Peter North
    British Columbia
    You got them pre assembled with new shocks ?
  20. Jun 3, 2011 at 2:41 PM
    TheHansen
    Mattapoisett, MA
    05 DC Sport
    no... i already have 5100's @ 1.75, and im not even 100% sure i will add the top plate. So my plan was to install the 885's @ 5100's at 0 and let them settle for a little while. If my cv angles will allow for more height i will add the top plate when i add uca's. Either way im getting new uca's. im just waiting to hear from someone who has stainless uni-balls in a climate with lots of road salt and how their holding up ( different thread i made).
