The aircondition doesnt work...??????
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Mr.Tacoma, Jun 8, 2011.
  1. Jun 8, 2011 at 9:13 PM
    Mr.Tacoma
    Mr.Tacoma [OP] Well-Known Member
    toronto
    DoubleCab4x4
    TRD Exhaust, Side step bar & ARE cap
    Folks..first time i think i turned the A/C since i bought this truck last fall.
    It just blows air thats all. What should i look for first. Isnt there a fuse for A/C..?? Is this a common thing in 2005 models. :confused:Thnx
  2. Jun 8, 2011 at 9:34 PM
    Carson
    Carson Well-Known Member
    Carson
    Modesto, California
    '20 Grey TRD Off-Road 6spd
    TC +2 LT, Kings, BAMF Armor, 35s, gears
    Maybe it just needs to be repressurized?
  3. Jun 8, 2011 at 9:35 PM
    McJosh
    McJosh avidoffroad.com
    Josh
    Chandler
    2005 Reg. Cab 5 lug Tacoma
    Pioneer AVH-p2300DVD, 12" Memphis sub and Alpine MRP-M650 amp, 32" BFG AT tires and KMC wheels, tinted windows, satoshi grille w/ stainless steel mesh, Avid front & rear tube bumpers, Cobra wx75 CB with 3' firestik, GaragePro bucket seats, FlowMaster 40 series, aFe CAI, Black head lights, LoJack and Autopage alarm installed, Avid sliders.
    check to see all the plugs are connected. fuse?
  4. Jun 8, 2011 at 9:46 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    This same thing happened to with my 06' a couple months ago. This to was the first time I had used it since last fall. I was on the highway and the A/C light lit up but it was nothing but hot air that blew out. Once I got off the highway and parked, I turned the engine off and restarted it and the A/C started working so I got lucky I guess. I'm still not really sure what happened to it but i works fine now.
  5. Jun 8, 2011 at 10:40 PM
    MountainEarth
    MountainEarth Well-Known Member
    Bryan
    CO
    2010 TRD OR Access
    Leer 100XR Shell, BedRug mat - comfy sleeping, GT Covers microfiber seat covers, BFG All Terrains 265/70r16, Dashmat, Antennax 13" shorty antenna, Weathertech liners, Ultra Gauge, Avid Light Bar, PIAA 520 ATPs, one old dog
    Yeah not impressed with the A/C in my Taco. Not very cold at all. Our Subaru is an icebox by comparison. Is the A/C compressor running?
  6. Jun 9, 2011 at 7:40 AM
    wlmuncy
    wlmuncy Well-Known Member
    William
    Knoxville, TN
    2007 Double Cab Manual 4*4
    If the ac ever looses power it will not run with truck at highway speeds. You have to run it below 45 miles an hour for a minute or two.
  7. Jun 10, 2011 at 5:34 AM
    reg boulette
    reg boulette Well-Known Member
    Found this same problem in my 09 v6 after having disconnected the battery for a few hours to wire up trailer harness. Seems to lose logic somehow without power. Just continued to drive while cycling through various choices....temp low to turn on AC, off/ on the outside/inside air source, etc. in no particular combination. After 5-10 minutes was working fine again.
    TreeFortRichard likes this.
  8. Jun 10, 2011 at 6:00 AM
    puckstopper55
    puckstopper55 Well-Known Member
    Long Island
    '11 Double Cab TRD Sport, Mag Grey
    tailgate anti-theft Map Light LED's Dome Light LED LP LED Halogen Bed Light Extra D-Rings in bed Anytime Fog Lights Tri-Fold tonnau cover Wet Ok's
    Ill be honest, the AC in my 2011 is very unimpressive. My 95 Taco's AC was like a walk in freezer. Not sure what changed.
  9. Jun 10, 2011 at 6:07 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    OP, Check the fuse for the AC.
    To everyone else that seems to have an issue, check the outgoing air temp of the vents. On "MAX" AC, the air temp should be below 55* for a normal AC operation. if this is not the case, check to make sure the AC coolant pressures are in spec.
  10. Jun 10, 2011 at 6:11 AM
    BFA
    BFA Nuttier than squirrel shit.
    Brian
    Phoenix, AZ
    2003 3.4 4x4 5spd
  11. Jun 10, 2011 at 6:32 AM
    buddywh1
    buddywh1 Well-Known Member
    Philly PA
    07 DC SR5 4x4
    A common problem with many Toyotas is the clutch relay goes bad and engages intermittently or sometimes not at all. If the A/C button indicator LED is flashing instead of steady this could be the case. I went through the same problem last year on my 2007; swapped it with the trailer tail light relay (not needed until I tow) and fixed it right up.
    The flashing LED means the compressor is not turning synchronous with the engine which happens when the clutch doesn't engage, so it should also flash if the clutch fuse is blown and if the compressor is seized.
    I got a DC and mine is actually pretty good even on the hot one yesterday... but only when rolling at near-highway speeds (35mph at least). That tells me it needs plenty of airflow over the condenser. I think good high-flow electric fans instead of the belt driven fan would do nicely when traffic crawling.
  12. Jun 10, 2011 at 7:29 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    The change from 95 to now is r-134a is not as efficent as r-12.
    Pressure switches, relays and TXV valves all like to go bad. Put a set of gauges on the ac before you replace parts. It will give you a good idea of where to start looking. Assuming it needs a recharge is a good way to overcharge. Don't add oil either, unless you have flushed the system. Overoiling is bad too.
  13. Jun 10, 2011 at 7:31 AM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    An add-on electric fan will help with low speed ac performance. Since the condenser needs air movement, and the clutch fan won't stay engaged when the ac is on, you lose cooling at low speeds.
