Side step rail mounting question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by clcowboy, Jun 18, 2011.
  1. Jun 18, 2011 at 6:59 PM
    clcowboy
    clcowboy [OP] Member
    Springfield, IL
    SRD 2WD TRD
    Any of you guys out there that mounted your own step rails, Are there pre-cut holes to mount these rails on any or all of the Tacomas? I have an 07 extended cab and didn't know how much of an undertaking this is to install these. Any feedback would be great. Thanks
  2. Jun 18, 2011 at 7:13 PM
    paidfor
    paidfor Well-Known Member
    Austin, TX
    2013 TRD OR 4x4
    Hidden GPS tracking system. Backflip cover, weather techs, bed mat, tailgate lock, OME 885 springs, blistein shocks, 2.5 in AAL/
    if you buy the rails for the truck body style you have, they mount to existing screw holes, mine were plugged so I removed the plugs and mounted the steps in less than 30 min. holes are under the body of the truck
    unless you plan on doing weld on, in which case you need no holes
  3. Jun 18, 2011 at 7:31 PM
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
  4. Jun 19, 2011 at 5:03 AM
    clcowboy
    Springfield, IL
    SRD 2WD TRD
    Thanks for the messages. I'll check and see if the plugs are there.
