Finally built the spare tire carrier.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 06rubi, Jul 18, 2011.
  1. Jul 18, 2011 at 9:07 PM
    06rubi
    06rubi [OP] Well-Known Member
    Kenney
    Pueblo West, CO
    10 MGM (wife's truck)
    Debadged, tinted windows, 7 pin relocated, bed lights, 12 volt socket in bed of truck, on board air, auxiliary fuse box, grill craft, hella 500's, t-rex eyelids, pink budbuilt skids, icon remote resi coil over, camburg uca, alcan rear springs, ubolt flip, icon 2.5 remote rear resi shocks
    Took off the back rail and replaced it with angle iron, welded on some tabs I made from angle for the lights and C.B. antenna and a couple hinges.
    Built the frame and bed bar to support it in the vertical position.
    Added support braces and tire tie in.
    Still need to paint it but here are some almost completed pics of it.
    Down
    Up.
  2. Jul 18, 2011 at 9:08 PM
    MrGrimm
    MrGrimm Mall Crawler
    Dean
    Wisconsin
    2006 Toyota Tacoma 4WD w/TRD Sport Package
    See build page
    I like it
  3. Jul 18, 2011 at 9:10 PM
    ouyin2000
    ouyin2000 Well-Known Member
    Nova Scotia
    '11 DCSB TRD Sport
    Leer 100XL Canopy, OEM Side steps, TRD Oil Cap, TRD License Plate Cover, WeatherTech Digital Fit Liners, Elite O/R Hitch Shackle, Katzkin Leather Interior, LED Interior Lighting, Foglight Anytime mod, Illuminated 4x4 switch, Grom Audio Aux adapter, Redline Goods leather shift boot console cover and door handle pulls, Sockmonkey bedside decals, Dynolock electric tailgate lock
    I like that it can be raised to allow for use of the bed still. Good thinking!
  4. Jul 18, 2011 at 9:13 PM
    zul
    zul Professional Goofball
    PNW
    2012 Pyrite Mica DCSB SR5 4WD V6 AT
    HAVE: Bed mat, Tailgate Lock, Color-matched Grille, Weathertech Floor Liners, Avid Step Rails, RokBlokz mud flaps WANT: Rear Plate Bumper, Steel bed cage
    Shit that is a great design. Make me one!
  5. Jul 18, 2011 at 9:14 PM
    MJonaGS32
    MJonaGS32 MJ on a GS
    MJ
    SF Bay Area (East)
    07 LT 4x4 DCSB 6spd Vagabond
    Drifter wedge camper, Dual battery, OBA, ARB locker, 4.56 gears
    OOhhhhh I LIKE!
  6. Jul 18, 2011 at 9:15 PM
    VooDoo
    VooDoo More Cowbell!
    Carter Ivey
    Baton Rouge, LA/ Starkville, MS
    '06 DC LB PreRunner
    when does the group buy start? :D
  7. Jul 19, 2011 at 5:13 AM
    06rubi
    Kenney
    Pueblo West, CO
    Thank guys, glad y'all like it! I doubt my engineering and welding are good enough to be selling them, still have to see if this one will even hold up! :D
  8. Jul 19, 2011 at 5:19 AM
    Styx586
    Styx586 Well-Known Member
    Terrance
    Lake Elsinore, Ca
    2013 Tacoma DCLB TRD Sport, 2001 Tacoma TRD Off-Road
    Nicely done... Looks slick.
  9. Jul 19, 2011 at 7:33 AM
    korslite
    korslite Well-Known Member
    Justin
    Bellingham, WA
    DCLB Sport
    FOX 2.5 RR's, TC UCAs, TC Spindle Gussets, Allpro Expedition leaf pack, Fox 2.O RR w/ Comp adjusters, 17" ATX Artillery, BFG AT 285's, de-scooped, custom sliders, custom bedrack, Brute Force Fab bumpers, Smittybilt XRC8 winch, ARB locked Rear diff
    That is sick! Gives me ideas... I feel another project coming up. Nice work.
  10. Jul 27, 2011 at 6:08 PM
    06rubi
    Kenney
    Pueblo West, CO
    I drilled a couple holes and mounted the Hi-Lift to it. Should have bought some wing nuts but regular ones will work till I find myself at Lowes again.
    Up position.
    Top View
    Down position
  11. Jul 27, 2011 at 10:10 PM
    MJonaGS32
    MJ
    SF Bay Area (East)
    looks clean!
  12. Jul 28, 2011 at 6:23 AM
    06rubi
    Kenney
    Pueblo West, CO
    Thanks! Just hope it holds up.
  13. Jul 28, 2011 at 6:32 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I've got a general question about tire carries and since you fabbed yours up this way, you might be able to answer it. Why does it seem tire carriers hold the tire at an angle rather than vertical? It seems if the tire were vertical it would leave much more of the bed space available while the angle closes off a good portion of it. Just curious, I ask out of ignorance (my spare is still under the bed :eek:)
  14. Jul 28, 2011 at 6:44 AM
    06rubi
    Kenney
    Pueblo West, CO
    I built it at an angle for a couple reasons. Biggest one probably is looks. If it were vertical it would block the window if it was against the front of the bed. I think it would look goofy if it was vertical on the inside side of the bed. Second reason was it was easier to design something strong enough to hold the tire safety. Laying at an angle it seems to be more stable, but I aint no engineer!
  15. Jul 28, 2011 at 6:47 AM
    Pugga
    Massachusetts
    Thanks, I was more curious that anything. I'm still stock sized tires and have no need for an in-bed mount but was curious as to why they're all at an angle. So far Metalmiller's is the only one I've seen that holds the tire vertical.
    Nice work by the way!
  16. Jul 28, 2011 at 6:55 AM
    06rubi
    Kenney
    Pueblo West, CO
    I had to put it in the bed because I mounted the OBA tank where the spare is supposed to be! Plus I figured it could be a hassle to drop the spare on the trail if I needed change a tire. Thanks for the complement!
  17. Jul 28, 2011 at 7:03 AM
    Burgman
    Burgman I KEEEEEL YOU
    Stephen
    Ric VA
    08 PreRunner TRD sport Silver
    K&N intake, Boston Acoustic SL 60 6.5 components up front, Rockford Power T16 6.5 in rear, Pioneer P4100 HU, Soon to be Pioneer Prs 4200f
    Im a fan, nice work
  18. Jul 28, 2011 at 4:38 PM
    EL TACOROJO
    EL TACOROJO SNAPPIN NECKS AND CASHIN CHECKS.
    BURRY
    south mills NORCAK
    03 dblcab prerunner sr5 v6
    smoked taillights,smoked front turnsignals,smoked 3rd brake light,black badges,black roof rack,removed mud flaps,debadged, camburg 2.5 coilovers,camburg uca's, cobra 25 cb, 4ft firestick ant, dust light/bed lights , 4 hellas on the front
    where you get the hinges at. any links
  19. Jul 28, 2011 at 4:40 PM
    rleeharris
    rleeharris "Old Timer," compliments of 11Taco2.7
    Bob
    San Antonio, Texas
    '11 Tundra Crew Max TRD Off Road
    Very impressive. I too like the way you can position it so you can still use the full lenght of the bed. Nice!
  20. Jul 28, 2011 at 4:48 PM
    Pope953
    Pope953 That's a fact Jack!
    Wesley
    Asheville, NC
    SR5 Pickup
    35% up front, 20% in the back window tint, 15" Mickey Thompson bullet hole wheels, with 31x10.5 Firestone Destination A/T tires. Glass Pack, High Flow Cat, S&B CAI, Custom Light Bar with 4 fog lights. 2 10" Rockford Fosgate P2 subs with 1000 watt Rockford Fosgate Amp, CB.
    Looks good! Good work!
