If it's not one thing, it's another. Rounded diff plug.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MxRacer190, Jul 20, 2011.
  1. Jul 20, 2011 at 3:58 PM
    MxRacer190
    MxRacer190 [OP] Well-Known Member
    Georgia
    06 SR5 4x4 Indigo
    So I'm prying on my rear diff fill plug to change my fluid, when SLIP there goes the nut. Rounded off like a motherf*cker. . . I even drove 30 minutes to buy a 24mm socket cause I didn't have one, and I let it soak in pb blaster for about an hour. . . Wtf do I do now? I'm just really bummed atm. . .
  2. Jul 20, 2011 at 4:00 PM
    beaver_scott
    beaver_scott Well-Known Member
    scott
    renton, wa
    2015 inferno trd pro
    vent shades, tinted windows, clear bra, pop n lock tail gate lock, anytime fog light mod.
    try to put a notch in the rounded head of the bolt and hit it with a flat head screwdriver and a mallet in the direction to break the nut loose.
  3. Jul 20, 2011 at 4:02 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Lots of options-Drill it, notch it, keep trying- but make sure you have a proper replacement plug before you try anything.
  4. Jul 20, 2011 at 4:19 PM
    MxRacer190
    Georgia
    06 SR5 4x4 Indigo
    Okay thanks. Will it not damage the interior threads if I beat it with a mallet and screwdriver?
  5. Jul 20, 2011 at 4:22 PM
    OffroadToy
    Since there isn't a whole lot of room under there to swing a hammer you might try cutting a deep notch at around the 3 o'clock position, then place chisel or something simalar against the notch and a bottle jack on the other end.
  6. Jul 20, 2011 at 4:24 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
  7. Jul 20, 2011 at 4:56 PM
    MxRacer190
    Georgia
    06 SR5 4x4 Indigo
    Where can I get a replacement? Do I have to go to the dealer? I've been searching, and see some folks getting Marlin replacements, but no luck finding part numbers/sites selling diff replacement bolts.
  8. Jul 20, 2011 at 5:31 PM
    baja820
    baja820 Well-Known Member
    pacific northwest mountains
    '11 SR5 Tacoma V6 6MT 4x4
    Six sided 15/16 socket. It feels tighter I'm super paranoid about stripping bolt heads off. If there is any slop at all with the socket I find a suitable alternative. Good luck with it man.
  9. Jul 20, 2011 at 5:34 PM
    baja820
    Also can you get some vice grips clamped on it?
  10. Jul 20, 2011 at 5:38 PM
    MxRacer190
    Georgia
    06 SR5 4x4 Indigo
    Actually, I tried a 15/16 before I went to the store. It felt the same as the 24mm. They are both 12 sided though.
    I'll try that tomorrow. I wish i had a damn impact/compressor.
  11. Jul 20, 2011 at 6:01 PM
    JKD
    JKD Well-Known Member
    12 point sockets might as well be advertised as "hex head grinders".
  12. Jul 20, 2011 at 6:04 PM
    baja820
    Ha,ha no shit! I hate 12 point sockets.
  13. Jul 20, 2011 at 6:08 PM
    scocar
    scocar hypotenoper
    Yes, they are shit for anything with narrow flats or that has been on forever.
    But you could go the Krazie route and use needle-nose vice grips.:eek:
  14. Jul 20, 2011 at 6:09 PM
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    When you find a replacement, please post where you get it from.... :eek: I have to change my diff fluid in the next week or so...
    Good luck
  15. Jul 20, 2011 at 6:11 PM
    scocar
    scocar hypotenoper
    Why not the dealer?
  16. Jul 20, 2011 at 6:14 PM
    samsung
    samsung Well-Known Member
    George
    Sugar Land, Texas
    2011 PreRunner doublecab TRD Offroad
    undercover lid/Ipod integration kit/Pop n lock/bed rug, fumoto drain valve, full piping Wet Okole covers, Blacked out badges, Lamin-X fog light cover yellow, window tint, ARB deluxe bumper with fog light kit,DSM UCA'S,3 support shrockworks sliders,complete OME lift with 886X coil and dakar leaf spring with 3 degree axle shims and center pin lenghtener,warn VR10000 winch,amsteele blue synthetic rope, daystar winch isolator, daystar delrin rollers, IPF 900xs Extreme Driving H9 Kit 900XSD (900XSD),Horn on fire with shot Penning,
  17. Jul 20, 2011 at 6:14 PM
    Snowman
    Snowman I have a problem for your solution…
    Craig
    Somewhere in Canada
    Check out my build
    Kind of late now, but a trick I learned long ago is to give those plugs a clip with a hammer before trying to turn it. Just hit the head square with the hammer and they normally come loose.
  18. Jul 20, 2011 at 6:14 PM
    HondaGM
    HondaGM CallSign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    six point 15/16
  19. Jul 20, 2011 at 6:17 PM
    jsmarine
    jsmarine Well-Known Member
    Jeff
    Dallas, TX
    2005 Tacoma SR5 Crew Cab 4x4
    ARB front & rear lockers ARB bull bar Warn XP9000 winch IPF lights
    Weld a cheap wrench (harbor freight) onto the head of the bolt, (just a couple of good tack welds should do) and that should help you get it off. Just make sure you have a new bolt ready after-wards.
  20. Jul 20, 2011 at 6:19 PM
    MxRacer190
    Georgia
    06 SR5 4x4 Indigo
    I think I found it. But holy $10 shipping. . .
    http://www.villagetoyotaparts.com/p...T-DIFFERENTIAL-FILLER/2428870/9034118066.html
    https://www.toyotapartsbarn.com/toyota-oem-parts.html
    Because I absolutely despise my local dealer. . . I would burn the place down if I knew I wouldn't get caught.
    I don't think it is big enough. Says up to 19mm :( iso 24mm
