Factory Spare Tire Lock vs Cable Lock
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Mav44, Nov 11, 2011.
  1. Nov 11, 2011 at 11:24 AM
    Mav44
    Mav44 [OP] Well-Known Member
    I am new to this and trying to lock everthing down before I do anything else. What is the best way to protect the spare tire, should I pick up the facory lock like this one , or should I get some type of heavy cable and lock?
  2. Nov 11, 2011 at 1:48 PM
    Mav44
    I just went up under the truck and noticed I have a chain from the factory hanging down through the center of the spare. Can I just padlock this to one of the holes in the rim of the spare and be protected?
  3. Nov 11, 2011 at 2:00 PM
    OffroadToy
    I guess that would work. I've never heard of a chain from the factory before...what year is your truck?
    What I did it swedge a loop on both ends of a heavy cable. I ran it up through the frame and around the tire, then padlocked. Spray some WD40 in the key hole and cover it with duct tape.
  4. Nov 11, 2011 at 2:07 PM
    Scubasteve4533
    Scubasteve4533 Well-Known Member
    Steve
    Ohio
    11 TRD OR
    5100 @ 1.75, tsb rear springs with 5100. anytime fogs, rear diff breather, 50 cal ammo boxes on bed rails
  5. Nov 11, 2011 at 2:20 PM
    Mav44
    It is a one week old 2012 that I have found out about all the security flaws the Tacoma has and I am working to fix. See pics of stock factory chain below.
  6. Nov 11, 2011 at 2:28 PM
    OffroadToy
    Is that chain somehow used to lower the spare and what's it attached to up above?
  7. Nov 11, 2011 at 2:51 PM
    Mav44
    I don't think so, there is still the place in the bumper to stick in the crank to lower the tire.
  8. Nov 11, 2011 at 2:59 PM
    OffroadToy
    Maybe your dealership had a problem with spare tire theft and had the chain installed?
  9. Nov 11, 2011 at 3:12 PM
    Mav44
    I guess I should see what this chain is tied to above the tire. If nothing else I will stick a big old master-lock on it to spook off the grab and run guys.
  10. Nov 11, 2011 at 3:22 PM
    tmt301
    tmt301 New Member
    I just got my 2012 a 3 days ago. I have that chain hanging too. I haven't had the time to mess around with the truck yet. I asked around including mechanics from different places they say that is normal. So I didn't bother with it yet, but I sure have to figure out how to lower that spare tire for safety reason.
  11. Nov 11, 2011 at 3:28 PM
    Mav44
    Hi tmt301, make sure you do the tailgate mod. It should be listed at the top of this page under mods & tutorials. I could not beleive I could walk up and pop my talgate off in under 5 seconds. Toyota needs to fix this!!!
  12. Nov 11, 2011 at 4:14 PM
    OffroadToy
    Do you guys with the chains live in California by any chance? I just talked to my dealer and they say it's a regional thing either Toyota or the dealers are doing in area's of the country with high theft problems.
  13. Nov 11, 2011 at 4:27 PM
    Mav44
    Yes, Southern California for me. Tacoma is number 4 on the stolen list.
  14. Nov 11, 2011 at 4:28 PM
    munkeeboi
    munkeeboi Well-Known Member
    Burbank
    I believe that chain is what holds up the spare tire carrier when lowered. My 1990 4 runner had a similar chain. it is not there for security. i would believe putting a padlock on it would help, but I am pretty naive to spare tire theft and would like to hear more suggestions
  15. Nov 11, 2011 at 4:58 PM
    OffroadToy
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/6391-stolen-spare.html
  16. Nov 13, 2011 at 4:40 PM
    woojoo83
    woojoo83 Well-Known Member
    John
    San Diego
    '12 MGM DCSB 4WD TRD Sport
    Mav44, have you determined what the chain's purpose is? admittedly, i have not sought to figure it out myself, but i have had my truck for less than 48hrs. i, too and a socal resident and i too have that same chain dangling like a dingleberry under there.
  17. Nov 13, 2011 at 6:27 PM
    tacomathom
    tacomathom Well-Known Member
    Tom
    It's not new, it's not Mexico
    A cable & lock would be real fun on a rainy night.
  18. Nov 13, 2011 at 11:26 PM
    MountainEarth
    MountainEarth Well-Known Member
    Bryan
    CO
    2010 TRD OR Access
    Leer 100XR Shell, BedRug mat - comfy sleeping, GT Covers microfiber seat covers, BFG All Terrains 265/70r16, Dashmat, Antennax 13" shorty antenna, Weathertech liners, Ultra Gauge, Avid Light Bar, PIAA 520 ATPs, one old dog
    I just bought a $5 combination cable lock from Wally World, threaded it through the tire and around the frame. My experience ... you just gotta do a little more than the next guy and you'll be fine.
  19. Nov 13, 2011 at 11:28 PM
    aznutx
    aznutx Well-Known Member
    DFW Texas
    2011 White TRD
    i have that the spare lock, and i put a cable around it with a weatherproof lock on the cable.
  20. Nov 14, 2011 at 1:39 AM
    canoeski
    canoeski Well-Known Member
    Bill
    Southcentral Wisc
    2012 Tacoma AccessCab
    Debadged. ARE Topper. Tailgate mods, including locking handle. BAMF LCA skids.
    My 1992 has exactly that same chain arraignment. Just had it down last night to work on a seized parking brake cable.
    It might be possible to put a padlock on it but the links aren't that big and I imagine a good bolt cutter might make short work of the lock or chain.
    BTW, be sure to lower your spare at least several times a year (I do it in the fall and again in spring, good time to check tire pressure) and spray lube the mechanism. Even with that, mine seized up after about 15 years of salt exposure and the entire mechanism had to be cut out and a new one welded in by the dealer.
