-   -   Hello - Questions regarding lifts/wheels/tires/etc already (http://www.tacomaworld.com/forum/2nd-gen-tacomas/191118-hello-questions-regarding-lifts-wheels-tires-etc-already.html)
Geebz 12-04-2011 10:01 AM
Hello
Just picked up a 2010 Tacoma TRD Sport DC from SK, Canada:canada:
I have always been interested in lifting my trucks ive had in the past and i think this time im actually going to do it.
Just from roaming around through the threads here's what ive learned so far:
Im probably going to go with the 3" Toytec ultimate with toytec AAL's (2") in the rear (comes with the diff drop and everything for straightening out the CVs). I was interested in RCD 4/5", but not interested in cutting the crossmember - at least not for my first lift attempt! :D
With that being said its a 3" lift, so on top of that i would be looking to get some new rubber and wheels(rims) and some TC UCA's for alignment issues (feel free to correct me if im wrong with anything!)
I currently have stock 17" rims with 265/70/17 kumhos all seasons (or something)
This brings me to my first question:
Is it possible to still run the stock rims and tires with the 3" toytec lift?
The reason - i might not have the cash to spend on the rims and tires right away
NEXT
I have been looking @ ballistic Jesters for rims (17x9) 6-5.5
They have a 5.47" backspacing and -12mm offset
from what ive seen, your backspacing needs to be around 4.5" - is this to clear the brakes and calipers or what? or is it a rubbing issues? or UCA rubbing issues? which leads me to my next question:
If i get some spidertraxx 1.25" spacers will this essentially decrease my backspacing i.e. 5.47-1.25 = 4.22" (mind you pushing the tires out further past the wheel wells by 1.25")
Tires i would probably go to 285/70/17's GY Duratracs :)
Now i know for sure this will cause rubbing issues, but im not sure how much with what the spacers will do if i need em and the rims
I know some guys on here said that they are getting away with 275/70/17's without rubbing problems so maybe thats what i have to go with instead, although im not afraid of trimming plastic (cab mount chop is a different story all together though)
KPT you seem to be the most educated when it comes to this stuff maybe a little blurb from you would help me out lol
OZ-T 12-04-2011 10:05 AM
Welcome
:canada:
Ryan07 12-04-2011 10:07 AM
Welcome, looks like a good setup.:canada:
Hot Tamale 12-04-2011 11:09 AM
Welcome from Nevada! :wave:
Geebz 12-04-2011 11:46 AM
I may have answered my question about the spacers, Here:
http://www.yotatech.com/f177/wheel-s...pacing-187664/
Can anyone out there confirm??
OZ-T 12-04-2011 12:42 PM
Originally Posted by AirborneTaco (Post 4130199)
First, welcome. Second, yes you can run your stock wheels and tires with the toytec lift. I have a toytec 3" w/ UCAs and am running the stock sport rims. before i got new rubber, i had the stock dunlops on there for a day. i can say it leaves quite a void between the fender and the tire. I ended up going the 275/70 route. I like it. unfortunately i don't know much about backspacing and all that stuff so i won't attempt your second question. here's a pic for visual reference. good luck.
What tires are those ?
4Wheelin4Banger 12-05-2011 01:27 PM
http://i.cdn2.tacomaworld.com/forum/...xtras/wave.gifWelcome to TW from Sparks, NVhttp://i.cdn2.tacomaworld.com/forum/...xtras/taco.gif
My '11 Taco with a full 3" OME lift (885s & Dakars) with stock tires & wheels.
http://www.tacomaworld.com/gallery/d...03Taco0002.JPG
Large 12-05-2011 01:50 PM
Welcome. I came here expecting what do I do with this and will that fit and etc but sounds like you made your choice already.
Banff2007Tacoma 12-05-2011 01:57 PM
Welcome to TW.:wave::canada:
