Cigarette Lighter does not work
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MikeB29212, Dec 14, 2011.
  1. Dec 14, 2011 at 12:36 PM
    MikeB29212
    MikeB29212 [OP] New Member
    Columbia, SC
    06 Prerunner SR5
    My cigarette lighter is not working, the adjacent 12v plug is working. I have checked the fuse and it is good, any suggestions?
  2. Dec 14, 2011 at 12:49 PM
    Bengland25
    Bengland25 Never Forget! 343
    Bradley
    Southern California
    09 Tacoma TRD
    MB Chaos 6 17" wheels, BF Goodrich All-Terrain TA/KO LT265-70R17, Anytime Fog Lights, Anytime Backup Camera, Bed Lights, Tailgate Lock, Light bar with 3 Hella 700FF's, Realtree Camo arm-rests, Anytime DTRL (With Switch), Blue Seas Fuse Block and Circuit Breaker, Custom Bed Light-Bar, Cobra 29 LTD Chrome, 4' Firestik, Masterlock Hitch Key Safe, Bed Storage Compartment Locks, Custom Shovel Bracket Mount, Flag Pole Mount (RED SOLO CUP FLAG!), DIY Washable Cabin Filter, URD MAF Cal., Homelink Garage Door Opener, Volant CAI w/ Ram Scoop, AeroTurbine 3030XL, URD Short Throw Shifter, Custom Satoshi, Blitzpro 21S, 2 Blitzpro 6LZ's, Blitzpro 6D, BAMF Sliders
    Sub'd mine doesn't work either.. Curious for the fix
  3. Dec 14, 2011 at 12:55 PM
    aznutx
    aznutx Well-Known Member
    DFW Texas
    2011 White TRD
    basically it's either the fuse, or the actual plug is broke, ^ double check the fuse
  4. Dec 14, 2011 at 1:06 PM
    MikeB29212
    Columbia, SC
    06 Prerunner SR5
    I have tried 3 different fuses and it still does not work. Does the same fuse power the cigarette lighter and the 12v plug? I have been looking at how to gain access to the lighter to remove it, it seems as if Toyota built the truck around the lighter!
  5. Dec 14, 2011 at 1:27 PM
    ouyin2000
    ouyin2000 Well-Known Member
    Nova Scotia
    '11 DCSB TRD Sport
    Leer 100XL Canopy, OEM Side steps, TRD Oil Cap, TRD License Plate Cover, WeatherTech Digital Fit Liners, Elite O/R Hitch Shackle, Katzkin Leather Interior, LED Interior Lighting, Foglight Anytime mod, Illuminated 4x4 switch, Grom Audio Aux adapter, Redline Goods leather shift boot console cover and door handle pulls, Sockmonkey bedside decals, Dynolock electric tailgate lock
    You have to take most of the dash panels apart in order to get to the back of the lighter plug/12v plug.
    I just toko mine apart, and in order to get the actual panel off, you have to remove the stereo, then the stereo surround (and in order to get that off you have to pull off the right hand side of the dash cluster panel). Remove the glove box, pull apart the center console (there's 2 bolts inside the bottom of it). Pull up on the cup holder (2 more screws underneath that). Remove the rear center console piece, then finally remove the front center console piece.
    That's all for the manual transmission. I'm unsure of exactly how to remove the auto trans pieces, but I'm sure if you get this far, you'll be able to figure it out.
  6. Dec 14, 2011 at 1:30 PM
    MikeB29212
    Columbia, SC
    06 Prerunner SR5
    I found the problem - I lit up the inside of the plug with a flashlight and saw corrosion on the connecting point. I pulled the fuse and cleaned the terminal with steel wool, everything is working fine now! I am glad that I did not take everything apart to find that it was a simple fix.
  7. Dec 14, 2011 at 4:39 PM
    aznutx
    DFW Texas
    2011 White TRD
  8. Apr 9, 2013 at 9:17 PM
    tacomatrdod
    tacomatrdod Well-Known Member
    Mud Country
    2010 tacoma trd offroad
    Toolbox, stereo upgraded a tad
    Well mine wont work... and it's very annoying, if it was a fuse apparently the radio and clock wouldn't be working. As is happening to mine right now. ANy ideas on how to fix this guys?
  9. Apr 10, 2013 at 1:29 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    The cigarette lighter outlet fuse doesn't have anything to do with the Radio or the clock... They have different fuses.
  10. Apr 10, 2013 at 3:20 PM
    tacomatrdod
    Mud Country
    Yes. But apparently the cigarette adapter is then hooked up to the radio in a . circuit, or at least according to the Internet. Anyways I've checked all the fuses and my clock, head unit & acc adapters are still not working :(
  11. Apr 10, 2013 at 9:40 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    The only common point would be the 7.5 ampere accessory fuse did you check that? Or the Accessory relay ( that is not in the radio or clock circuit ) that is turned on by the ACC Position on the ignition switch which powers the Cig Lighter and power point sockets.
  12. Apr 10, 2013 at 10:05 PM
    AMH3RST
    AMH3RST eat, sleep, work
    Mitch
    Las Vegas, NV
    06 PreRunner Dbl Cab
    Camburg +3.5" LT; King Shocks 2.5x8"; King Shocks 2x2" Bump Stops; Maxtrac 4" spindles; Deaver J66 leafs; King Shocks 12x2"; BAMF Rear Shock Relocate; KMC Enduro 16x9; BFG KM3 315/75R16; BAMF BTG Light Bar; 2 20" Toughlight Pro Series LED Light Bars; Cab Cage
    Accessory fuse.
  13. Apr 11, 2013 at 1:18 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    Hey, there is an echo in here .....
  14. Apr 14, 2013 at 5:56 AM
    tacomatrdod
    Mud Country
    Hmm... which fuse exactly? I swear i checked all of the fuses with ACC in them. even that really big one, like i checked everyfuse short of checking them one by one.
    regardless im checking all the 7.5Ampere fuses lol
  15. Apr 14, 2013 at 8:49 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    The 7.5 Ampere Fuse for the ACC is in the Drivers side fuse box behind the change pop out.
