looking for tires for my truck, 3 inch lift
Discussion in '2nd Gen. Tacomas (2005-2015)' started by janelle2388, Dec 30, 2011.
Thread Status:
Not open for further replies.
  1. Dec 30, 2011 at 7:31 AM
    janelle2388
    janelle2388 [OP] Well-Known Member
    Corey
    Montana
    09 tacoma access cab SR5
    3 inch icon lift, dual exhaust, 17 inch pro comp rims, tinted tail lights, black badges, BHLM, T-Rex eye lids, 10" alpine type R sub, alpine deck, alpine amp, K&N CAI, icon UCA's, 2" AAL, 32" led light bar
    i have a 2009 tacoma access cab and just put a 3 inch lift in it. what size tire is recommended for the stock rims?
  2. Dec 30, 2011 at 7:45 AM
    feldman28
    feldman28 Well-Known Member
    chris
    batavia
    09 sr5 stick
    Id go 285 but that's just me.
  3. Dec 30, 2011 at 9:39 AM
    TexasTacoma37
    265/75/16 for stock rims if you don't want to run spacers.
  4. Dec 30, 2011 at 9:50 AM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    255/85/16
  5. Dec 30, 2011 at 11:16 AM
    janelle2388
    Corey
    Montana
    you think 285/75/16 will fit well? with no rubbing?
  6. Dec 30, 2011 at 11:19 AM
    chadderkdawg
    chadderkdawg Don't ask questions you don't want the answer to..
    Des Moines, Iowa
    09 FX4 F150
    That's what I run.
  7. Dec 30, 2011 at 11:23 AM
    janelle2388
    Corey
    Montana
    no rubbing? and your truck looks sick im going for a similar look
  8. Dec 30, 2011 at 11:24 AM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    they will rub all over and require major modification if you plan on turning it ever. that guys full of shit
    IDK why people keep saying to put these on other peoples trucks, but "they" need to stop. If someone asks for advise and some hoser gives him blatantly bad advise we need to ban them :D
    265/75/16 is perfect. I'm running 265/70/17 (basically the same) and I rub from time to time.
  9. Dec 30, 2011 at 11:25 AM
    pataco
    pataco Well-Known Member
    Down by the lake
    05 4x4 trd dc white
    FOX 2.0 RESIS,LRUCAS,BILLY 5100S ON THE REAR.MAGNAFLOW 11264,COLOR MATCHED GRILL,YELLOW FOG MOD.OVER HEAD DVD,FEDERAL COURAGIA M/T
    SSSSSEEEEEEAAAAAAAARRRRRRRRCCCCCCCHHHHHHHH
  10. Dec 30, 2011 at 11:27 AM
    OZ-T
    Peter North
    British Columbia
    If your hoser comment is directed at me , 255/85/16 will fit a 3" lift on stock wheels with no rub under most conditions , there's a fairly large thread on that tire size here
  11. Dec 30, 2011 at 11:30 AM
    janelle2388
    Corey
    Montana
    im just looking for a little advice see what other people are running and make my decision from that. i no i dont have the same set up as everyone else out there so i no there will be a difference from my truck to others. just trying to get a rang for sizes
  12. Dec 30, 2011 at 11:32 AM
    DreDog
    DreDog Well-Known Member
    Andrew
    id go 40's if you have a 3 inch lift
  13. Dec 30, 2011 at 11:33 AM
    DreDog
    Andrew
    :thumbsup::thumbsup::thumbsup::thumbsup::thumbsup::thumbsup::thumbsup::thumbsup::thumbsup::thumbsup::thumbsup::thumbsup::thumbsup:
  14. Dec 30, 2011 at 11:42 AM
    chadderkdawg
    Des Moines, Iowa
    09 FX4 F150
    I'm sorry, who are you? I've had 285/75/16s on my truck for months.... I trimmed a very small amount of plastic and can turn lock to lock.
    Quit bein a fuckin toolshed, dickbag.
  15. Dec 30, 2011 at 11:45 AM
    Dhawk1313
    Dhawk1313 Well-Known Member
    Drew
    New Jersey
    99 SR5
    Clear Corners, Clear Turn Signals, Pioneer Headunit, Kenwood speakers up front, Alpines in back, Billy 5100's front + rear, Toytec AAL, Eibach/Toytec Coilovers, Toytec Diff drop, Smoked taillights
  16. Dec 30, 2011 at 11:50 AM
    NicNac22
    NicNac22 D.I.L.L.I.G.A.F
    Nic
    Wild and Wonderful
    95 V6 4x4 ex cab SR5 5sp PICKUP!!!
    fun stuff coming soon! New battery, radiator and CV joints and axles. Added some Rancho RS5000 shocks.
    hey pass some o dat over here?
  17. Dec 30, 2011 at 11:55 AM
    orvis
    orvis Well-Known Member
    Winnipeg, Canada
    06 TRD off road
    now now childern, play nice. 285/75r16 if you want to add spacers, remove your mud flaps and do a little trimming, otherwise 265/75r16. There is also the Nitto trail grapplers in a 285/70R16 that only require a 1/4" spacer.
  18. Dec 30, 2011 at 11:57 AM
    OZ-T
    Peter North
    British Columbia
    You shouldn't have said that
  19. Dec 30, 2011 at 12:04 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    15 Lariat Sport 5.0L
    you also forgot to mention that you are running spacers to fit those 285s on stock rims, correct? since there are pics of spacers in your gallery.
    might wanna lay off the un-needed comments when nothing was said to you.
  20. Dec 30, 2011 at 12:05 PM
    tacoman15
    tacoman15 Boobies
    Northeast Georgia
    2015 Tacoma TRD OR & 1985 SR5 4Runner
    wrong. you sir need to educate yourself. OP no major modification is needed. like someone above said before, just take off your mud flaps, trim a little bit of plastic out of your fender wells, and throw some wheel spacers on there and you will be goo.
    :ohsnap:
    x2
    that escalated quickly
    x2
    but makes for a great reason for some :popcorn:
Thread Status:
