-   -   Front End Clicking sound. (http://www.tacomaworld.com/forum/2nd-gen-tacomas/201276-front-end-clicking-sound.html)
Hiatt1991 01-29-2012 11:43 AM
Hi guys. I have recently noticed that when I coast, I get a weird clicking sound that seems to be from the front end. It starts when I am either coasting really slowly to a stop, or when I apply the breaks. From the info I have read on here, it seems like it could possibly be the wheel bearing. I jacked up the truck and shook both front tires but the dont seem to have any play but when I spin the tires, I can hear a really slight noise that resembles the clicking, but im not sure if Im being overly particular. I dont have any kind of locking hubs either. Just bilstein 5100s, camburg ucas, KMC enduros and 285s. Any help would be greatly appriciated.
IKMtacoma 01-29-2012 11:46 AM
sounds like the shaft issue - there is a thread about it somewhere on here.
Hiatt1991 01-29-2012 11:48 AM
Drive shaft? Could be possibly. I havent gotten the carrier bearing drop from beefed tacos yet from the lift but it never made a clicking noise. Just an occasional groan sometimes. Its just it sounds like it comming more from the front.
Fractured 01-29-2012 11:51 AM
It could be the fit kit in the brake calipers shifting. They might need a clean and lube.
Hiatt1991 01-29-2012 11:52 AM
What is the fit kit?
Hiatt1991 01-29-2012 11:53 AM
BTW it seems like it got a little bit louder today. Either that or Im being picky. lol
Fractured 01-29-2012 11:54 AM
It is the little pins that the brake pads sit on. There is also a little bracket that looks like a "Shepards cane" I suppose. What year is your truck?
NM its a 2005. It sounds like its coming from the front? You could also get a grease gun and hit the slip yokes/u- joints on the front and rear drive shafts too. Unless you JUST hear it when you hit the brakes.
Hiatt1991 01-29-2012 11:57 AM
Well I hear it when Im comming to a stop (coasting) but it is definatley more prominate when I hit the brakes. Ill try out the grease gun.
Fractured 01-29-2012 12:03 PM
If it happens when you brake, it is more likley the pads shifting in the caliper. However, the grease gun is a good idea anyways.
See the pic taken from badguybusters how to.- Its the pin going across the pads- I would use a brake caliper lube on them.
http://img809.imageshack.us/img809/3983/1001839p.jpg
Hiatt1991 01-29-2012 12:08 PM
Oh ok I see. Ya I changed the breaks myself and I was very liberal with the anti friction past that I put on the back of the pads. It could very well be that clip because the clicking sounds slightly metallic as if it were a clip.
Fractured 01-29-2012 12:09 PM
Its also important to apply the lube to the pin itself, so when the pads shift it doesn't make noise.
Hiatt1991 01-29-2012 12:11 PM
Ok. Ill try that.
Just to describe the sound better, it sounds sort of metallic and it happens every time the wheel makes a full rotation.
Fractured 01-29-2012 12:13 PM
That could be a "high"spot and glazing on the rotor.
MonkeyProof 01-29-2012 12:26 PM
High spots won't cause a clicking noise...you'll feel a shimy in the steering wheel when on the brakes
Hiatt1991 01-29-2012 12:45 PM
Ya. I'm almost certain its those wheel bearings.
flyboy.co2 01-29-2012 12:51 PM
I have a similar clicking when I put the breaks on at low speeds, and coasting. I'm dead certain it's coming from the front left wheel, inclined to think it's the pin aforementioned. I'm interested to see where this goes. Sub'd
Hiatt1991 01-29-2012 01:35 PM
Glad I'm not the only one but sorry its happening to you too. If its not the clip, I'm definitely going to change out the wheel bearings.
flyboy.co2 01-29-2012 03:06 PM
I'll be sure to let you know how things turn out with my click. This upcoming weekend I might jack her up and have a look see. Hopefully it's not a bearing....
Hiatt1991 01-29-2012 03:09 PM
Bearings aren't that hard to replace if you get the ones that bolt on instead of being pressed in. I kind of hope it is my bearings because everyone I've talked to that has gotten their bearings changed said it drove so much better/smoother and their steering felt better.
flyboy.co2 01-29-2012 03:13 PM
Well I would assume a bearing is covered under warranty? If isn't the clip I'll have Toyota take a gander.
