Finished Interior painting/sound deadening!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by XPOTRPR, Mar 12, 2012.
  1. Mar 12, 2012 at 11:48 AM
    XPOTRPR
    XPOTRPR [OP] CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    What do you guys think?
    Heres the breakdown: Finally finished my interior painting and sound deadening. I tore out the back wall plastic and my sub/amp and laid down some Fat Mat Rattle Trap.
    of course refreshments...
    I removed the chrome piece on the shifter by just popping it off as if you weer to break it in half. lol, sanded, primed, and then painted in krylon fusion white.
    Then removed the door panels, and the gauge cluster
    removed the gauge rings by the small clips behind the cluster
    all pieces painted in Krylon fusion.. waiting to dry..
    next step... watch paint try..
    then reinstalled all the pieces. I used two part epoxyto attach the bezel on the shifter, and the emblem on the steering wheel.
    all finished, cleaned, and detailed..
    For the gauge cluster: remove the driver side kick panel (under your fuse panel by the foot rest) there is one bolt you will see at the top. Remove it and pull that portion towards you. Next, remove the two screws above the gauges. They are more like push in clips. Once those are out, snuggly but carefully pull towards you on the bottom light gray part of the day. You will tell when it pops out. Do the same for the black gauge/upper dash portion.pull toward anf down. One it is loose, you will have to wiggle it out between the steering wheel. It's somewhat flexible so you can bend the upper part that is over the gauges a big to clear it. Tilting the steering wheel down helps a bit too. Then, once its out, you'll see the clips that pictured in the OP.
    Here's the link I used. It's not for the same project, but it gets the cluster off. Lol
    Tech Knowledgebase - Disable 2005+ Door Buzzer
    http://www.customtacos.com/tech/index.php?article=225
    Steering wheel emblem is definitely tricky and you have to be patient. its really soft, flexible plastic, and i used a SMALL flat head and a razor blade to cut it away from the steering wheel. then used the same razor blade to cut all the tabs off the back, applied apoxy, and stuck it back into place.
  2. Mar 12, 2012 at 12:00 PM
    NvrSumR
    NvrSumR Well-Known Member
    Jeff
    Colorado
    Nice work. Did you add sound deadening to the doors or just the rear of the cab?
  3. Mar 12, 2012 at 12:01 PM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    Just the rear
  4. Mar 12, 2012 at 12:04 PM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    lol thanks Patrick. yeah, just the rear.
  5. Mar 12, 2012 at 12:07 PM
    Casey05Taco
    Casey05Taco Well-Known Member
    Casey
    Penngrove, CA
    05 Tacoma Prerunner
    trd seat covers, bed mat, tinted windows, debadged, mud flaps removed, tinted tails, blacked out center console, Black Rims, 6000k HID in highs and fogs, blacked out front emblem, Pioneer AVH-4300DVD, Gauge Cluster, lower valence, retrofitted, audio system, Maxtrac Spindles, Billies
    subbed, looks good
  6. Mar 12, 2012 at 12:10 PM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    thanks man
  7. Mar 12, 2012 at 12:13 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Does the silver trim around the gauges, door speaker and shifter base just pop off or do you need to remove the panels and undo some sort of connection on the back side?
  8. Mar 12, 2012 at 12:16 PM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    the pieces around the gauges use clips that easily pop off. the tweeter rings are clipped AND have those melted tabs thast hold them in place. I used a lighter to soften up the material, and then popped them out. heated them again to reinstall. the same with the chrome bezel piece on the shifter, but then i used epoxy to reinstall that.
    ChadsPride likes this.
  9. Mar 12, 2012 at 1:30 PM
    jpmorrisvb
    jpmorrisvb Well-Known Member
    Jimmy
    Virginia Beach
    2014 Barcelona Red TRD Off-Road PreRunner
    Clazzio seat covers, KB Voodoo Powder Coated Tailgate Cap, OEM running boards, ImMrYo Rear-View Mirror Lift Bracket, 35% Tinted windows, EGR window vents, color matched door handles and tail gate lift, WeatherTech FloorLiners, OEM bed mat, sound dampening on rear wall and rear doors, on anytime foglight mod
    So, let me get this right before I go breaking anything ... the "rings" around the speedometer, tachometer, and fuel/temp gauges come off with a little gentle pressure? I want to paint mine black.
    Also, I have got to ask ... whose curb is now painted with ring shapes?
  10. Mar 12, 2012 at 1:35 PM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    no pressure needed. they are held in with clips, use a small flathead screwdiver, or even your finger. they just pop out.
    curb in the back lot of my complex.
  11. Mar 12, 2012 at 1:41 PM
    Pugga
    Massachusetts
    I think I know what my next mod is going to be...
    I thank you, my fiance will hate you because I'm gonna stink up the house with the sweet smell of spray paint :D
  12. Mar 12, 2012 at 1:47 PM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    right on! what color are you gonna do?
    hahaha.. i wish i could paint in my house! :p
  13. Mar 12, 2012 at 1:47 PM
    TennesseeFan76
    TennesseeFan76 I intend to live forever. So far, so good.
    Phill Goodfactor
    Georgia
    2005 PreRunner DCLB
    3 inch lift, Debadged, 5% Tint, Custom Stereo, BHLM, Fog Light Mod, Sockmonkey Decals, OEM Bedmat, Plasti Dip Front Valence, Slims 6K HIDs (thanks goes to TheGloryFades), Hyper yellow fog lights, LED interior lights, Satoshi Grille with FJ Emblem, Pro Comp lights behind Satoshi, FatMat
    That looks great! Been wondering how difficult that would be to paint.
  14. Mar 12, 2012 at 1:47 PM
    brny67
    brny67 Well-Known Member
    Bill
    Moyock NC
    08 TRD Sport A/C
    wow this looks great, I actually have been thinking about doing this for a while now, might have to break down and do this really soon, thanks for the info
  15. Mar 12, 2012 at 1:54 PM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    thanks guys! i was really hesitant myself, but after reading up on how to take the dash apart.. its only one bolt, and two screws. lol the doors are only two screws.
  16. Mar 12, 2012 at 1:55 PM
    SOSHeloPilot
    SOSHeloPilot My 1st Muscle Car
    U.S.A.
    2023 RAV4 XLE Premium
    Missing My Last Tacoma --- Had 11 Toyota trucks in the past and many other Toyota cars too.
    Sub'd ... You did a great job and I got some good ideas. ... :D
  17. Mar 12, 2012 at 1:56 PM
    Pugga
    Massachusetts
    Superwhite FTMFW :bananadance:
    I still have some white Krylon Fusion from when I did my SW-HLM. I didn't realize those trim pieces just popped off otherwise I would have done it months ago!
    I set up a small paint area in the basement but the fumes tend to seep up to the first floor :eek:
  18. Mar 12, 2012 at 1:57 PM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    not much honestly. its more for the sub back there. the bass is more hard hitting i guess you would say. it definitely gets rid of the tin can sound, especially when your outside. theres no more rattling below the rear window. i still have some rattles, but i think its either the rear doors/trim or the plastic behind the driver side rear seat.
  19. Mar 12, 2012 at 1:59 PM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    thanks man! do it up. lol
    Superwhite Unite! lol
    yeah, me either.. or i too would have done it a long time ago. lol I used Fusion paint too. the only one i had to prep was the chrome piece on the shifter.
  20. Mar 12, 2012 at 2:04 PM
    shadowsecho
    shadowsecho Well-Known Member
    Charleston, SC
    11 Taco 4x4
    Superwhite! Love your build, im going to work on something just like it...traded my 06 silver for an 11 superwhite for the stormtrooper effect :).
    My question is about your sub box...where did this sub box come from?
    Saw pg 3 on your build, didn't see where the box is from, if you built it or w/e. I'm looking to put a 10 or 12 behind my rear seats just like you did. After reading this, I'll be putting some sound dampener back there. Any pro tips before I go out and get a box/sub to install?
