Vibration on Brake Pedal
Discussion in '2nd Gen. Tacomas (2005-2015)' started by OverRated, Mar 25, 2012.
  1. Mar 25, 2012 at 12:40 PM
    OverRated
    OverRated [OP] Well-Known Member
    David
    San Jose, CA
    12 Tacoma / TRD-OR / DCSB
    I have a 2012 Tacoma with 4,000 miles on it and the brake pedal started vibrating whenever I press on the brakes. Took it into Toyota and they tried to tell me that it isn't covered in the warranty.. boy did I blow up on them :eek:
    Anyways I wanted to see if anyone is having a similar problem? The service guy at Toyota told me that it is due to warped rotors and that it isn't covered under warranty but i've had warped rotors before and it was nothing like this. Even when my truck is in PARK and I press on the brakes the pedal would vibrate about 3-5 seconds. Long story short, I have to take it back in tomorrow so the "master tech" can take a look at the truck since the service guy had no idea what the problem is.. Also was told that they would have to call Toyota and see what they can do about the problem and if Toyota will warranty it.
  2. Mar 25, 2012 at 1:29 PM
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    2011 Suburban 2500
    JBA Shorty Headers, Flowmaster FlowFX Sing/Dual Exhaust
    It sounds like a possible issue with pedal feedback from the anti-lock brake system. The ABS system shouldn't be kicking in every time you press the brake pedal though. I wonder if there could be air in the system?
  3. Mar 26, 2012 at 10:11 PM
    OverRated
    David
    San Jose, CA
    Well I took it into Toyota and the reply is that the brake setup that my model have is a "electronic brake" so therefore when i push on the brake to build up pressure it'll vibrate.
    My question is why didn't it do that before when I purchased the car.. I had the master tech walk me around to find a car with the same brake setup as I did.. While doing that he took me to a Tundra V8 (1st GEN) as if I was some idiot and told me its going to be hard finding a model like mine with that brake setup. So I picked out a random TACOMA and had him popped the hood and hey it was one with the same electronic brake setup yet this one didn't have that vibration that I had. He still kept to his word and said he felt it on the 4th press of the brake but I didn't feel shit and I am 100% that there wasn't any vibration to it at all! So I had enough arguing with the master tech since we weren't resolving anything. I'm also sure I am just being pushed over due to my young age and I am sure as hell reporting this to the Bureau of Automotive and seeing what actions can be done.
    Also can other 2012 owners chime in, if you have a electronic brake setup please let me know if you have the same issue or not? I was told ALL electronic brake setups does this. The brake pump is located on the left hand (drive side) top corner as seen below.
    Electric pump brakes
    Vacuum pump brakes
  4. Mar 26, 2012 at 10:21 PM
    1GR
    1GR Toyota Dealer Technician
    Scott
    BC, Canada
    2012 Tacoma DCLB TRD Sport
    Let me look into this thoroughly. I will contact you soon.
  5. Mar 27, 2012 at 5:59 AM
    Maticuno
    2011 Suburban 2500
    My wife's Ford Escape Hybrid is an electronic brake system and there is no vibration in its pedal even after 120k miles.
  6. Mar 27, 2012 at 8:56 AM
    Tuctaco
    Tuctaco Well-Known Member
    Todd
    Tucson, AZ
    2012 MGM TRD OR 4x4
    Katzkins, Redline hood struts, Pop & Lock,285/75/16 Toyo Open County ATll, 16X8 Konig Countersteer, Icon extended coilovers, Icon rear shocks, Icon progressive leaf pack, LR UCA's, extended brake lines,
    No problem so far here. 1800 miles
  7. Mar 27, 2012 at 10:47 AM
    forana
    forana Well-Known Member
    Kaneohe, Hawaii
    2022 DCSB OR Lunar Rock
    No money, all went to truck...
    I have a 2012 and have no vibrations. Don't let this one go, doesn't sound normal. Tell Toyota that since you reported the issue to them, some liability lies with them in the case of an accident.
  8. Mar 27, 2012 at 2:50 PM
    Tacoma Mike
    Southern Maine
    Don't blame you for blowing up.
    Bumper to bumper 3/36 and with 4000 miles there is no question it would be covered.
    I hate it when they talk through their ass like that. There should be no vibration at anytime unless it's abs feedback. Wish i could help ya but your a little far from me.
  9. Mar 27, 2012 at 3:12 PM
    GP3
    GP3 Well-Known Member
    California
    4X4 TRD Off Road
    Front: stock suspension, 12" wide fiberglass fenders Rear: stock suspension, 10" wide fiberglass fenders
    It sounds like your hydraulic brake booster pump (what you are calling "electric pump brakes") is purging and/or running too often.
    When I first start my truck (2007 w/ hydraulic brake booster), it will purge the system for 3-5 seconds vibrating the pedal and making a faint electric motor sound, but will not do it again until I shut the truck off and restart.
    Let me see what I can find via the FSM.
    EDIT: I attached some info from a 2006 FSM. It was the only year I could find online at the moment.
    1.pdf: "Noise from hydraulic brake booster (Abnormal pump motor operation noise)"
    • 1.pdf
      File size:
      35 KB
      357
    • 43.pdf
      File size:
      275 KB
      395
  10. Mar 27, 2012 at 10:06 PM
    OverRated
    David
    San Jose, CA
    Thanks this is very helpful!!
  11. Mar 28, 2012 at 8:55 AM
    spithead051
    spithead051 Well-Known Member
    Patrick
    Fairfax, VA
    09 AC 4x4 OR S/C'ed!
    Supercharger, ICON 2.5VS w/ CDC, TRD T/X Pro Wheels, 255/85/R16 BFG MT KM2's, APEX three hoop bumper, Smittybilt X20 Comp Gen 2, Allpro IFS skid, All-Pro Sliders, Dynomax exhaust, aFe Stage 2 si, URD 2.85 stealth pulley, Oil pressure, oil temperature, boost, A/F ratio gauges, Devil horns, WO seat covers
    Mine started vibrating after I did my S/C install. Haven't thought of playing with it since the truck shakes a little more with the supercharger installed but I am going to do a quick look through this weekend to make sure everything is okay
  12. Mar 28, 2012 at 9:04 AM
    81shark
    81shark Well-Known Member
    2006 Base Access CP1
    huh...not to derail the topic, but what are we talking about? never seen this set up before.
  13. Mar 28, 2012 at 9:24 AM
    1GR
    Scott
    BC, Canada
    Most Tacoma's come with a Vacuum booster for the braking system, some come with a hydraulic booster instead (electronic).
  14. Mar 28, 2012 at 9:43 AM
    GP3
    California
    4X4 TRD Off Road
    Correct.
    Some 2005-2008 4x4 Off Road's have the hydraulic booster (optional), all 2009+ 4X4 Off Road's have the hydraulic booster.
    All other models have a vacuum booster.
  15. Mar 28, 2012 at 10:57 AM
    81shark
    what's so special about this hydraulic booster? just curious. thanks in advance
  16. Mar 28, 2012 at 11:05 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Mine looks like this. 2007 SR5, no fancy brake boosters.
  17. Mar 28, 2012 at 11:08 AM
    GP3
    California
    4X4 TRD Off Road
    ATRAC/DAC/HAC/etc.
  18. Mar 28, 2012 at 11:11 AM
    Pugga
    Massachusetts
    SHHHHH, you'll bring DK to this thread :smack:
  19. Mar 28, 2012 at 12:32 PM
    graywolf2011
    graywolf2011 Well-Known Member
    Orlando Florida
    11 Tacoma 4X4
    undercover hard toneau, stainless steel nfab step bars
    They told you warped rotors were not covered under factory warranty?
  20. Mar 28, 2012 at 12:36 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    I had my rotors replaced under warranty 2 months before my 3 year bumper to bumper expired on my '09
