running lights and dome light
Discussion in '2nd Gen. Tacomas (2005-2015)' started by whalenrocks, Apr 8, 2012.
  1. Apr 8, 2012 at 7:38 PM
    whalenrocks
    whalenrocks [OP] New Member
    Hello.
    I have owned 3 Tacomas. Recently my 97 4x4 failed the frame inspection. I am heartbroken. Loved the truck and I am not thrilled with the "digital" tacomas now. I like a truck to be a truck. Long story short I just bought a 2012 4x4.
    I have a few questions.
    How can i stop the running lights from coming on when my truck is running and idling. If I am in a parking lot, allowing my truck to warm up, I don't want lights on. How can I turn those off or bypass them?
    next..I hate the dome light staying on after i close the door. Is there any way around that?
    Any and all info is appreciated.
    thanks.
  2. Apr 8, 2012 at 7:47 PM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Diamond Bar/Ontario, CA
    08 TRD 2wd converted to 4wd
    Estock
    Hello and welcome to Tw...
    For the day time running lights, You can remove the relay to not make them come on anymore
    For the dome light, it only stays on for 30 seconds after the doors are closed :notsure: I'm not sure why it's that bad...they also turn off as soon as you lock the truck
  3. Apr 8, 2012 at 8:13 PM
    wado66
    wado66 Well-Known Member
    To disable the daytime running lights while the car is idling, just engage the parking brake a click or two before you start the vehicle.
  4. Oct 9, 2012 at 3:34 PM
    Cain
    Cain Well-Known Member
    Southern California
    2012 Tacoma
    Chrome don't get you home
    Where is this Relay located? Thank You
  5. Oct 9, 2012 at 4:22 PM
    Jerez
    Rod
    Estock
    under the dash behind the knee fuse box
    hit up csjumper2003 and he will tell you exactly :thumbsup:
