-   -   Using 2" Lifting Blocks to Raise Rear 2" (http://www.tacomaworld.com/forum/2nd-gen-tacomas/230779-using-2-lifting-blocks-raise-rear-2-a.html)
parfleet 07-23-2012 02:30 AM
I installed Rancho Quick Lift Struts to the front of my 05 Tacoma PreRunner about a month ago. At the same time, I installed Rancho heavy duty shocks to the rear. I knew that the Quick Lift Struts could add up to 2 1/2 inches to the front. I was hoping that the heavy duty Rancho heavy rear shocks would add a couple of inches. The end result is that the front of my truck is 2 1/4 inches higher than the rear. I called the Rancho Tech Line and complained. I was told to give it about a month to settle on the front. Well, it's still 2 1/4 inches higher on the front. I was thinking about adding 2 inch block kit to the rear to get it to look somewhat normal. I have read that this is the least desirable of methods to raise the rear 2 inches but it is the cheapest. Has anyone raised the rear of their Tacoma 2 inches using this method and was there any negative consequences? I have left a message with Rancho over the weekend to help me resolve this issue once and for all or I'll get some Monroe Quick Struts, which are OEM, just to level off my truck. Any ideas?
I'm going back to the dealership this morning to get the front end aligned for a second time. The chamber is still not right.
808TacoMan 07-23-2012 02:42 AM
Rear shocks dont give you lift. You should look into getting a 2" Add a Leaf rather than the block. Toytec has them
CayucosTacoma 07-23-2012 02:45 AM
Yeah rear shocks are only there to dampen yhe rear movements. The rear is lifted/supported by the rear leaf pack. If anything I'd go with an aal. It's cheap and gives a better ride than blocks
Konaborne 07-23-2012 02:45 AM
also, please try not to make multiple threads on the same topic :thumbsup:
808TacoMan 07-23-2012 02:46 AM
x2
650H1 07-23-2012 02:50 AM
x3
CayucosTacoma 07-23-2012 03:47 AM
X4
ace96 07-23-2012 05:00 AM
So you called Rancho to complain since you did not do your homework and didn't buy what was needed to level your truck?
Bama_TACO 07-23-2012 07:52 AM
The general consensus is to stay away from blocks. However, I went with a 1 1/2" AAL on mine and still wanted a little more lift so I added a 1 1/2" Block a couple of weeks ago and I don't have any issues. I think as long as you stay at a 2" or smaller block you will be fine. The downside of running blocks is that it can cause issues with axle wrap and it can cause your leafs to wear out sooner. I don't have any issues with wrap and my leafs have 152,000 miles on them, so I don't think I can do much else to them. The positive side of adding a block is that it doesn't change the ride of the truck and it's cheap and easy to install. Let me add that if you are going this route you will want to make sure your shocks are long enough to handle the increased height.
