2nd gen dual battery install
Discussion in '2nd Gen. Tacomas (2005-2015)' started by badtoytrd, Jul 30, 2012.
  1. Jul 30, 2012 at 11:35 AM
    badtoytrd
    badtoytrd [OP] Well-Known Member
    Brock
    Northern VA
    Well it seems I am following Barlowrs on his ideas so thanks to him but here is my Columbia Overland and National Luna with aux fuse block install.
    I had installed this kit about a year ago but I was never happy with how the wiring was organized or where the aux fuse block was installed so I set out to fix it. I ordered so braided sleeving and heat shrink, went to West Marine for the cables and connectors and had a aluminum plate made up for the fuse block. I ended up having to splice the cable going from the engine to the battery so it would reach and look clean. Took my time and it turned out even better than I thought.
  2. Jul 30, 2012 at 11:50 AM
    SalmonTaco
    SalmonTaco Well-Known Member
    Andrew
    Naches
    08 Silver TRD Sport
    Brute Force bumpers, TRD FauxLocks, 5100s & 885s, Falken Wildpeaks, SnugTop MVP Shell, Tuffy Bed Box, Console Vault, Fogs anytime, ImMrYo mirror bracket, Wet Okoles, aFe Pro Dry S, PowerStop Z36 pads & drilled/slotted rotors, more shit I can't remember
    Clean install.
    Welcome to TW, neighbor.
  3. Jul 30, 2012 at 12:11 PM
    03f5sp
    03f5sp Well-Known Member
    Bill
    Wisconsin
    2011 TRD Off Road dcsb
    Front 5100s @ 2.5, 1.5 AAL, 265/75-16 all terrains
    Why would you need a second battery?
  4. Jul 30, 2012 at 12:14 PM
    ToyComa92
    ToyComa92 Write your love, Then your anger.
    Jon
    Conifer, Colorado
    2006 Tacoma TRD sport Debadged
    Heated katzskin leather, Black TRD sport wheels, Bilstein 5100s, Toytec 2" Springs, Deaver 2" AAL, Pioneer AVH4400BH, Ultragauge, Weathertechs front/rear,
    Yah what is the wattage need for? I mean its cool and id be looking at doing it if i ended up installing the speakers and amps and subwoofers i wanted.
  5. Jul 30, 2012 at 12:54 PM
    badtoytrd
    Brock
    Northern VA
    Second battery powers ARB frig, 12v to bed, gps, and any future 12v needs. Also a bit of piece of mind can use second battery to jumpstart primary battery in the event that it goes dead.
  6. Jul 30, 2012 at 12:54 PM
    badtoytrd
    Brock
    Northern VA
    Thank you for the welcome.
  7. Jul 31, 2012 at 9:16 AM
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    Well done. :)
    TacomaTung likes this.
  8. Jul 31, 2012 at 9:36 AM
    Smoke2
    Smoke2 Well-Known Member
    Tacoma
    07 DC 4X4 LB
    Rear TSB, Firestone Air bags
    Great Job!
    I should put a second battery in with an isolator.
  9. Jul 31, 2012 at 10:54 AM
    deeznutz
    deeznutz Well-Known Member
    Seattle, WA
    09 SR5 DC LB 4x4
    That's awesome! Whoa, you're in the Seattle area too!! Hmmm, I've been wanting to do a dual battery setup but was reluctant since I wasn't too familiar on the wiring. Wanna help? :p
  10. Jul 31, 2012 at 11:32 AM
    badtoytrd
    Brock
    Northern VA
    Sure.
  11. Aug 2, 2012 at 9:02 PM
    badtoytrd
    Brock
    Northern VA
    I had wanted to do full build but finally got around to posting it. Had alot of questions so I thought I would post parts list and tolls needed.
    Parts needed
    -Batteries
    Odyssey PC1400 Amt needed: 2
    -Columbia Overland dual battery tray
    http://www.columbiaoverland.com/product/toyota-tacoma-2nd-generation-2005-current-dual-battery-tray
    -Custom made tray for aux fuse block
    -Hardware for aux fuse block plate
    M8-1.25, flat washers, and lockwashers for attaching plate to fender nutserts
    1/4 x 20 allthread, nuts, locknut, flat washers, and lock washers to support end of plate
    -National Luna dual battery kit
    http://www.sierraexpeditions.com/index.php?l=product_detail&p=543
    -Military style battery connectors/terminals
    http://www.sierraexpeditions.com/index.php?l=product_list&c=753
    -Blue Sea aux fuse block
    http://www.sierraexpeditions.com/index.php?l=product_detail&p=550
    -Blue Sea circuit breaker
    http://www.sierraexpeditions.com/index.php?l=product_detail&p=185
    -Cables
    http://www.westmarine.com/webapp/wc...&subdeptNum=50560&classNum=50562#.UBm8zELsIdI
    Red 2 AWG battery cable P/N: 233718 Amt needed: 6’
    Black 2 AWG battery cable P/N: 233726 Amt needed: 6’
    Red 4 AWG battery cable P/N: 179523 Amt needed: 3’
    Black 4 AWG battery cable P/N: 214551 Amt needed: 3’
    -Connectors/Lugs
    http://www.westmarine.com/webapp/wc...&subdeptNum=50566&classNum=50568#.UBn6QELsIdJ
    2AWG heavy duty butt connector P/N: 104259
    2AWG heavy duty lug 3/8” stud P/N: 214163
    2AWG heavy duty lug 5/16” stud P/N: 291146
    2AWG heavy duty lug 1/4” stud P/N: 104309
    4AWG heavy duty lug 3/8” stud P/N: 214254
    4AWG heavy duty lug 5/16” stud P/N: 214247
    4AWG heavy duty lug 1/4” stud P/N: 385799
    -Braided Sleeving
    http://www.buyheatshrink.com/braidedsleeving/pet-braided-sleeving.htm
    Red 3/8” PET braided sleeving P/N: BS0375 Ordered 100’ roll
    Black 3/8” PET braided sleeving P/N: BS0375 Ordered 100’ roll
    -Heat Shrink
    http://www.buyheatshrink.com/heatshrinktubing/3-1-heavy-wall-polyolefin.htm#B
    .4 Red 3:1 heavy wall adhesive lined heatshrink Amt needed: 4’ piece
    .4 Black 3:1 heavy wall adhesive lined heatshrink Amt needed: 4’ piece
    Tools Needed
    -Heat gun
    -Lug/terminal crimper -Lighter/torch/hot knife to cut braided sleeving
    -Assorted screwdrivers and wrenches
    1. Mounted both batteries and Columbia Overland dual battery tray.
    2. Mounted dual battery solenoid.
    3. Ran controller cable beneath dash and along center console.
    4. Spliced engine harness cable that runs to primary battery using 2AWG butt splice then covered with heat shrink for protection.
    Where I spliced positive engine connection to primary battery.
    5. Mounted fuse block plate with M8-1.25 to fender nutserts. I had to support end with 1/4 x 20 all thread connected to hole drilled through fender.
    Bottom of plate. Locknut and flat washer supporting plate.
    Fenderwell where all thread comes through.
    6. Mounted aux fuse block and circuit breaker. Labeled 12V connections.
    Elkhart likes this.
  12. Aug 4, 2012 at 8:53 AM
    coulter6
    coulter6 Member
    NM
    06 TRD Off Road DC
    Great looking install, very clean and professional looking.
    What model Taco do you have?
    I have an 06 TRD Off Road with an 130A alternator and was wondering if the Nat'l Luna kit would work with it.
  13. Aug 4, 2012 at 9:00 AM
    Enzo
    Enzo Well-Known Member
    Opie
    Bedford, Va
    2012 FJ Cruiser
    2012 FJ Cruiser Maggiolina Medium Grand Tour w/winter hood National Luna dual battery split charging system ABR Sidewinder Aux battery tray ARB 50qt Fridge w/Transit Bag Bajarack flat rack w/ladder Crawlarado flat black hood blackout TRD exhaust Trasharoo Outback FJ roof console
    The NL kit will work in any car.
  14. Aug 4, 2012 at 9:46 AM
    skippermike
    skippermike Well-Known Member
    San Diego
    08 SR5 4x4 w/off road mods
    3" Icon lift, coilovers, reservoir r. shocks, AAL, Icon UCA, 17" Eagle wheels, extra electrical, inverter, ICOM VHF
    Very nice installation.
    As an alternative in a DC, especially if loads are in cab or bed, is to put a thin, taller AGM battery with an intelligent combiner/isolator behind the rear passenger side seatback. Very easy installation. Also easy to install inverter behind rear driver side seatback, with extra 12v outlets.
    As OP suggested, use Blue Sea components, easily available at West Marine. They are good quality and have excellent tech support.
    My primary reason for installing a second battery is that we are often parked for hours with VHF radio on, 12v spotlight, 110v halogen work light, chargers for handheld radio, phones and sat phone, etc. - and don't want to wear down engine battery!
    Good luck.
  15. Nov 13, 2012 at 9:19 AM
    Jbcm12
    Jbcm12 Well-Known Member
    Joshua
    Bay Area
    Sub, good ish
  16. Nov 13, 2012 at 9:31 AM
    acdronin
    acdronin Well-Known Member
    Very nice work!
  17. Nov 13, 2012 at 9:36 AM
    tacoma16
    tacoma16 Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    Very very clean install
    just out of curiosity did you change the alternator to handle the load of the extra battery?
  18. Nov 13, 2012 at 9:37 AM
    Failure2Comply
    Failure2Comply Old HVACR Tech
    John
    Virginia, USA
    05 Access Off Road TRD/SR5
    Now that is one professional looking job, well done sir!
  19. Feb 13, 2013 at 6:49 PM
    Tbird
    Tbird Well-Known Member
    Tom
    Santa Teresa, NM
    05 4X4 TRD Sport Access cab (white)
    ICON Ext.trav coilovers, rear ICON w/res. TC UCAs. All-pro 3" leafpac & U-bolt flip kit. Konig Countersteer offroad wheels. Goodyear Durtracs 260/75/16. Blacked-out badging, BHLM, Extra D-rings, Satoshi grill, SockMonkey "All Terrain" decals, Avid Off-road light bar and rock rails, Wet Okey seat covers. Weathertech digital fit floor mats. GROM ipod interface.
    WOW...very nicely executed. I appreciate the step-by-step and the sources for all the components. I'll probably mimic all you've done and end up with a very similar system.
    :bowdown:
  20. Jul 19, 2013 at 9:45 AM
    Tbird
    Tom
    Santa Teresa, NM
    A couple of questions...
    How many of each lug did you need to tie in the two batteries, the circuit breaker, and the fuse panel?
    Thanks!
