OME 885 coil help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Garrett1, Jul 30, 2012.
  1. Jul 30, 2012 at 9:42 PM
    Garrett1
    Garrett1 [OP] Well-Known Member
    Louisiana
    07 PreRunner SR5
    If I was to install OME 885s and toytec aals could I clear 285s?
  2. Jul 30, 2012 at 10:05 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    With some slight trimming with a razor knife, yes. Keep in mind some 33's are taller/shorter than others. I wheeled my BFG AT's with the trimming I mentioned above. Only rubbing I encountered was full lock in reverse, and only 1 direction.
  3. Jul 30, 2012 at 10:33 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    You'll need wheel spacers or aftermarket wheels too
  4. Jul 30, 2012 at 10:38 PM
    medic2230
    Murph
    Bama! Roll Tide
    Unless you're a mall crawler.
  5. Jul 30, 2012 at 10:40 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    This^ 4.5" bs
  6. Jul 31, 2012 at 4:49 AM
    Garrett1
    Louisiana
    07 PreRunner SR5
    I will be getting new 18'' rims
  7. Jul 31, 2012 at 5:02 AM
    LEX
    LEX --- --- --- - ----
    Houston, Texas
    100 Series LC
    Be prepared to trim some plastic, regardless.
