-   -   Fog Light Kit for 2013 Tacoma......? (http://www.tacomaworld.com/forum/2nd-gen-tacomas/239999-fog-light-kit-2013-tacoma.html)
5150Bronco 09-18-2012 11:22 PM
I just bought a new 2013 Tacoma 4cyl 4x4 and want to put Fog Lights in.
I have looked and I am pretty sure there is no pre-wire.
Is there a difference from 2013 compatibility or do I need a new kit?
Thanks for all the help! :D
us3rname 09-18-2012 11:48 PM
http://www.tacomaworld.com/forum/2nd...-solution.html
Read thru these posts. Im almost certain that what worked for my 2012 will work for your 2013. I ordered the kit from the ebay link in this thread. Only modifications I had to do were to the second set of screw holes to the fog lights. I used all the wireing includeing the relay and added in an add a circut to the headlight low beam and a fuse(since the kit didn't come with one) the switch in the kit will work if you want to put the switch in one of the center console blanks. If not then ditch that swtich. I ordered one for a 2011 and the pig tails.
Armcphail 02-13-2013 07:39 PM
Was yours pre wired?
