Lights for camper, plug wont hold
Discussion in '2nd Gen. Tacomas (2005-2015)' started by phoneguy44, Oct 14, 2012.
  1. Oct 14, 2012 at 1:49 PM
    phoneguy44
    phoneguy44 [OP] Well-Known Member
    Dennis
    Oxford, Alabama
    06 4x4 Double Cab
    Where can I get one of these online (dont knowwhat its called)? I've never needed it till now. Mine was broke when I got the truck and it wont hold my pig tail from camper, keeps falling off. Looks like all I have to do is take two screws out and unplug and repeat process to put a new one on.
    Thanks guys
  2. Oct 14, 2012 at 1:59 PM
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    You can find them on this here site also
  3. Oct 14, 2012 at 7:10 PM
    NHCrewcab2008
    NHCrewcab2008 Well-Known Member
    Thornton, NH
    SR5 TRD
    walmart, $20.
  4. Oct 14, 2012 at 9:02 PM
    brianv3ntura
    brianv3ntura Well-Known Member
    Jacksonville FL
    MGM'12 Taco TRD Sport 4x4 DCLB 4.0L 5spd Auto
    Stock for now.
    Pep Boys sells a bigger variety than Walmart
  5. Oct 15, 2012 at 4:45 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Check Toyota the factory set up is a lot better built and water proof it's also plug and play.
  6. Oct 15, 2012 at 4:55 AM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    Yeah, you need the lid. The lid helps hold your trailer plug. You can find a new pretty much anywhere.
  7. Oct 15, 2012 at 5:59 AM
    Taco Dan
    Taco Dan Well-Known Member
    Dan
    Tuscaloosa, AL
    07 FJ Cruiser auto 4X4
    Snorkel, Cooper ST Maxx 255/80/17, diff breather relocate, Cobra ultra III cb radio set up Warrior Products front bumper
    i only have the 4 pin harness. is there such think as a converter from 4 to 7? i like that hopkins one
  8. Oct 15, 2012 at 6:13 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I've never seen a 4-7 pin harness and probably for the same reasons DoorDing already mentioned.
  9. Oct 15, 2012 at 6:39 AM
    oldstick
    oldstick Medicare Member
    GA
    I had a 4 to 7 adapter some years ago. But I do not remember where I got it. I think it was probably Walmart or one of the chain parts stores.
    In fact I need to look for it, it might still be around somewhere. I used it for a small boat trailer with 4 pins, where my truck and pop-up camper were using the 7 pin.
  10. Oct 15, 2012 at 6:44 AM
    Pugga
    Massachusetts
    Sounds like you had a 7 - 4 pin adapter, not a 4 to 7 pin. The 7 to 4 is easy to find and is available at any auto parts store, Uhaul or Walmart. I don't believe the 4 to 7 exists because it would allow the owner to tow a trailer without the proper connections. As DoorDing said, most trailers with 7 pin connectors have them because they require brakes. A connector that has 4 pins on the truck side and 7 on the trailer side would bypass the brakes.
  11. Oct 15, 2012 at 6:45 AM
    phoneguy44
    Dennis
    Oxford, Alabama
    06 4x4 Double Cab
    Thanks guys ! Much appreciated.
  12. Oct 15, 2012 at 11:50 AM
    phoneguy44
    Dennis
    Oxford, Alabama
    06 4x4 Double Cab
    hmm, anyone have the OEM part number by chance ?
  13. Oct 15, 2012 at 2:22 PM
    phoneguy44
    Dennis
    Oxford, Alabama
    06 4x4 Double Cab
    Just went by the dealer, $224.95 OUCH
  14. Oct 15, 2012 at 4:32 PM
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    For that price buy an aftermarket and replace it every other year.
  15. Oct 15, 2012 at 4:43 PM
    Round II
    Round II Member #12005
  16. Oct 15, 2012 at 5:19 PM
    charles leandro
    charles leandro Well-Known Member
    north alabama
    08 perrunner dc sr5
    none
    just go to u haul or rv store
