rear end noise
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cline, Jan 6, 2013.
  1. Jan 6, 2013 at 8:52 PM
    cline
    cline [OP] Member
    ethan
    Covington, va
    07 tacoma SR5
    3in pro comp lift 285/75/16 Cooper discovery stt tires
    My rear end is making a squeaking noise only at higher RPMs . Ive been off roading a whole lot lately because of hunting season and spinning alot because where i hunt at is pretty rough. Could anyone tell me whats wrong
  2. Jan 6, 2013 at 11:10 PM
    92LandCruiser
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    off that? no
  3. Jan 6, 2013 at 11:20 PM
    RelentlessFab
    Eric
    Sparks, NV
    x2
    Too vague. OP, can you describe the sound/condition it occurs at better?
  4. Jan 7, 2013 at 5:44 AM
    cline
    cline [OP] Member
    ethan
    Covington, va
    07 tacoma SR5
    There aint to much to describe. It makes a squeeking noise, and the higher rpm's that i run, the louder the sound gets
  5. Jan 7, 2013 at 5:49 AM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    check your u joints then wheel bearings
  6. Jan 7, 2013 at 5:53 AM
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    Pinion bearing on one of your diffs?
  7. Jan 7, 2013 at 6:03 AM
    fireturk41
    Kevin
    High Point, NC
    280k miles
    being an 07 its more probable its the other two, im waiting for OP to reply back
    also whats the whining sound like, does it increase/decrease with turns/ acceleration/deceleration? is it squeak squeak squeak how many miles on the truck
  8. Jan 7, 2013 at 8:59 AM
    cline
    cline [OP] Member
    ethan
    Covington, va
    07 tacoma SR5
    It sounds like pieces of metal hitting together. It only does it if im accelerating, doesn't do it in turns or decelerating . And 54,000 miles
  9. Jan 7, 2013 at 9:02 AM
    BORNWILDGUY
    BORNWILDGUY Well-Known Member
    Rich
    Florida
    2020 TACOMA TRD SPORT DCLB LIFTED W KDMAX-PRO XT TUNE
    FULLY LOADED WITH THE TECH PACKAGE, LEATHER, JBL, LED HEADLIGHTS, MOONROOF, EXTANG FULL TILT COVER, NFAB SIDE STEPS, OEM ROOF RACK, TRD PRO TAILS, WHITE RAPTOR LIGHTS, 15% TINT ALL THE WAY AROUND, BILSTEIN 6112'S W 650# SPRINGS AND 1/4 SPACER, ICON LEAF SPRINGS W 5125 REAR SHOCKS, 18 x 9 -12 Weld Racing Ledge 6 wheels w 275/65r18 Toyo AT III tires
    Check your fluid level in the rear end
  10. Jan 7, 2013 at 9:39 AM
    fireturk41
    Kevin
    High Point, NC
    280k miles
    defineately sounds like a ujoint
  11. Jan 7, 2013 at 11:11 AM
    cline
    cline [OP] Member
    ethan
    Covington, va
    07 tacoma SR5
    Alright thanks alot y'all, ill have to get it check out
