Bearing noise at slack throttle at highwat speeds
Discussion in '2nd Gen. Tacomas (2005-2015)' started by skytower, Jan 22, 2013.
  1. Jan 22, 2013 at 2:12 PM
    skytower
    skytower [OP] Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    (highway speeds)Going 60mph on a level road, I get a grumble. Not at accel nor at decel, slack throttle, it happens. It's almost like the noise you get when threading a large nut down a threaded rod, or holding a Timken bearing by the inner race and spinning the cage. The location of the noise is very difficult to pinpoint:(
    New ujoints, front wheel bearings, 103k miles, one piece driveshaft.
    Any ideas?
  2. Jan 29, 2013 at 7:19 AM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    Anyone? Bueller?
  3. Apr 24, 2013 at 7:12 AM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    Still looking. Noise is getting worse:(
  4. Apr 24, 2013 at 4:27 PM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    Well... Road speed makes a difference with the speed and intensity of the noise. There is no difference with engine speed, nor with gear selection.
    There were no shavings in the diff, xfer case, nor trans lube. I suspect from the trans output to the rear of the drivetrain, but I would like to hear from someone else before I start tearing into anything.
    I have till middle of May to get it fixed...
  5. Apr 24, 2013 at 5:11 PM
    92dlxman
    92dlxman drinking whats on sale
    Kevin
    Visalia, CA
    08 access 4x4 4.0 6-gear
    5100s, ome884s, wheelers aal kit, and some rustoleum
    honestly, no idea, but maybe its gear chatter somewhere as at "slack" throttle its likely switching from loaded, to reverse loaded very quickly?
    check driveline lash at the rear end? im digging deep on this lol
  6. Apr 24, 2013 at 5:37 PM
    Jetman1979
    Jetman1979 Well-Known Member
    Michael
    North Texas
    2009 tacoma 4X4
    Look at your carrier bearing in the middle of your drive shafts.
  7. Apr 24, 2013 at 5:41 PM
    Ghost848
    Ghost848 Well-Known Member
    Tony
    Alberta,Canada
    09 V6 TRD OR Silver M6
    OME + Dakers, 285/75R16 Nitto Trail Grapplers, ARB Bumper, Columbia overland Dual battery, Super winch,CC stage 4 clutch, bestop supertop, URD TO bearing, BHLM headlights, Cruisin offroad rear bumper, Harrop front E-locker.
    One peice drive shaft.
    If it was bearings it would be more of a wirring noise to it. Diff has more of a worrr noise... In my experience.
  8. Apr 24, 2013 at 6:17 PM
    Jetman1979
    Michael
    North Texas
    2009 tacoma 4X4
    My bad I reread and saw 1 piece shaft
  9. Apr 24, 2013 at 6:20 PM
    Jetman1979
    Michael
    North Texas
    2009 tacoma 4X4
    Have you done anything to the rearend. Possible axle bearings or the 3rd member? Can you get the truck in the air safley and run it maybe on a lift or something?
  10. Apr 25, 2013 at 11:51 AM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    20 mph on jack stands made no obvious noises via stethoscope.
    Only mod is the lift. New ujoints, no abormal slop in drivetrain.
    No shavings in any gear lubes.
    I'm going to hunt for TSBs and look to see if there are any sealed bearings in the trans and xfer case. It has to be something from the output shaft of the trans on back, since it's road speed related.:notsure:
  11. Apr 25, 2013 at 2:03 PM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    Dealer wants $120 to take a look at it...FML.
  12. Apr 25, 2013 at 2:13 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    How recently did you change your wheel bearings? One could have been bad or damaged during the install and worn out prematurely. Have you checked any of the wheels for play or check the tranny output shaft for play for that matter?
  13. Apr 25, 2013 at 2:20 PM
    jandrews
    '09 FourDubDee TRD OR
    Dave...
    I had this same symptom above 70mph on the way home last weekend from gulches while running my 1 piece driveshaft spare.
    Haven't had it up to that speed since then, but will keep you posted (please do the same for me). I also suspect rear drivetrain, particularly u-joint or slip yoke. Tq on all the bolts was good. Hoping when I torched the stock driveshaft I didn't cause a problem with the trans output.
  14. Apr 25, 2013 at 2:30 PM
    650H1
    650H1 Well-Known Member
    Michael
    VA
    2020 (Cement) TRD O/R
    its the driveshaft... they arent long enough on the reg cabs. its not a big deal, nothing is "wrong" per say, but if you flip your driveshaft around, it will eliminate the noise. thats what i did with my reg cab, and it was fine. a better fix would be to have your driveshaft lengthened. fwiw...
  15. Apr 25, 2013 at 2:34 PM
    Blueitrgsr
    Blueitrgsr Well-Known Member
    Brad
    Gainesville, Fl
    2006 Reg Cab 4wd
    Some bilsteins, OME 885's, and an AAL.
    Seems like most reg cabs do it. Flipping the driveshaft around usually helps. Mines done it since the day I bought the truck.
  16. Apr 25, 2013 at 3:01 PM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    Worth a try... In progress shortly, will post details.
  17. Apr 25, 2013 at 3:34 PM
    650H1
    Michael
    VA
    worth a try? that the fix. its not u-joints, or a carrier bearing. its your driveshaft. it needs to be lengthened. either spend the $150 to get it lengthened, or flip it for free. either way, there is nothing wrong with your truck, and nothing is broken.
  18. Apr 25, 2013 at 4:29 PM
    Pugga
    Massachusetts
    Out of curiosity, how does flipping the shaft solve the problem?
    I believe OME sells a drive shaft spacer. If length is the issue, that could be another solution.
  19. Apr 25, 2013 at 7:01 PM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    Flipping it moved the noise to the rear of the truck, and it doesn't do it as long.
    Also, It no longer has a vibe at 60MPH anymore.
    So, no, it is still not fixed. I just need to get another driveshaft. Any recommendations on who to go through? I don't like spacers. They might be nice for a temp fix till I save for a new driveshaft though.
  20. Apr 25, 2013 at 7:52 PM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    Reading up on the spacers, I see that they are a bad idea. More extreme shaft angle and a higher likelyhood of running out of slip joint travel=smashed xfer case. New shaft it is.
