Wiring Diagram for Rear View Mirror?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dragnet, Feb 17, 2013.
  1. Feb 17, 2013 at 2:41 PM
    dragnet
    dragnet [OP] Member
    2008 Indigo Blue Tacoma 4x4
    Hi all,
    I recently obtained a Blend Mount to hang my radar detector underneath my rear view mirror. Installing the mount was simple; however, I am having quite a bit of difficulty tapping into the power from the rear view mirror.
    I have an '11 Tacoma Prerunner with a back up camera in the mirror.
    According to the Blend Mount instructions, I need to plug the black MTPC clip into the ground wire and the red MTPC clip into the 12 volt wire. The instructions are generic and do not specify which color to use.
    I have tried searching and have been unable to find the diagram, anyone know which is which?
  2. Feb 17, 2013 at 5:36 PM
    Agro
    Agro Well-Known Member
    San Diego
    2015 Ford F-150 XLT 3.5L Ecoboost!
    I unplugged it and put wire in the holes and used a volt meter to determine the +12v. I listed it in the Valentine One thread. Couldn't remember what wires now. Also on my iPhone. Search and you'll see.
  3. Jul 29, 2013 at 11:48 PM
    dragnet
    dragnet [OP] Member
    Follow up.
    Here are pictures (after some trial and error) of the wires I plugged into.
    Radar detector comes on/off with key turn of the ignition.
  4. Feb 7, 2014 at 9:54 AM
    bluebird1717
    bluebird1717 Member
    Jacksonville, Florida
    12' Access Cab V6 TRD
    How did you determine which wire/hole to insert the mirrortaps ground wire into? Arent most of them grounded?
  5. Feb 8, 2014 at 3:24 PM
    dragnet
    dragnet [OP] Member
    To be honest, rather unscientifically.
    Trail and error.
  6. Oct 10, 2021 at 7:51 PM
    Pearson
    Pearson Well-Known Member
    Elliott
    Lexington Texas
    Black 2012 2.7L Prerunner
    I can't tell what the wire color was for the proper 12V & Ground. Has anyone ever came up with an actual diagram? Best I can tell the Blue was your ground. And I cant see the color or pin location of the 12V at all. Could you clarify?
  7. Oct 10, 2021 at 8:02 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Predator tube steps, Ranch Hand grill guard, Magnaflow CatBack exhaust, Toyota tool box & bed mat, 2LO Module by @Up2NoGood, Rearview Compass/Temp Mirror, Tune by @JustDSM.
    Here you go.
    Looks like
    Pin 1 Light Green is switched ignition
    Pin 2 White/Black is ground
    Pin 8 Red is battery power
  8. Oct 10, 2021 at 8:08 PM
    tcjacado
    tcjacado Well-Known Member
    You all do realize this is fro. 2014, right?
  9. Oct 10, 2021 at 8:14 PM
    Pearson
    Elliott
    Lexington Texas
    And you sir are my new hero! Question though, the schematic is clear. My tap's Hot (red) to LT. Green my tap's ground to white/Black. But should I not want some sort of circuit protection possibly in the form of an inline fuse? Educate me.
  10. Oct 10, 2021 at 8:17 PM
    Pearson
    Elliott
    Lexington Texas
    My Taco is a 2012 Prerunner with the fancy mirror, backup, compass etc. Is this diagram correct? The diagram is labeled "2012 Toyota Tacoma Base" I'll ring it out myself to confirm. This gives me a place to start at the very least. What is the consensus concerning an inline fuse?
    tcjacado[QUOTED] likes this.
  11. Oct 10, 2021 at 8:23 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Ideally you would use a fuse that is lower amperage than the fuse that is in the circuit but since the circuits both have their own fuses it's not an absolute requirement.
    He meant the thread was from 14, the diagram I posted is for a 2012 truck.
    Pearson[QUOTED] and tcjacado like this.
  12. Oct 10, 2021 at 8:27 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    I know I was just trying to answer the question that was currently being asked, not really worried about when the thread originated.
    TnShooter and tcjacado[QUOTED] like this.
  13. Oct 10, 2021 at 8:28 PM
    tcjacado
    :cheers:
    :hattip:
    Pearson likes this.
  14. Oct 10, 2021 at 8:33 PM
    Pearson
    Elliott
    Lexington Texas
    Thanks for the info, I now understand about the 14 comment, though I don't see the relevance.
    Question out of curiosity, Is the NCA not a ground as well? And what is the reference CGND? Is it for (continuous ground)? Also what color does NCA represent?
  15. Oct 10, 2021 at 8:39 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    NCA (No Color Available) This mean the manufacturer didn't provide a color.
    I'm assuming CGND is the camera ground but I can't be sure, I wouldn't use it for a ground anyway use the dedicated mirror ground.
  16. Oct 10, 2021 at 9:00 PM
    tcjacado
  17. Oct 10, 2021 at 9:19 PM
    Pearson
    Elliott
    Lexington Texas
    That sounds like the best thing to do for sure. Thank you for taking the time, I really appreciate it. I had looked for the schematic for a while. Is there an all-inclusive whole truck reference available somewhere?
  18. Oct 15, 2021 at 4:33 PM
    Pearson
    Elliott
    Lexington Texas
    Taken from another Thread but applies here.
    Well finally made time to hardwire the V1 this past Wednesday. I used the Rearview Mirror diagram a TW brother provided that I believe showed the #1 pin position as Lt. Green as ignition switched 12V power and White & Black as Ground.
    Well, this was accurate and she is all done and done. One little unexpected quirk I found was that when you go into reverse, power is cut to the Lt. Green wire thus killing whatever you are powering. LOL Hopefully no one here needs a V1 while in reverse. Other than that all is well!
    Peace-Love & Taco's
  19. Oct 15, 2021 at 4:39 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Interesting, the diagram must not be entirely correct then because it shows that wire coming directly from the IG2 fuse which is hot in run or start.
  20. Oct 15, 2021 at 5:05 PM
    Pearson
    Elliott
    Lexington Texas
    Interesting give me a sec and I get my copy. Never really looked downstream of the mirror connector.
    OK Right but let's look at the ground. Is it an uninterrupted circuit?
